First post, by RetroSpector78
I have 3 MX440 cards here that produce a wide range of performance in quake 3 (same drivers, same Athlon XP+ 1700 running Windows XP machine)
I've used Aida64 to mark down some metrics :
                VANV17L1PS MMX440SE             Prolink MX440-8x          No-name MX440-8x-03913
Bus AGP4x AGP8x AGP8x
GPU Clock 250MHz 274MHz 240MHz
Mem 64MB 128MB 64MB
MemType SDR DDR DDR
MemBus 128bit 128bit 64bit
RealClock 333MHz 256MHz 130MHz
EffectiveClock 333 MHz 513MHz 261MHz
Bandwidth 5328MB/s 8208MB/s 2088MB/s
Q3 1024 dem1. 42fps 158fps 70fps
Regarding the Q3 performance of the cards :
  • I would imagine the AGP4x bus would not be saturated on this system with these cards so that should not make a huge difference ?
  • Is the memory type (DDR) of the no-name card responsible for the 64bit card to have almost 2x the q3 performance (70fps vs 42fps) as the VANV17L1PS 128bit card ?
  • There is a huge jump between the 2 AGP 8x cards. That is purely related to the memory bus (64bit vs 128bit) and the memory clock speed ?
To what extend can you trust readings in Aida / GPU-z when it comes to memory bus , memory type ..... ? Is there a better / other way to retrieve that information ?
I sometimes go to TechPowerUp / GPUZoo but sometimes there is also conflicting information as I guess each card vendor can pretty much do what they want with regards to memory and gpu clock speeds ?
Reply 1 of 15, by lost77
I have not found any software that can reliably differentiate between memory bus widths.
With that said you should test your cards again, especially the MX 440SE looks wrong. Try running powerstrip after installation and make sure AGP is working correctly (DiME transfers). Also force Vsync off and re-apply Quake III settings after launching it with a new card.
Reply 4 of 15, by RetroSpector78
lost77 wrote on 2021-02-13, 17:51:
Before running benchmarks I typically turn vSync turned off in the nvidia panel (as I have noticed that swapping cards turns if back to "application controlled"
So it is turned off, and I do see the q3 demoo01 go above 60fps (albeit rarely) during the run of the slowest MX440SE card.
However, It only seems to be with quake3 that I am seeing this performance hit ....
Also did the Unreal Tournament demo (getting 80-90 fps in the cityintro at 1024x768 on all 3 cards) and the Expendable benchmark (90+ fps at 1024x768 on all 3 cards)
So went to look for the quake 3 settings and noticed that Color Depth and Texture Detail were set to "Default".
I'm guessing "Default" here means whatever your windows display adapter is set to (16 bit or 32 bit colors).
I noticed that the MX440SE had its display settings set to 32bit. After I set it to 16 bit the fps moved from 42fps to 74fps.
So now I get :
  • MX440SE - GPU 250MHz - 64MB SDR 128bit @ 333MHz : 74fps
  • MX440 - GPU 230MHz - 64MB DDR 64bit @ 261MHz : 98fps
  • MX440 - GPU 274MHz - 128MB DDR 128bit @ 513MHz : 158fps
But still a bit gap don't you think between these 3 cards in Q3 ? (especially the one hitting 158fps). Don't understand why it's only in Q3.
Other interesting benchmarks I can try ? (I prefer to run game benchmarks)
Reply 5 of 15, by RetroSpector78
SPBHM wrote on 2021-02-13, 18:16:
SDR 333MHz is not a thing […]
AGP 4x vs 8x is irrelevant for this card
I would think riva tuner is reliable at detecting the card bus/memory
also check the memory chips, manually if in doubt.
Found some references to the 333MHz clock here :
http://www.vgamuseum.info/index.php/component … orce4-mx-440-se
And also saw it in PowerStrip.
Reply 6 of 15, by SPBHM
RetroSpector78 wrote on 2021-02-13, 21:52:
Found some references to the 333MHz clock here : http://www.vgamuseum.info/index.php/component … orce4-mx-440-se […]
check the memory chips and google the code to know what exactly is the ram installed if possible (and in general 8 chips = 128bits, 4 =64 with these cards) my guess is that it's actually a SDR card that it will end in -6 and run at 166MHz, and perhaps riva tuner will give you the right number, the link you posted shows a GPUz screenshot, I found that for old cards GPUz is at times giving bad readings (I think it gives twice the real memory bandwidth for my FX5900 also for example), so if it's based on that it could be wrong,
if your card actually had 5.2GB/s ram and the NV17 chip it wouldn't be that much slower than the other 2, so something is clearly wrong with that info
Reply 7 of 15, by Pierre32
Throwing in some data which might be interesting, or not. I previously posted about terrible results from my MX440 PCI in another topic of yours: Direct3D gaming with a PCI videocard on an AMD K6-2 platform on windows 98se
This weekend I've dropped it into a PIII rig, and now I'm seeing some performance (1987 vs 6223 in 3Dmark99). I've just grabbed the stats:
                No-name low profile MX440 PCI
Bus PCI
GPU Clock 146MHz
Mem 64MB
MemType DDR
MemBus 64bit
RealClock 79MHz
EffectiveClock 159MHz
Bandwidth 1272MB/s
Q3 1024 dem1. *
Pretty ordinary compared to any of yours!
Unfortunately I haven't been able to log FPS from the Q3 demo as it's not appearing in the console at the end. But I'm watching it fluctuate between 40-90 and would guess around 70 as an average. (I realise the differences in our systems make this comparison meaningless anyway).
Reply 8 of 15, by The Serpent Rider
RivaTuner.
timedemo 1
They've just copypasted this info from another wrong source. SDR SDRAM/SGRAM clocks officially never exceeded 250 Mhz on video cards. Some utilities "interpret" 128-bit SDR 166 Mhz memory as DDR 333 Mhz memory, because MX 440 officially never had SDR memory listed.
Reply 9 of 15, by Pierre32
The Serpent Rider wrote on 2021-02-14, 02:17:
timedemo 1
Thanks, had my procedure all wrong.
Pierre32 wrote on 2021-02-14, 00:33:
70.9 (arsey bastard!)
Reply 11 of 15, by Pierre32
RetroSpector78 wrote on 2021-02-14, 10:33:
Q3 timedemo ? On what CPU / resolution / card ?
Yep. PIII 1GHz, 1024x768, card:
289.57 KiB
285.74 KiB
Reply 12 of 15, by RetroSpector78
Pierre32 wrote on 2021-02-14, 10:55:
On my P3 550MHz with my Prolink MVGA-NV617GA MX440 (128bit with 128MB DDR mem) I am getting 59fps at 1024x768x16bit 😀
Weird thing however is that on all resolutions (640 x480, 800x600, 1024x768) and all color depths (16bit, 32bit) the timedemo always finishes with 59fps.
I do have vsync off and I can see during the demo that it goes way beyond 60fps from time to time. But on all resolutions it averages out at 59fps.
Reply 13 of 15, by RetroSpector78
SPBHM wrote on 2021-02-13, 23:46:
Looked up the part numbers :
  • VANV17L1PS MMX440SE : V-Data VDS6616A4A-6 : DDR Synchronous DRAM (1M X 16 Bit X 4 Banks)
  • Prolink MX440-8x : Samsung K4d28163hd-tc40 : "128mbit DDR SDRAM" (2M x 16Bit x 4 Banks)
  • No-name MX440-8x-03913 : V-Data VDD8616A8A-6B : Synchronous DRAM(1M X 16 Bit X 4 Banks)
Is it purely the amount of chips you have on the board that determine if you have a 64bit or 128bit bus ? (Because Samsung mentions it explicitly in their datasheet)
Would removing 4 of the chips in the Prolink turn it into a 64bit 64mb card ?
And does that mean that the ANV17L1PS MMX440SE that was detected as an 128 bit SDR card is in fact an 128 bit (8 chips) DDR (ram chip datasheet) card ?
Reply 14 of 15, by SPBHM
RetroSpector78 wrote on 2021-02-14, 17:06:
Looked up the part numbers : […]
VDS6616A4A-6 is SDRAM, not DDR
if the card has 8 chips that's 8x16bit chips and since it's SDRAM the "effective clock" is the real clock which is 166MHz, so the real bandwidth is 2.7GB/s
if you have 16bits chips which is typically the case with these cards AFAIK
yes, 4x16 = 64bits, 8x16 = 128bits
Reply 15 of 15, by vlask
SDR memories are not double clocked like DDR ones and some versions of GPUZ forgot about it. Thats why it shows 333MHz SDR memories, but in reality its only 166MHz. Thus also bandwidth is wrong and info on vgamuseum site too as owner of cards didn't realised, that its bug in GPUZ. You might try also HWinfo software for checking of cards. Btw dont think that anyone used SDR memory at clocks over 200MHz, so if its over this number, you can be sure that its detected like DDR and you need divide number by 2.
Not only mine graphics cards collection at http://www.vgamuseum.info
