First post, by dreamblaster
Hi,
teaming up with Matze, I made a compact PCB, inspired by his PS/2 mouse to serial port converter.
This works fine now, and I soon will have a first batch available.
It plugs directly on the DB9 serial port, and allows to connect a PS/2 mouse, and has an USB connector for 5V power.
A 3d printed enclosure is being designed as well.
I will post more information in this thread.
EDIT 12.11.2020 :
available here : https://www.serdashop.com/PS2TOSERIAL
quick demo here : https://youtu.be/G6yVVGo7HpQ
    538.18 KiB
Thanks for your support !
Reply 2 of 56, by dreamblaster
Ready and available now at https://www.serdashop.com/PS2TOSERIAL
    281.49 KiB
    438.02 KiB
Reply 3 of 56, by darry
It's remarkable how Serdashop manages to offer niche (relatively small production run), but very useful, often unique and high quality products at very reasonable prices . This is one that I do not personally need, but I would buy it in an instant if I did .
Reply 4 of 56, by dreamblaster
Quick demo of PS2TOSERIAL : https://youtu.be/G6yVVGo7HpQ
Reply 7 of 56, by dreamblaster
konc wrote on 2020-11-12, 10:06:
Excellent news! Will the enclosure be available soon? I want to get one but since I want the enclosure as well should I wait a bit?
Yes better wait for the enclosure then, it may take some time until it is available though
Reply 8 of 56, by konc
dreamblaster wrote on 2020-11-12, 10:09:
Nah, if it's not just a couple of days I'm getting it now and we'll add the enclosure in the next order, there will be a next order for sure 😉
Reply 10 of 56, by darry
northdale wrote on 2020-11-12, 13:03:
There are many passive serial to ps2 adapters. What is the benefit of this one?
This one is active . It will work with PS/2 mice that do not have serial compatibility built in .
The passive adapters require a mouse that already supports the serial protocol .
Reply 11 of 56, by chrismeyer6
This is a great idea I like how small and compact it is. It'll be nice to use optical mice on older systems as well as making it easier to use with newer KVM's.
Reply 12 of 56, by Pierre32
darry wrote on 2020-11-11, 23:07:
Amen to this 😀
Reply 13 of 56, by colpoz
Has it been tested on KVM switches? Does it work with them?
RetroPc I: Asus P3V4X - PentiumIII 1000MHz - 256MB Ram - Geforce3 Ti 200 - SLI VoodooII 12MB - Aureal Vortex2 - HDD 80GB - Win98 SE
RetroPc II: Asus P5A - K6-2 333MHz - 64MB Ram - Geforce2 MX - Voodoo 4MB - Soundblaster AWE64 - HDD 13GB - Win95
Reply 14 of 56, by 1541
... but I would buy it in an instant if I did .
I did 😀
By the way, is it possible to power the adapter with this solution?
61.4 KiB
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 16 of 56, by konc
1541 wrote on 2020-11-13, 20:00:
Where can I buy these? I wasn't able to find them on ebay and they look like an excellent solution, no extra adapters/plugs
Reply 18 of 56, by konc
1541 wrote on 2020-11-13, 20:56:
Sellets from CN offer them on amazon.
www.amazon.de/dp/B01F35XBS4
However this is not Mini USB but USB-A
Exactly, I couldn't find anything like in your picture
Reply 19 of 56, by matze79
colpoz wrote on 2020-11-13, 07:37:
Yes, but due double Translation its possible you get delay.
But not all Devices are tested.
I use it daily with my Lindy KVM and its also tested by few Members of dosreloaded.de.
Christian Machill did rewrite the whole Firmware back then to make it better compatible.
NuXT also runs this Converter Device onboard.
Its highly recommend to use High Speed Mode (19200 Bauds)
The Adapter is configurable by Software.
But needs Special Drivers then.
I will update the Stuff during the Week and Dreamblaster can add it to its repository.
It needs some Translation as its german only currently.
