Asus P2B-DS Rev 1.06 FSB Modification
Reply 20 of 72, by H3nrik V!
wiretap wrote on 2020-11-11, 22:21:
Gerber files attached. I just whipped this up in about 20 minutes, so please review before sending to the fab.
Looks good here, in ViewMate ..
Reply 21 of 72, by mockingbird
TimWolf wrote on 2020-11-16, 10:39:
When you have a good source, share that vendor with the class. Thank you!
Ok, I ordered from three seperate vendors. I won't share the vendor because of hoarders, but I'm happy to send it to whoever needs one for the price of the chip and a stamp to your country.
(Decommissioned:)
Reply 22 of 72, by Mamba
wiretap wrote on 2020-11-11, 21:52:
Nice mod :P […]
Nice mod 😜
Here's my idea..
Any chance it can be built and ordered for real? Seems a pretty slick solution...
Reply 23 of 72, by wiretap
Mamba wrote on 2020-11-17, 07:02:
Nice mod :P […]
Nice mod 😜
Here's my idea..
I'll do it at some point. But I provided the gerber files so anyone can send it to a place like JLCPCB or PCBway to be fabbed. It should be around $2 for 5 boards + shipping costs if you do it. Then all you need is some male and female 2.54mm pin headers and a single 10k-ohm 0603 surface mount resistor.
My Github
Circuit Board Repair Manuals
Reply 24 of 72, by Mamba
wiretap wrote on 2020-11-17, 18:47:
Nice mod :P […]
Nice mod 😜
Here's my idea..
Problem is, I have no clue of what your are saying, let alone answer to any type of question that the fab would say to me regarding the pcb I need...
I am a total dumb in electronics I can only give money to buy things....
ugh.. Ugh...
Reply 25 of 72, by wiretap
Mamba wrote on 2020-11-18, 15:21:
Problem is, I have no clue of what your are saying, let alone answer to any type of question that the fab would say to me regard […]
ugh.. Ugh...
It is much easier than you think. For example, go to jlcpcb.com and click the "Quote Now" button on the page. It will then take you to another page where you click the "Add Your Gerber File" button. Upload the ZIP file that I attached a few posts back. Then select the PCB color you want, and checkout/purchase it. That's all there is to it.
My Github
Reply 27 of 72, by Mamba
Ok I received my P2B-d.
It is 1.06 and D03 it seems, hope it works now.
Can't wait to see updates on this thread.
Edit: what's on the back pf my mainboard?
Are the two little cables normal??
    799.09 KiB
Reply 29 of 72, by Mamba
Just an update.
While waiting for your very nice piece of hardware, I learned the hard way that my two P-III 933MHz won't run in SMP with the P2B-D, because I have not the proper slotkets... Apparently there are not suitable slotkets for coppermine/smp (apart legendary Asus S370-DL of course).
Correct me if I am wrong, hope I am.
Took 10 year to find a decent and 100% functional P2B-D 1.06 BR03, just to find it is useless.
Very sad...
Reply 30 of 72, by PARKE
Mamba wrote on 2020-12-08, 09:27:
Just an update.
8><CUT
What type of slotkets are you using ?
Reply 31 of 72, by Paadam
MSI 6905 ones can also be used with small modifications, ver 2.3.
Also if wanting to use Coppermine just buy Slot1 CPU's, no point messing with S370 ones.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 32 of 72, by adalbert
Paadam wrote on 2020-12-08, 20:17:
Do you know what kind of modifications are needed?
Reply 34 of 72, by H3nrik V!
S370 Coppermines just tend to be more available than Slot1's ..
Reply 35 of 72, by Mamba
H3nrik V! wrote on 2020-12-09, 09:17:
This
and also Slot-1 FSB 100 are even less available.
It is difficult to find MSI slotket also...
Reply 37 of 72, by Mamba
PARKE wrote on 2020-12-12, 13:59:
Sent four emails to them without any answer.
Not so friendly to say the least...
Plus it says 2.x meaning it can easily be 2.0 to 2.2, so perfectly equivalent to the 3 Super Sloket III I already have that do work in dual but with Mendocino only
Reply 38 of 72, by PARKE
Mamba wrote on 2020-12-13, 09:40:
8><cut
You are likely right. It seems you need a [version 2.3] with a 4-pin configuration on jumper 3 and even then correct functioning is not guaranteed.
51.11 KiB
Reply 39 of 72, by Mamba
Nice mod :P […]
Nice mod 😜
Here's my idea..
Wiretap you are the hero I am waiting for right now.
Let the world know when you end up with your tool and be prepared to take my money...
For the moment I have this getto solution with two Mendocino cpus
    1.02 MiB
