Reply 20 of 21, by lowlytech
Horun wrote on 2021-01-24, 02:50:darry wrote on 2021-01-24, 02:09:lowlytech wrote on 2021-01-24, 01:40:Wow, thank you so much Darry for all the bios patches and links. Yes this card has an svideo out i suppose would be nice to keep accessable. The chip is a conexant which has a sub id of bt869, so brooktree would be the correct one probably.
Thanks again for all the input and help with this card. A wonderful community and resource for sure. And yes the power strip util does report 200mhz for the core clock.
Happy to help .
Here is a modified version based on GF3BT.ROM (for Brooktree/Conexant) gf3(new)_bt_patched.zip
Thanks ! I actually think have the same card (assuming OP has 180-p0050-0000-a09 silk screened on his) mine is a Visiontek 64MB from a Dell with bios 3.20.00.10.03, all green with same chips, same fan, same missing DVI port.
Yep, that is the exact part number that is on this card. Never knew where it originally came from, I think I got it with a motherboard purchase a few years ago. Good to know where it originated from.
