First post, by sergio27ru
Hello all! I've got a problem with es1688+es968+qs700: esfm work well 220/5/1/330, but onboard wavetable doesn't work by any settings\jumpers configuration, also dosn't work external wavetable. I'm think - that needed software activation programm (or card is dead). Does somebody have an expirience with this cards and mpu? please help!
    1.99 MiB
    KLZ1105 Multiwave Innovation Pte Sound Card
Reply 1 of 40, by appiah4
Have you checked to make sure that the Synth is not muted with the DOS mixer? Use ESSVOL.EXE to check, and adjust if necessary.
Reply 2 of 40, by sergio27ru
appiah4 wrote on 2020-12-21, 07:46:
Yes, of course, the values are fine.
Reply 3 of 40, by cyclone3d
I am pretty sure that that card needs something besides the standard ESS1688 driver for the wavetable t work.
I'll check what I have maybe this evening since I should have a copy of that card but not sure if I have the correct driver saved for it or not.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 40, by badmojo
sergio27ru wrote on 2020-12-21, 15:33:
Are you sure you're sure? ESSVOL has wavetable under 'aux' from memory so it's not obvious, and it's muted by default.
Reply 5 of 40, by sergio27ru
badmojo wrote on 2020-12-21, 21:13:
Yes, im sure, fixed levels a lot of times. Will be wait for answer from cyclone3d, otherwice - probably card is not in work condition...
PS: now looking for simple es1688 cards for checking mpu port
Reply 8 of 40, by sergio27ru
1541 wrote on 2020-12-24, 06:33:
Would you mind posting your whole ESSVOL.EXE command here for reference?
I once had a similar issue with a ES1868.
Im using 2 diferent versions of ESSVOL.EXE with comand line: C:\ESSUTIL\ESSVOL.EXE /V:8 /L:8 /W:8 /M:0 /C:8 /S:8 /A:8 and SETVOL.EXE with graphic interface, volumes are adjusting ok, checked with Doom and/or DOSMID.EXE player
Reply 9 of 40, by sergio27ru
Wolfus wrote on 2020-12-24, 08:57:
How did you test it? Some games reset mixer values and default value for AUX is 0.
I'm usually check the current level with a simple run ESSVOL.EXE and it shows the current level
Reply 10 of 40, by appiah4
OK, if you are *that* sure then the wavetable probably needs another utility to initialize..
The problem is that I have no idea what that sound card or wavetable actually is. Googling the model name results in hits for two different cards, which may well be the same thing:
MEDIAWAVE MW-0203151
MultiWave Innovation
FCC ID search also gets a hit for MultiWave Innovation.
A google search leads to this obscure page which appears to be a mirror of their archaic web site, and at the bottom you can find some driver links but they are all gone.
http://3430.online.fr/computing/multiwave%20d … vers%20list.htm
But if you check the links they all refer to www.multiwave.com, so do an archive.org search for that:
https://web.archive.org/web/20000815200454fw_ … rt/download.htm
And if you check the ESS Download area:
https://web.archive.org/web/20000817024044fw_ … dio_support.htm
The DOS download package for the 32 PnP card is significantly larger.. So download that:
https://web.archive.org/web/20001016100541/ht … np_3ddoscfg.exe
Aaand.. no, it's not archived 🙁
Reply 11 of 40, by darry
cyclone3d has (or had) a very similar card Re: Bought these (retro) hardware today . If there is an initialization utility (if one exists), he may have it or he might be able to confirm that none is necessary .
An Opti based card with similar wavetable chip, owned by dionb, was likely defective . See MediaMagic ISP32 (OPTi930A+QS700) - wavetable drivers etc cyclone3d has/had one of those as well and, if I understand correctly, it used bog standard Opti drivers for init .
At this point, my guess is that QDSP QS700 wavetable cards are always implemented with a micro-controller and initialization code in a ROM chip, so an external init utility does not exist for them because it is not needed . If I am right, this would point to your card being defective or, if very lucky, maybe having improper jumper settings .
Reply 12 of 40, by sergio27ru
darry wrote on 2020-12-25, 17:56:
yessss.....im think the same... need some days to check\found another one es1688 and motherboards
Reply 13 of 40, by sergio27ru
Checked al my cards, not one with es1688/698... But, I rechecked this card on other pentium1 and 486 motherboards. I don't understand anything, 1st test stand was a tomato board 5dhx-512k and all that happened you read before, as I wrote - board started, sound in windows/dos - exist, but another 2 boards didn't start! Very strange motherboard fault!?
Reply 14 of 40, by sergio27ru
So, some days are passed 😉 unfortunately im still do not found es1688/698 card, but i have Sound Vision Gold-16 with es688 onboard chip. I found photos in inet where exactly same card but with es1688 and without Yamaha\clone OPL chips. I decided upgrade this card and check swapped MultiWave's es1688 chip. ....Tadam!!!!!
noooo. Same result: card is work well with essfm, but on the external wave table connector+ doughterboard (ofcourse checked all IRQ,DMA.Ports 300/330) - same - quiet MIDI clicks. Probably chip is dead...
Ok, that is result, not fantastic, but result. Next step: i found cheep notebook's compact card with es1688 chip, and swap it again - and again same: card is work well, but MPU doesnt work.
At this point I have a question: does anyone have Gold-16/es1688 sound card with doughterboard? Does it work well? Could you please send exactly your's autoexec/config lines?
    197.34 KiB
    es688 card before exchange chip to es1688
    132.4 KiB
    es1688's donor
    1.96 MiB
    es688 to es1688 swapping result
Reply 15 of 40, by appiah4
I have an ES688 card, and yes it works quite well. I use it with the TSR from the Edison Gold-16 drivers in my 386SX, along with a Pi-32. I do not have access to that PC at the moment but I will be able to play around with it on the weekend.
This is the card I have in there. The jumper setup should be the same as in the photo.
543.9 KiB
I also have an ES1868 in a Socket 7 PC that works perfectly fine with usual ES1868 initialization tools, no TSR needed. ES1688 should have been the same.
This many cards not working in a single PC in the same exact way leads me to believe the issue lies elsewhere. The MPU401 is usually defaulted to IRQ2/9, can you check and make sure that another card in your system is not using that interrupt? It might be a non-PnP card, or the BIOS may be misbehaving.
Reply 16 of 40, by sergio27ru
appiah4 - are you sure that yours es688 play MIDIs through MPU port 300 or 330? Maybe you hear esfm by 220 port? Im doubt because a lot of people tell me, that es688 do not have native MPU support and no one cants use doughterboards. One more - if im wrong - send me please drivers with TSR. Thank you.
IRQ - ok, thx, i'l recheck later.
Reply 17 of 40, by appiah4
sergio27ru wrote on 2021-04-21, 11:48:
I am 100% positive it is MIDI through port 330.
I uploaded the ES688 driver disks that include the MPU401 enabling TSR to vogonsdrivers in the past.
http://vogonsdrivers.com/getfile.php?fileid=1461
Reply 18 of 40, by sergio27ru
Thx, yes, i have the same drivers in my system, TSR - is a ENMPU.exe? And yes, TSR is working, mpu port is visible in dosmidi player but no sound. If im disable ENMPU.exe - no MPU device is founded by player. So, i found another one es688 card, also known like miss melody audio drive-es688 (photo in attach). Enmpu show that port/irq are Ok, but no MPU device is founded by player (esfm- Ok).
    45.03 KiB
    essvol
    56.24 KiB
    autoexec.bat
    73.85 KiB
    midi player/gold16+es1688
    75.64 KiB
    enmpu load
    60.3 KiB
    miss melody
Reply 19 of 40, by appiah4
OK, just to make sure.. You actually have a wavetable daughterboard connected to the card, right?
