First post, by awocrf
Can someone help me identify this card? I think it's sound blaster AWE32 CT2760 but I don't know if i'm correct.
    65.21 KiB
Reply 2 of 14, by ReadySelectStart
If it is, it will say. Certainly looks like it could be. I have the same card, it's great with proper OPL support. Not PnP which could be good or bad depending on your opinion. This is my CT2760: https://www.instagram.com/p/CKHUbNIhV6s/
Reply 5 of 14, by mkarcher
According to my favorite (not necessarily perfect) list of Sound Blaster model numbers, there are only two soundblaster models with SIMM slots (i.e. AWE32 or the like) and multiple CD connectors, the CT2760 and the CT3780. It is clearly not a CT3780. So this card is either the CT2760, or a rare item which might or might not have collector's value due to its rarity.
Reply 7 of 14, by fitzpatr
This is a CT2760 revision 039436. Sound Blaster AWE32.
The capacitor layout does not match a rev 019401.
    263.51 KiB
    Sound Blaster AWE32 CT2760 REv. 039436
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 8 of 14, by awocrf
Ok, so the card arrived. Seller just threw it into the box with other 25kg worth of motherboards, old phone PCBs etc. It has a few bent pins and a broken memory holder thingy (nothing unrepairable). I will test it when I'll have time to do that.
Reply 9 of 14, by Boohyaka
awocrf wrote on 2021-01-27, 22:28:
(...) a broken memory holder thingy (nothing unrepairable)
Very, very common fault with those. My own AWE32 also had it, beyond "proper" repair. I'm just holding ram sticks with a couple cable ties around the whole card, does the job fine, not like I'm switching ram anyway.
Reply 10 of 14, by darry
Boohyaka wrote on 2021-01-27, 22:55:
That worked for me too when I was using a CT3670 .
Reply 11 of 14, by awocrf
After fighting with 2 CD drives (1st not reading, 2nd not opening), sometimes working PS/2 keyboard, pendrive not working I was finally able to install drivers for this card. Didn't test it yet but it shows up in device manager as something similar to "sound blaster 16 or AWE32" (don't remember).
Reply 14 of 14, by Doornkaat
awocrf wrote on 2021-01-18, 09:09:
Can someone help me [...]? I think [...] but I don't know if i'm correct.
awocrf wrote on 2021-01-18, 10:19:
Sorry, but I can't[...].
awocrf wrote on 2021-02-05, 18:06:
After fighting with 2 CD drives (1st not reading, 2nd not opening), sometimes working PS/2 keyboard, pendrive not working[...]
awocrf wrote on 2021-02-05, 22:27:
[...]couple more issues with hardware and software.
awocrf wrote on 2021-02-06, 12:41:
Aaaand... dead hard drive. Windows doesn't want to start, 3x clicking sound, delay and again 3x clicking sound. Bad sectors in scandisk.
I would like to extend a warm welcome to awocrf! It's a wonderful hobby we're sharing and I believe everyone on this grief counseing platform computer enthusiast forum can relate deeply to your experience. 😅
Spoiler
Just in case: This is not a dis, I mean it.
