First post, by adalbert
-- update: here is somehow-working version if anyone needs it /at least in my board, no warranties/--
1834v105TA_mod1.zip
152.5 KiB
12 downloads
I have a dual-cpu Slot-1 Tyan S1834D Tiger 133 mainboard with Via 694X chipset. I just sucessfully modded MS6905 Master 2.3 slotket and booted that mainboard with one SL5XL Pentium IIIS 1400MHz CPU (didn't try dual-cpu setup yet, I need to get second slotket). I set voltage jumpers to 1.45V, I measured 1.54V on MOSFET tab next to the CPU slot, but I guess that's fine. (edit: that was next to the empty slot, working slot gets 1.47V under load, so that's perfect)
It POSTs just fine, but displays wrong multiplier. CPU is detected as PENTIUM III 1400MHz (215x6.5). There is no -S suffix.
Should I care about this? Do I lose anything by not having proper microcode in BIOS? I can't find a BIOS with Tualatin update for this motherboard. Are there any tools I can use to add the microcode by myself? Or does it require hex-editing the BIOS by hand? I have a programmer so i'm not worried about bricking the board.
    464.96 KiB
Repair videos: https://youtu.be/T6mXM1tA7pA
Reply 1 of 20, by darry
adalbert wrote on 2020-11-14, 00:57:
There is Bios Patcher 4.23, which works for Award BIOSes . See Help needed with booting slot1 boards with unsupported CPUs
Be careful, though. It can create a non bootable BIOS. Make sure you can recover from a bad flash (by hot flashing or preferably with an EEPROM programmer) .
Reply 2 of 20, by gex85
Some useful tools and microcodes can be found on www.rom.by (you might want to use Google Translate...).
Additionally, I found the Award BIOS Editor to work very well for this purpose. I can post some more detailed instructions later... Once you have figured out the process it becomes really easy.
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 3 of 20, by red-ray
I expect the raw multiplier in MSR 0x002A is 0x1F which is x10.5, but the BIOS is only looking at the low 4 bits as x6.5 is 0x0F. I further suspect the BIOS does not have code that knows about the CPUID 2 cache type 0x83 which is L2 512KB . I wonder what CPUID 80000002/3/4 return, it should be "Intel(R) Pentium(R) III CPU - S 1400MHz".
I could comment further if you posted the Menu->File->Save Local files from my SIV utility, ideally run SIV32X on Windows XP or later.
Reply 4 of 20, by adalbert
Thanks for the answers,
darry wrote on 2020-11-14, 04:55:
gex85 wrote on 2020-11-14, 08:33:
i will check these tools. I have TL866II programmer, so I don't even have to program BIOS in-system.
red-ray wrote on 2020-11-14, 15:24:
I attached saved files. I ran SIV32X on Windows 7.
    tyan_s1834D_SL5XL.zip
    198.23 KiB
    14 downloads
    35.23 KiB
Reply 5 of 20, by red-ray
adalbert wrote on 2020-11-14, 19:20:
Windows 7 is good. My initial thoughts were correct and as I suspected the name in CPUID 80000002/3/4 did not have the - S, I don't think this really matters.
The BIOS only detected 2 DIMMs, but looking at Menu->System->SMB Bus there look to be three DIMMs present. How many DIMMs are actually installed? I think there is a Golden Empire DIMM with some sort of issue.
SIV did not detect any SIO chip so no motherboard temperatures, fan speeds or voltages were reported. Do you know if the board has one/does the BIOS report these?
Reply 6 of 20, by adalbert
Thanks for checking the logs.
Yes, I had three DIMMs installed, and they were not detected correctly. First I tried populating 4 banks with 256MB modules (8 chips on each side of stick). With four modules BIOS detected 640MB? or so. With three it detected 512MB, and in such configuration I saved the logs. After that I removed all the memory, installed 2 x 256MB modules with 4 chips on each side and they are correctly detected as 512MB. Memory problems were mentioned in BIOS changelog, I should update to the newest BIOS and see how it behaves. But it still won't have Tualatin support.
BIOS reports both fan speed and temperature. It has W83977EF-AW chip.
Reply 7 of 20, by red-ray
adalbert wrote on 2020-11-14, 21:44:
OK about the DIMMs, let us know how things transpire.
Looking at the attached W83977EF-AW datasheet it does not do hardware monitoring, is there another Winbond chip?
    W83977EGAW.pdf
    1.39 MiB
    11 downloads
Reply 8 of 20, by adalbert
Sure, I will try to use whole gigabyte of RAM with this board. Currently I am trying to inject Tualatin microcodes with CTMC and Award Bios Editor. If I get everything to work I will post the results.
There are no other Winbond chips. There is a programmed GAL next to it and some logic chips, there is also a Myson MTP008P28 chip in 28 pin case, I couldn't find a datasheet. I don't know how motherboard reads the temperature and fan speed.
//EDIT: i found this document https://www.fnal.gov/projects/ckm/ckm_cluster … sors.conf.ckmxx
chip "mtp008-*" # The values below should be correct if you own a Tyan S1834D motherboard. # If not, please contact us, so […]
chip "mtp008-*"
# If not, please contact us, so we can figure out better readings. (...)
so it looks like that Myson chip might be used for the sensors, but still I can't find datasheets. Edit: more info is available when looking just for MTP008
Reply 9 of 20, by adalbert
Update:
Mainboard was able to detect 1024MB of RAM after trying to use different sticks, but when I used more than 2 sticks i got black screen after changing any BIOS settings and board refused to boot until CMOS was cleared. I will try to get 4 identical sticks, or two 512MB sticks, maybe it will be better.
I added microcodes (up to 6B1) with CBROM utility. I tried to use Award BIOS Editor, but it caused BIOS checksum error displayed on the screen and the board refused to boot. I am still getting exactly the same message on boot (PENTIUM III 1400MHz (215x6.5)). I don't know if I did it properly, i just merged all microcodes with copy /B *.bin cpucode.bin and replaced them with CBROM.
By the way, USB isn't working under Windows 7 (Code 12 on USB controller), i need to check if using older OS would fix it. The same problem existed on stock BIOS.
maybe I will try BIOS Patcher 4.23 linked earlier and see if it fixes anything
Reply 10 of 20, by red-ray
adalbert wrote on 2020-11-14, 22:35:
Thank you for the information and I suspect they are read via SMBus device [ 0_2D ], see Menu->System->SMB Bus. If you press [ 0_2D ] this should dump all the data and pressing [Timer] should update the data every few seconds. Do any values change as you plug/unplug fans and if so which ones?
I may be able to deduce what is what if you post a screen shot of what the BIOS reports so please do this.
I have adjusted the attached SIV32X 5.54 Tyan-01 test SIV so it should report Tyan S1834D (Tiger-133) and the BIOS version as V1.05, please may I have new save files so I can validate the changes.
It looks like Windows 7 loaded the CPU µCode 001C from mcupdate_GenuineIntel.dll so if not being in the BIOS is not a real issue. I suspect WXP would also do this.
Looking in the manual it specifies Supports up to 2 GB at 100 MHz and Supports up to 1.5 GB at 133 MHz so I suspect only three DIMM slots can be used with PC133 memory.
Update: I just found a PII CPU CARD VER1.5 + SL36C that I have not used for at least 15 years and I am wondering if it will work with a Tualatin CPU. The two jumpers are JP1 + JP2 and I have no idea what they are for.
    148.08 KiB
Reply 11 of 20, by red-ray
adalbert wrote on 2020-11-14, 23:56:
See https://support.microsoft.com/en-gb/help/3101 … ager-in-windows which says
This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12)
Cause
This error can occur if two devices that are installed on your computer have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or both). This error message can also appear if the BIOS did not allocate enough resources to the device.
Recommended Resolution
Windows Vista and later versions of Windows
Use Device Manager to determine the source of and to resolve the conflict. For more information about how to resolve device conflicts, see the Help information about how to use Device Manager. This error message can also appear if the BIOS did not allocate sufficient resources to a device. For example, this message will display if the BIOS does not allocate an interrupt to a USB controller because of an invalid multiprocessor specification (MPS) table.
Windows Server 2003, Windows XP, and Windows 2000
Open Device Manager.
Double-click the icon that represents the device in the Device Manager window.
On the device property sheet that appears, click Troubleshoot to start the hardware troubleshooter for the device.
This error message can also appear if the BIOS did notallocate sufficient resources to a device. For example, this message will be displayed if the BIOS does not allocate an interrupt to a USB controller because of an invalid multiprocessor specification (MPS) table.
Reply 12 of 20, by adalbert
red-ray wrote on 2020-11-15, 10:47:
I put that system aside for a moment, I ordered new PSU and heatsinks for the CPU because I was running it with a tiny heatsink and underpowered Pico PSU inside a cardboard box. I will mount it in a case, do a fresh install of OS and upload logs when I reassemble it.
USB: maybe OS reinstall will fix it, because i just took a HDD with preinstalled Windows 7 out of different machine with VIA chipset. BTW USB keyboard works fine in BIOS, with or without Legacy USB keyboard setting enabled, but as soon as OS boots it stops working.
That slotket is built for Celeron Mendocino CPUs.
I found info about jumpers here: https://de.comp.hardware.cpu-mainboard.misc.n … d-ver1-5-jumper (google translate)
JP1 stands for the FSB, open 66MHz, closed overclock,
JP2 stands for dualprocessing, open none, closed dual.
It will not work out of box with Tualatin CPUs, also probably not with regular P3. S370 had 3 variants: PPGA, FC-PGA, FC-PGA2. Maybe it could be modded for Coppermine CPUs with PPGA -> FC-PGA mod. But the problem is that this adapter doesn't have voltage clamp chip. Coppermine and Tualatins use lower I/O voltage. I don't know if this is a real problem, there are mixed opinions. But your adapter also doesn't have jumpers for setting core voltage, and that would require additional mod not to fry the CPU.
I am using MS6905 Master slotket with voltage clamp chip. I insulated 3 pins in the socket: DYN_OE(AN3), RESET2#(AJ3), VttPWRGD(AK4). I connected VttPWRGD(AK4) on the CPU to VTT (AN11) with kynar wire. Similar mod should work with other slotkets which support Coppermine CPUs (they have that rectangural voltage clamp chip).
Here is some info about modding Mendocino slotket (like yours) for Coppermine, but I didn't try it: Re: Simple passive slotket on 694X dual cpu board for Coppermine/Tualatin?
Reply 13 of 20, by red-ray
adalbert wrote on 2020-11-15, 15:29:
Thank you for the info, I don't think I will bother as I have no real need to use it.
OK about the rebuild, good luck and do you plan to add the 2nd CPU as well?
Reply 14 of 20, by adalbert
red-ray wrote on 2020-11-15, 16:41:
Yes, i just hope I will get another slot adapter soon. I am now using SL5XL P3-S 1.4GHz, i have second SL6BY P3-S 1.4GHz, so that's a different stepping but the same speed and cache. I wonder if it will work, or would I have to buy another matching CPU. I found some Compaq Xeon server manual that said you need to put the CPU with lower stepping in first slot when there is a mismatch, don't know if it will always work.
Reply 15 of 20, by red-ray
adalbert wrote on 2020-11-15, 17:54:
The only way to know for sure is to try it. Have a look at Re: In an SMP system how does DOS/98 choose the CPU to utilise?, all of the Speeds, L2 Cache and Stepping are different!
Reply 16 of 20, by gex85
Yeah that should work. When I did this mod the last time for my Diamond C400, I used the Award BIOS Editor to replace the microcodes and it worked pretty well. Just used CBROM in the end to verify that it correctly detects all the microcodes.
I have attached a modded version of the S1834 BIOS version 1.05 where I included the microcodes for pretty much everything from early Pentium II all the way up to Tualatin. Maybe you want to give it a shot (use at your own risk, but if you have an external programmer, you should be OK in case something goes wrong).
1834v105-mod.zip
169.89 KiB
11 downloads
Tyan Tiger-133 (S1834) BIOS with Tualatin microcodes
Here's the output of CBROM v1.55 for this file (the mc-final.bin is my assembled collection of microcode updates):
C:\biosmod\CBROM155.EXE V1.55 [10/12/05 Release] (C)Phoenix Technologies 2001-2005
******** C:\biosmod\1834v105\1834v105-mod.bin BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
========================================1381Bh(78.03K)==1834W105.BIN============
0. System BIOS 20000h(128.00K)
1. XGROUP CODE 09D30h(39.30K) 068A3h(26.16K) awardext.rom
2. CPU micro code 13000h(76.00K) 0A1BBh(40.43K) mc-final.bin
3. ACPI table 026FBh(9.75K) 00F50h(3.83K) ACPITBL.BIN
5. YGROUP ROM 02760h(9.84K) 01B74h(6.86K) awardeyt.rom
Total compress code space = 36000h(216.00K)
Total compressed code size = 26FE7h(155.98K)
Remain compress code space = 0F019h(60.02K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
------------------| PPGA 04 06B0 | PPGA 1C 06B1 | PPGA 01 068A
SLOT1 13 0630 | PPGA 11 0681 | PPGA 14 0683 | PPGA 08 0686
SLOT1 0D 0681 | SLOT1 0C 0683 | SLOT1 20 0632 | SLOT1 34 0633
SLOT1 35 0634 | SLOT1 32 0650 | SLOT1 30 0651 | SLOT1 14 0652
SLOT1 01 0653 | SLOT1 04 0660 | SLOT1 06 0670 | SLOT1 03 0671
SLOT1 04 0672 | SLOT1 05 0673 | SLOT1 14 0680 | PPGA 10 0683
PPGA 01 06B4 | SLOT1 2A 0652 | SLOT1 0A 0660 | SLOT1 0E 0673
SLOT1 40 0650 | SLOT1 40 0651 | SLOT1 10 0653 | PPGA 03 0665
SLOT1 10 0672 | SLOT1 07 0686 | SLOT1 02 1632 | SLOT1 32 0633
SLOT1 33 0634 | SLOT1 27 0650 | SLOT1 29 0651 |
Here's the output for the original v1.05 BIOS file, still having the CPUCODE.BIN microcode file, which is only half the size of the updated mc-final.bin:
******** C:\biosmod\1834v105\1834v105.bin BIOS component ********
========================================13812h(78.02K)==1834W105.BIN============
2. CPU micro code 09000h(36.00K) 05163h(20.35K) CPUCODE.BIN
Total compressed code size = 21F86h(135.88K)
Remain compress code space = 1407Ah(80.12K)
------------------| PPGA 11 0681 | PPGA 10 0683 | PPGA 03 0665
SLOT1 20 0632 | SLOT1 34 0633 | SLOT1 35 0634 | SLOT1 40 0650
SLOT1 40 0651 | SLOT1 2A 0652 | SLOT1 10 0653 | SLOT1 0A 0660
SLOT1 06 0670 | SLOT1 03 0671 | SLOT1 10 0672 | SLOT1 0E 0673
SLOT1 14 0680 | SLOT1 0D 0681 | SLOT1 0C 0683 |
Reply 17 of 20, by adalbert
gex85 wrote on 2020-11-16, 10:40:
1834v105-mod.zip
Thanks 😀 unfortunately it didn't boot with that BIOS, I got checksum error and beeping (but that's no problem since TL866II is sitting right next to me). I had exact the same error when I was using Award BIOS editor. It looks like any changes in Award BIOS editor cause checksum error, but i'm not able to recalculate the checksum with that software.
BUT i extracted your microcodes to CPUCODE.bin and installed it into original BIOS file using CBROM software:
cbrom 1834v105.bin /cpucode release.
cbrom 1834v105.bin /cpucode CPUCODE.BIN
I used this tutorial http://www.geocities.ws/tuacubx/reads/MBMG.htm
I attach fixed file. It works, but doesn't fix wrong multiplier 😀
1834V105microcodes-fix.zip
169.91 KiB
8 downloads
Multiplier is OK with BIOS patched by Bios patcher 4.23, it also recognized Tualatin CPU, but I looked inside generated file and it has typos in CPU identification like Pentium 2 Deshutes, I also don't like the fact that it modifies boot screen message. I will try to fix that with hex editor, test it and upload it here. I also noticed that it doesn't show the number of CPUs, so I wonder if it will correctly recognize both CPUs when I install second one.
I'm still waiting for my power supply to arrive so I can install CD drive and reinstall the OS (i have only one molex now), then I will test SIV32X
Reply 18 of 20, by red-ray
adalbert wrote on 2020-11-17, 20:20:
I am not surprised. Looking at Menu->Hardware->BIOS Tables->BIOS Tables the only µCode was for Intel (Klamath) [A0], so not even for Coppermine CPUs. I wonder what will get reported for the new BIOS.
To fix the ratio the code that interprets MSR 0x0000002A would need to change, the change is simple enough, but I suspect patching it into the BIOS would be tricky.
mult[3:0] come from MSR 0x0000002A[25:22] and for ( model >= 8 && stepping >= 3 ) || ( model >= 11 ) then mult [4] needs to be set from MSR 0x0000002A[27]. I expect there is also a 16 entry table that converts the raw value to the multiplier that will need to be extended to have 2 x 32 entry ones as below.
Ratio Tables and Sample Code
static CONST  BYTE p3c_ratios[ 32 ] =                               // P-3 Coppermine Ratios
10, 6, 8, 4, 11, 7, 9, 5, // multipliers x 2
7, 14, 16, 12, 4, 15, 3, 13, //
18, 22, 24, 4, 19, 23, 17, 5, // Coppermine 83
7, 14, 16, 20, 4, 15, 3, 21 // and later only
static CONST BYTE p3t_ratios[ 32 ] = // P-3 Tualatin Ratios
24, 7, 7, 8, 11, 7, 23, 7, // multipliers x 2
32, 14, 16, 12, 8, 15, 7, 13, //
18, 22, 24, 32, 19, 23, 17, 7, //
7, 7, 26, 20, 28, 7, 30, 21 //
LONG cpu_mul_p32( // get CPU Multiplier for P-2 + P-3
ULONG msr, // raw MSR value
CONST CPUB *cpu ) // CPU Context
{ ULONG val; // working value
val = ( msr >> 22 ) & 0x0F; // get the ratio
if( ( cpu->xmodel >= 0x08 ) && // CPU a Coppermine and
( cpu->stepping >= 0x03 ) ) // newer Coppermine ?
val |= ( msr >> 23 ) & 0x10; // yes, merge in the extra bit
return p3c_ratios[ val ]; // return the scaled ratio
LONG cpu_mul_p3t( // get CPU Multiplier for P-3 Tualatin
return p3t_ratios[ ( ( msr >> 22 ) & 0x0F ) | // return the scaled ratio
( ( msr >> 23 ) & 0x10 ) ]; //
Reply 19 of 20, by adalbert
All right, so gex85's microcodes work fine with Tualatin, but after I installed Dual P3-Katmai 450 PC unfortunately froze on POST screen (before memory count).
I decided to use BIOS patched with BP 4.23. Looks like it doesn't modify original BIOS contents (except microcode), but adds another module which bypassess some settings? Anyway, I removed some stuff that I didn't like (custom BIOS message, typo in CPU name, disabled BIOS recovery mode, un-deleted CGA font, removed comma before CPU count because it is in wrong line now) and added TA suffix to BIOS version. I got 1GB of memory with 2x512MB right now.
Here is updated BIOS file:
1834v105TA_mod1.zip
152.5 KiB
11 downloads
POST screen and sensors page:
542.74 KiB
I still couldn't get USB to work in current Windows 7 install and have no time to reinstall, but I just installed PCI network card, so I can easily share the files and we are back in the game 😀 I downloaded SIV32X Tyan-01 tool and ran it with current modded BIOS. Main window screenshot:
43.27 KiB
This is how SMBus looks like with fan plugged and unplugged (i have a tiny 486 heatsink and fast fan right now, so it gets hot very fast):
94.07 KiB
and full log dump:
tyan-siv181120a.zip
196.84 KiB
10 downloads
