Reply 140 of 169, by hard1k
Arrived:
1.36 MiB
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 142 of 169, by hard1k
Thank you! 😀
AWE64 Legacy
Reply 143 of 169, by Meatball
While testing a Vortex 2 today, I came across the dreaded secondary PCI bus warning on an Intel D815EEA (Easton) motherboard. The Vortex 2 was plugged into the very last PCI slot of the board. It could be other 815 (Solano) chipsets experience the same, as well.
I'm just putting this out there in case someone else is able to help given the likely larger install base (I don't have a YMF744).
Reply 144 of 169, by hard1k
Yes, we get the same warning due to the PCI-PCI bridge, there is a patch for that.
AWE64 Legacy
Reply 145 of 169, by hard1k
990.79 KiB
1.64 MiB
1.38 MiB
1.12 MiB
1.09 MiB
Tests coming soon.
AWE64 Legacy
Reply 147 of 169, by hard1k
Thank you 😀
AWE64 Legacy
Reply 148 of 169, by Duffman
I have a YMF744 sound card in an external enclosure over a PCIe-to-PCI bridge (made by sintech).
I can do some testing with it if you think it might help.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 149 of 169, by hard1k
Yes, please! Could you test its MIDI Out functionality?
AWE64 Legacy
Reply 150 of 169, by Duffman
I ran the DirectMusic tests through DXdiag on Win98SE and all the MIDI devices listed there played back music properly.
Sound in windows works too.
Something that doesn't work properly is both FM Synth and DOS soundFX in Win98SE.
FM Synth doesn't work at all, says 'Could not Detect FM chip' with Blood setup.
SoundFX will play but are slow and stuttery.
No sound in proper MS-DOS mode at all, but sound in win98SE itself is working at least.
Regarding my PCIe to PCI bridge it's ID is
PCI\VEN_104C&DEV_8240
It's a XIO2001 Texas Instruments PCI Express-to-PCI Bridge
I think DOS sound doesn't work properly because this bridge chip doesn't support 'Subtractive Decode' but I could be wrong.
CPU: Ryzen 9 5950X
Reply 151 of 169, by hard1k
Ok, you say it played back through all listed MIDI devices, do you have any external MIDI synth connected to the soundcard's gameport? If not, please check that you have external synth selected in the Yamaha control applet, so that you choose that MIDI out and no sound comes out.
AWE64 Legacy
Reply 152 of 169, by Duffman
Yeah, if I choose external synth I don't get any MIDI since there isn't anything connected to the gameport.
I suspect that the gameport in non functional though despite Win98SE reporting it as OK.
If I boot into XP and look at the gameport it says it cannot find enough resources for the gameport, and assigning resources manually does not help it start. It's probably the lack of 'subtractive decode' but again it's only just a theory at the moment.
CPU: Ryzen 9 5950X
Reply 153 of 169, by hard1k
Ok, so you don't get any sound but the MIDI player runs just fine, pretending to be playing something, right?
AWE64 Legacy
Reply 154 of 169, by Duffman
Yeah.
CPU: Ryzen 9 5950X
Reply 155 of 169, by hard1k
Thanks a lot! That discards one of our hypotheses.
AWE64 Legacy
Reply 156 of 169, by Duffman
Are you aiming at making this as a PCI or PCIe card? or both?
CPU: Ryzen 9 5950X
Reply 157 of 169, by hard1k
No, it will be regular PCI only. If anyone is interested in taking on the project for any further development once we release it, please PM me and we'll see.
AWE64 Legacy
Reply 159 of 169, by hard1k
Good eye there 😉
Thanks for asking, I actually hoped to get this request.
As the vast majority of users will be using it in 5V slots, we decided to key it as such, as another protection against wrong placement (as main chips, components, and headers may actually inspire such wrong placement).
However we did not change anything related in the schematics, even more, we left the 3.3V key without the metal latches, giving a hint for all of you who have carefully watched our project 😉
AWE64 Legacy
