First post, by Sphere478
anyone know the pinout of the irda port?
https://stason.org/TULARC/pc/motherboards/Q/Q … ium-P55XB2.html
    46.78 KiB
    19.74 KiB
Sphere's PCB projects.
Reply 1 of 2, by PC Hoarder Patrol
Manual is no help at all ("The IR (Infrared) port is a 7 pin pin-header connector, this connector is reserved for future use. ")
P55XB2.DOC
2.28 MiB
35 downloads
so it might be worth trying a similar header layout from their BD100 board
18.89 KiB
Reply 2 of 2, by Sphere478
PC Hoarder Patrol wrote on 2021-01-26, 05:25:
Manual is no help at all ("The IR (Infrared) port is a 7 pin pin-header connector, this connector is reserved for future use. ") […]
P55XB2.DOC
very nice. I bet that is probably it! if it's from the same mfg
this should work wit it then? 4mbps?
https://www.ebay.com/itm/IrDA-Infrared-FIR-4M … 675.c100623.m-1
