Reply 40 of 41, by Sphere478
- l33t++
avxstudios wrote on 2021-02-06, 22:24:I have a curious problem, wondering if any of you folks could chime in on it.
At the moment I have a PCI Matrox Millennium II in the Aiwa and that works fine, but I have a spare Radeon R7000 PCI (64mb) that I've tested on other systems, specifically a Asus CUSL2 with a Pentium III 800, and it works there, but when I install it on the Aiwa it does not turn on the monitor (no signal), and even if I connect the VGA output to an external monitor, nothing is displayed.
As I understand it cards such as this are slotted for both 3.3v and 5v as they're universal, the PCI slots in the Aiwa are 5v, Is there a particular reason why this would not work on the Aiwa? or any modification I can do to it, to make it work?
Best pci 2.1 non sse video card?
You’re not alone 🤣. 6200 seems to be a good one to try if you wanna grab a new one.
