First post, by galanopu
Hello everyone,
I made this little original device that plugs into a PCI slot.
I measures the PCI clock in real-time and with high accuracy.
Maximum measured frequency: 80MHz, Resolution: 10KHz.
I find this device very useful when I try to figure out and tweak Retro PC Systems.
I will have a few pieces of this professionally manufactured and available very soon.
https://www.youtube.com/watch?v=QmJi0tpL7kc
https://www.youtube.com/watch?v=syvaUgXfFzU
ISA / AT version Is also now available:
https://www.youtube.com/watch?v=1R9ZLLG1g5Q
What do you think about this?
    232.55 KiB
Let's mod everything! Check my youtube channel:
https://www.youtube.com/channel/UCZ6ULBqIKhxuNslAbqFNJUg
Interested in my devices? Check my store:
https://migronelectronics.bigcartel.com
Reply 1 of 21, by H3nrik V!
Very cool! And should be easy to make an ISA version as well 😉
Will you share schematics, etch., or will you have it manufactured and sell it?
Reply 2 of 21, by galanopu
H3nrik V! wrote on 2021-02-18, 09:57:
Thnx! 😀
The ISA version is next and it will double down also as an post code card.
It is fairly easy to add this into the ISA card without significant extra cost.
I can not give schematics or code, but this will be fairly inexpensive.
As I said in the video I have already ordered 20 of them.
These will be available in ~1 month from now.
Reply 3 of 21, by dionb
Nice stuff! I would definitely want one - and the ISA version too. Particularly useful when messing around with badly documented boards with jumper settings. Right now best I can do is guess based on when things crash 😉
Reply 4 of 21, by waterbeesje
Definitely interesting stuff 😀
Would be valuable along with a simple/cheap PCI/ISA tester.
I can imagine one with extension cable to get there segment display onto a front bay as well 😀
Stuck at 10MHz...
Reply 5 of 21, by galanopu
Thank you.
It is nice to see that other people find this interesting and useful too!
I will give you an update when I got the first batch or if I have any update on the ISA version.
Usually I post to my Youtube channel first.
Reply 6 of 21, by zyga64
I'm also interested. How much approximately will it cost ?
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 7 of 21, by galanopu
zyga64 wrote on 2021-02-18, 13:20:
If everything goes well with this batch, I will probably charge 30e per piece.
Reply 8 of 21, by debs3759
Cool tool. I'll be interested in this and the ISA version. Even more an ISA version with POST code testing. A tool for all eventualities 😀
Reply 12 of 21, by galanopu
Thank you all!
I got the message... I will design the ISA version this weekend ^^
This was a mistake on my side. I should have done this earlier too.
Now I have to prototype first and then order again.
It will take 2-3 months to have stock of the ISA version.
Reply 14 of 21, by galanopu
These 20 x PCI_clk v1.01 got shipped to me today.
Gold finished, beveled, and professionally assembled.
I will have them in ~20 days from now.
    209.92 KiB
Reply 16 of 21, by Tiido
These look nice ~
Reply 18 of 21, by galanopu
V1.01 now in stock...
Improved compatibility and displayed error to +-5KHz.
Check this:
Reply 19 of 21, by galanopu
ISA Clock is not available 😀
    286.16 KiB
