First post, by tegrady
So, I broke one of the plastic clips on the mounting bracket for the stock Intel Socket 478 heatsink. Therefore, I need a new cooler. I really don't like the stock heatsink mounting design as I find it difficult to install and remove, and the plastic parts are fragile.
I went on eBay and found this cooler. It's a Foxconn CRSBW model 342291-001. Instead of the plastic clips, it has 4 screws.
Does anyone know if this screws directly into the motherboard, or is there some kind of retention bracket that I need for it?
Thanks.
    104.35 KiB
    60.99 KiB
Reply 2 of 13, by tegrady
I did a search on eBay, Amazon and Aliexpress. I only found 1 socket 478 retention backplate for sale, and it was a bit expensive ($9). There are tons of Socket 775 and newer backplates for sale though that are under $3. Do you know a site that is selling Socket 478 retention backplates for cheap (under $5) or in bulk? If not, I guess I will bit the bullet and buy the expensive one I found.
Thanks.
Reply 4 of 13, by tegrady
PC Hoarder Patrol wrote on 2020-11-27, 23:28:
Backplates seem to be much cheaper in my area - would it not be simpler to replace the whole bracket / backplate assembly as these seem cheaper from China?
The only back plate and bracket I saw for sale is the clip type. I want to avoid the clip type bracket and back plate and go with the screw type. As far as can tell, the screw type uses only the heatsink and backplate. I don't think there is a bracket for the screw type. If I am wrong, please let me know.
I've only seen 1 screw type backplate for socket 478 for sale.
If you know where I can find the screw type backplate for sale for cheap from China, or anywhere else, please share the link.
This is a picture of the screw-type backplate I found. The screw-type cooler I found is pictured in my earlier post. Is there a bracket that goes with this?
Thanks.
    82.28 KiB
Reply 5 of 13, by PC Hoarder Patrol
Maybe take a step back, as on checking that heatsink appears to be designed for 533MHz Prestonia / Gallatin Xeon processors for the HP / Compaq xw6000 workstation, rather than skt478 (did you see a compatibility list that said otherwise?)
Reply 6 of 13, by tegrady
PC Hoarder Patrol wrote on 2020-11-28, 00:49:
The eBay listing says it is for Socket 478. Is the eBay listing incorrect? It is Foxconn part number 342291-001.
Reply 7 of 13, by PC Hoarder Patrol
Think the listing is wrong - these are designed for 1st generation skt 603 / 604 boards like those in the xw4000 & dual processor xw6000 workstations
https://translate.google.co.uk/translate?sl=a … 25BChler-xw6000
65.87 KiB
Reply 8 of 13, by cyclone3d
Take a look here for some cooler models to look for:
https://web.archive.org/web/20171219223212/ht … eid=1576&page=5
You can also do a Google search for:
Socket 478 heatpipe
That should point you in the right direction as well.
Should be much easier to find a good cooler with the model numbers.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 9 of 13, by Almoststew1990
I've been faffing with 478 coolers today and to be honest I'm surprised some entrepreneuring retro gamer hasn't 3D printed a bunch of Socket 478 sized backplates that have the ubiquitous 939/754(?)/AM2/AM3/FM1/FM2 mount-y hook system. so you can use any AMD heatsink on 478.
I'd buy one! I'd (terribly) design one if I had a 3D printer!
Reply 11 of 13, by PC Hoarder Patrol
OP seems to be looking for one with a custom retention system, so something like this (not mine!)
https://www.ebay.com/itm/Zalman-92mm-original … nk/224244337129
EDIT: "That still uses the stock motherboard mounting system though."
My bad 🙁 thxs @cyclone3d
Reply 12 of 13, by cyclone3d
PC Hoarder Patrol wrote on 2020-11-28, 20:30:
Yamaha YMF7x4 Guide
Reply 13 of 13, by cyclone3d
Almoststew1990 wrote on 2020-11-28, 14:03:
There were some aftermarket coolers like this if I remember correctly.
Yamaha YMF7x4 Guide
