Reply 81 of 96, by jnemo2004
Hello, I would like to find information about this motherboard. I need to find the BIOS images. Thank you very much
    86.41 KiB
Reply 83 of 96, by jnemo2004
There is a similar Motherboard with same chips (https://theretroweb.com/motherboards/s/tk-tk8 … d03-01#expchips) , but the BIOS image is only one for a 512 Kb EPROM. The motherboard I bought, has two sockets, probably to use two 256kb EPROMs. Can I use the EPROM of 512kb alone in the first socket?
Reply 84 of 96, by weedeewee
jnemo2004 wrote on 2023-11-18, 13:51:
you will need to split the bios image into two files, one for the odd bytes, and one for the even bytes.
one program to do this is Romwak https://github.com/freem/romwak/releases/tag/0.3c
romwak /b <infile> <outfile1> <outfile2>
Do not ask Why !
Reply 86 of 96, by Poi3212
Hello. I found this socket 7 board without any RAM or CPU. A sticker on the case indicates it originally came with a 100MHz Pentium. A sticker on the lowest ISA slot indicates 1995 manufacture date. The blue + white sticker near the cache has a pufferfish, which might indicate the manufacturer.
    1.29 MiB
Reply 87 of 96, by pvlst
Poi3212 wrote on 2023-12-30, 04:48:
Seems to be Amptron PM-7500.
Reply 89 of 96, by jnemo2004
Dear Sirs, I need your help to find the manual of the following motherboard:
Thank you very much
    153.09 KiB
    123.53 KiB
    60.96 KiB
    34.93 KiB
Reply 90 of 96, by analog_programmer
Can someone confirm that this is AOpen AP4 motherboard since there are no actual pictures for the board on theretroweb? The chipset is SiS 85C496/85C497.
    151.91 KiB
    486 socket 3 PCI
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 91 of 96, by PcBytes
It is, and someone seems to have one with populated cache as well, according to this link.
Reply 92 of 96, by analog_programmer
PcBytes wrote on 2024-01-12, 13:39:
Thank you. I'll read all the information from the given link later. As for the missing cache chips... first I have to get the board working - there are broken traces on the back and one PCI slot with broken plastics, not even counting the broken lever on the socket. So far it's one very broken board in need of repair 😀
Reply 93 of 96, by W.x.
Don't have another photos
Tried with this search (1 3.3 AGP, 3 PCI, 1 ISA, microatx socket 370)
https://theretroweb.com/motherboards/?page=1& … %5D%5Bsign%5D==
(edit: tried with Universal AGP, as it is covered just about the notch, and found almost identical motherboard FIC FA31)
https://theretroweb.com/motherboards/s/fic-fa31
It has some differences thought.
    248.67 KiB
    GPL-2.0-or-later
    244.96 KiB
Reply 94 of 96, by PC Hoarder Patrol
W.x. wrote on 2024-01-23, 22:56:
Don't have another photos […]
It's the FA31 (says it on one of the white stickers in line with the ISA slot!)
Reply 96 of 96, by superswami
Hello all, I'm trying to sort out the various jumpers on a PC Chips M601 VLB 486 mainboard - specifically version 1.0 - I've been able to find jumper info on the other variations 1.2, 1.3, etc. but anything on 1.0 has been conspicuously absent. Given that it's PC Chips, it's possible it may have been marketed under a different name which might be why it seems so obscure. The 1.0 board seems to have more in common jumper-wise with the 1.3 board than the 1.2 as the locations are similar even though the jumper numbers don't match. The cmos battery header and jumper for selecting an external battery ( pin 1-2 disables charging if you're replacing the old VARTA battery with a standard lithium) were similar too.
There's also a mysterious SIP header next to one of the ISA slots right above the JP5-8 jumpers that I'd love to know more about as it didn't reappear in the later board revisions.
Version 1.3 - has documentation for reference.
https://theretroweb.com/motherboards/s/pcchip … 1-ver.-1.3#docs
Better pics of someone else's 1.0 board can be seen here:
https://theretroweb.com/motherboards/s/pcchips-m601-ver.-1.0
Currently the board reports a clock speed of 66MHz and 256k of cache
I've got 64MB (16MB x4) 30-pin SIMMs installed for RAM and my Genoa 8500VL gpu on the #3 VLB slot.
Jumpers 9-10 I assume control cache size and 13-15 might be the CPU select jumpers.. My best guess on JP 5-8 would be something to do with bus speed selection.
