help with soundcard
Reply 22 of 41, by ragefury32
scroeffie wrote on 2020-12-10, 16:19:
any one nobody
I am not sure what you are asking for here - to wit:
A) What kind of soundcard, which system is it in? Which OS are you asking about?
B) What configuration settings are in the autoexec.bat (if assuming DOS)
B) IRQ 6 isn’t commonly used. Why is it on 6 (if it’s even possible on 6)
C) DMA5 is a 16 bit DMA channel - also not that usual. Are you sure whatever program you are working with isn’t automatically requiring an 8 bit DMA to send commands? If it is, then assuming 1 or 3 for DRQ (DMA request)i is perfectly fine.
Reply 23 of 41, by Jorpho
The messages are more confusing than they need to be.
Your sound card is configured as:
A220 I5 D1 H5
That means you cannot use IRQ 5 or DMA channels 1 and 5 for your CD-ROM and you need to set the jumpers accordingly.
In your config.sys, you have:
/P:300 A:0 /M:2 /T:1 /I:5
So it looks like /T corresponds to the DRQ, which is actually set by the DMA jumper on the card. When you set up the driver, you need to specify the value according to whatever the jumper is set to.
Reply 24 of 41, by scroeffie
386 /soundblaster 16 is working
the cd rom drive is not there is no drive letter D:
Reply 27 of 41, by Jorpho
Posting the same pictures over and over again isn't going to get you help any faster, you know. In fact, it just makes things more confusing. We don't have much more information than you do.
Your last image says:
/P:300 A:0 /M:2 /T:3 /I:5
That suggests you are still specifying IRQ 5 in the Setup program, but like I said in the last message, your sound card is using IRQ 5 and the jumper on your card is set to IRQ 9.
Reply 29 of 41, by scroeffie
some one said to me to use dma 3 and irq 10 but there is not dma 3 jumper setting on the cd rom card and also in the software i cannot choose irq 10 but the manual says there is
what am i missing here ?
Reply 32 of 41, by scroeffie
Iam going to begin fresh wil post pics so you guys can see this is the intall programm
Reply 33 of 41, by scroeffie
oke i found out iam installing the wrong drivers ,the controller card i have is the latest model and i need these drivers
if any one has these please share thanks to all the people that helpt me
MTMCDE.SYS
Reply 34 of 41, by fitzpatr
As listed above, you need to tell the driver which settings that you have configured on the card.
If the last pictures are accurate, you are jumpered to IRQ 10, and DMA 6.
THESE VALUES MUST MATCH WHAT YOU PUT IN THE SOFTWARE.
https://www.ibm-pc.se/drivers/cdrom/MITSUMI/MITSUMI.ZIP
I think that this link has the newest drivers. You probably need them to allow Higher DMA channels.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 36 of 41, by Jorpho
scroeffie wrote on 2020-12-10, 19:07:
Those pictures look exactly the same as the ones you posted before. How is this supposed to help anyone? You are only making things confusing. Please slow down and take a minute to think about what you are posting.
Reply 37 of 41, by scroeffie
i found the new drivers but they dont want to install
o formated the hdd again installed dos 6.22,and i want to install the sounblaster 16 again but dont know how any more
than i want to install the mistumi cd rom drive but it wont let me
    549.03 KiB
Reply 38 of 41, by scroeffie
also the sounblaster 16 witch drivers do i need
sbbasic.exe
Download File
ctcmbbs.exe
Download File
    440.09 KiB
    183.77 KiB
