Tyan Titan-Pro AT/ aka S1662
Reply 20 of 34, by Nexxen
red-ray wrote on 2021-01-03, 14:34:
Is W2K SP4 now running OK, did you install http://www.catalog.update.microsoft.com/Search.aspx?q=891861 ?
Had to restart with another HD, hanging at user and password and couldn't finish installation
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 22 of 34, by Nexxen
maxtherabbit wrote on 2021-01-03, 16:01:
If you can get the memory total up to 512MB I'd heartily recommend XP SP3, that's what I run on my PPro dually. But 256MB is a bit anemic for XP
I don't have 64MB ram sticks.
Only 32 and one proved faulty, I'm on 190MB...
Now it won't go past credentials and freeze.
Boots into safe mode. Headache
Reply 23 of 34, by Nexxen
At least SIV works in safe mode.
What do you want me to do?
I'm here with the pc on at my side.
Edit: It's a bit oa chore without mouse.
I'll swithc back to NT4.
Edit 2: ISA VGA saved the day. Prolly a bad contact on the PCI card. One of the ram socket was broken on a side.
Reply 24 of 34, by red-ray
Nexxen wrote on 2021-01-03, 16:24:
At least SIV works in safe mode. What do you want me to do?
Thank you for checking it out, but I am wondering if the SIV driver will start in Safe Mode, what does Menu->Windows->Services->Control SIV report?
I would like the two files generated by doing Menu->File->Save Local ideally with the SIV driver running. I would prefer NT4 with SIV Driver running to W2K without it.
The .DMI file is a binary dump of the raw data that the [Machine] panel reports, when I have it SIV runs better in test mode and I am often able to use it to improve what SIV reports for elderly systems.
I wonder if SIV will report it, which card is it? I managed to make it report my ISA Kelvin64 so if it doesn't I suspect I will be able to adjust it.
Reply 25 of 34, by Nexxen
red-ray wrote on 2021-01-03, 17:02:
Thank you for checking it out, but I am wondering if the SIV driver will start in Safe Mode, what does Menu->Windows->Services-> […]
Changed video card now works in 2k normally
Reply 26 of 34, by Nexxen
I used a Trio64v+, but ram socket are broken, upgraded from 1024 to 2048 but probably some pin aren't making contact naymore and as it reaches a certain area it fails.
ISA card is RTVGA_V2_91024_B - Realtek
Reply 27 of 34, by Nexxen
I'll post a few pics of the menu.
The thing works.
Graphics sucks tho...
I've seen in other pics that you have a menu, arrow on the right side (scroll menu), the arrow doesn't show in VGA, have to click on it o show menu
Reply 28 of 34, by red-ray
In general you can Right/Click to get a menu including from the Tray Icon
file.php?id=99526
    136.17 KiB
Reply 30 of 34, by red-ray
Nexxen wrote on 2021-01-03, 18:10:
I'll try another time but it keeps rebooting at some point.
If you look at the last line of the .TXT file that should be the section being processed when there was the issue. You can skip that section by doing Menu->File->Save->Save Selected and deselecting that section before pressing [ Start ].
Reply 31 of 34, by Nexxen
red-ray wrote on 2021-01-03, 18:21:
I'm giving a last go with nt4. If it works ok otherwise I'm calling it.
    s.7z
    59.98 KiB
    30 downloads
Reply 32 of 34, by OzzFan
Nice build. I have a similar system with an Intel 440FX board running 2 Pentium II Overdrives, 512MB RAM and NT 4.0 SP6a and is currently my legacy file server and PDC for my Win3.x/OS/2/DOS systems. The thing runs like a champ!
A (mostly accurate) listing of my computer systems: http://www.shelteringoak.com/OzzNet/
Reply 33 of 34, by red-ray
Nexxen wrote on 2021-01-03, 18:23:
Thank you, please deselect [gpu-dump] and see if it get's any further
Reply 34 of 34, by Nexxen
OzzFan wrote on 2021-01-03, 18:33:
Nice build indeed but gonna store it until I get my hands on a cool case.
