Vectra 4/66 cpu upgrade problems
Reply 20 of 31, by Intel486dx33
A 486dx4-100 should score about 200 in topbench.
Looks like you CPU is either running at 25mhz bus speed or set up 33mhz bus for a 486dx2-66 CPU.
See my photos for reference.
Reply 21 of 31, by jm8881
What is that middle benchmark you attached?
    1.65 MiB
    1.68 MiB
    1.4 MiB
Reply 22 of 31, by thepirategamerboy12
The middle benchmark is Speedsys. Surprised it's working on here, though. I have this same computer (with the stock CPU) and it hangs at determining memory contents or something like that.
Reply 25 of 31, by jm8881
Oh, ive never let it complete then. it runs a long time just flashing 164/165 and I didnt know if it ended or if that was the whole test. I'll let it run then.
    1.34 MiB
Reply 26 of 31, by thepirategamerboy12
jm8881 wrote on 2021-06-21, 03:34:
If you're running it from Philscomputerlab's DOS Benchmark pack, to get the full interface go to the MARKS\TOPBENCH directory and run it directly from there with no command switches.
Reply 27 of 31, by jm8881
Thanks for that.
Running it I get two different outputs as far as system specs. They cycle from one to the other every few seconds with the incomplete output only lasting about half a second.
I realize that it isn't my systems specs but what it thinks is a similarly spec'd machine. It never shows a 100mhz cpu but the rest of the tests do?
    1.27 MiB
    1.4 MiB
Reply 29 of 31, by jm8881
Sigh, ok. I put the dx2 66 in, changed the jumper jp16 to 1-2 for dx2 and the self test at the post listed it as such. But in topbench it listed it as a 50mhz. But if top bench was detecting 66mhz on the dx4 100 Bthen wouldn't the jumper setting have already been on 33mhz?
For clarity there are 4 jumpers on this board that configure the cpu and the manual describes them as:
Cache Mode Selection
JP8*
1-2 Write back mode (with JP8 set to 2-3)
2-3 Write through mode, with JP10 set to 1-2 (default)
1-2 Write through mode, with JP10 set to 2-3 (default)
2-3 Write back mode (with JP8 set to 1-2)
Processor Speed
JP13
1-2 33 MHz (66 and 100 MHz processors)
2-3 25 MHz (50 MHz processor)
Processor Type
JP16
1-2 DX2 Processor
2-3 DX 4 Processor
It shows jp10 but doesn't describe what it does, only mentions it in jp8 settings. I believe jp10 toggles the multiplier. Not entirely positive on that one though. The jp8 section is very confusing and I think where it says:
JP8*
should be:
JP8*
1-2 Write back mode (with JP10 set to 2-3)
because how would you set it to 1-2 and also set it to 2-3? Unless I'm not understanding it correctly. The documentation isn't very good on this computer.
Thank you all for your help so far. Hope we can get this figured out soon.
    253.83 KiB
Reply 30 of 31, by megatron-uk
Ah, you may have misunderstood what Topbench does - it doesn't identify your system as such; it actually measures the performance of your system (cpu, fpu, ram, video) and compares it against entries in its internal database.
What it shows on-screen is the closest matching system to your current performance (depress the turbo switch on your system to see it alter in real-time and find the next closest match).
To see what your processor is actually running at, you should look at something like chkcpu, comptest, nssi or similar.
https://www.target-earth.net
Reply 31 of 31, by jm8881
Good news, I got the new "enhanced" dx4 100 today. I put it in, changed the jumper to dx4 and it just works.
I think this computer is just not fully compatible with certain cpus.
    787.89 KiB
    840.33 KiB
    685.3 KiB
    390.21 KiB
