First post, by Corvair
Hi! This is a retro printers in my collection (part 1)
251.77 KiB
Epson LQ-2550
326.46 KiB
LQ-2550 test print
248.73 KiB
Fujitsu DL-3300. Pictured shortly after decomissioning
457.67 KiB
DL-3300 test print
256.5 KiB
Epson LX-300+ with colour kit
Reply 1 of 10, by Corvair
This is a retro printers in my collection (part 2)
184.68 KiB
Brother M-1824L with SF-240 Cut sheet feeder
181.66 KiB
M-1824L test print
333.76 KiB
Facit E-560
266.03 KiB
E-560 test print
247.12 KiB
Epson LQ-570+ with 50-sheet Cut sheet feeder
Reply 2 of 10, by Corvair
This is a retro printers in my collection (part 3)
279.37 KiB
TEC F10-40 daisywheel
347.33 KiB
437.87 KiB
F10-40 daisywheel and test print
Reply 3 of 10, by Miphee
I got this printer because this type was the one I used when I was 8.
It's slow, noisy, heavy and the print quality is bad but I loved this printer when I was a kid, that screeching noise has a sentimental value to me now.
The ribbon costs like $3 and still widely available.
It doesn't fit any of my shelves so I'm lucky I'm not into collecting old printers.
    558.41 KiB
Reply 4 of 10, by wiretap
Not retro, but somewhat. I have an Epson FX-890 dot matrix tractor feed printer that is recently manufactured. It will interface with everything from my Amiga and 8088 up through Windows 10.
Circuit Board Repair Manuals
My Project List
Reply 5 of 10, by chinny22
Corvair that's a lot of printers!
Do you have them permanently setup and attached to PC's or do they only come out for special occasions.
I'd like a dot matrix of some sort and/or something like a HP LaserJet 4 but don't have the space.
Reply 7 of 10, by Corvair
My printers don't attached to permanet rig and come out for spesial occasions only, firstly for my friends. And i planning to move my collection to display in a retro tech museum.
Who else has colour matrix printers? This machines used up to mid 90s, but Epson recently released very interesting DLQ-3500 II, not only than colour matrix printer, first matrix printer with colour display 😀. This means to colour matrix printer, truly ancient technology, remains in demand.
Reply 8 of 10, by Errius
The Epson LQ were daisy wheel and LX were dot matrix, IIRC.
I think I had one of each many years ago, but no longer remember the models.
“I like to dissect PCs. Don't you know I'm utterly insane?"
Reply 9 of 10, by keenmaster486
I have an Epson LQ-850 and HP Deskjet 842C which I use for printing from retro machines, and an HP Color Laserjet 4500 which I use for both modern & retro printing from network
I'll see if I can post pics later
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 10 of 10, by Corvair
Errius wrote on 2021-03-02, 20:11:
All Epson impact printers is a typical dot-matrix (needle, SIDM) printers. LQ/DLQ/PLQ series - 24 pin, LX/FX/DFX - 9 pin. Modern FX has 18 (2*9) pin, DFX also x*9 pin, basically is a 9 pin technology with multipied 9 pin arrays for speed.
Letterpress/typewriter-like fixed letters printer and daisy wheel in particular, provides best quality among impact technology, true Letter Quality class. But most LQ-class printers typically is a 24-pin SIDM machines, daisy wheel technology in comuter printer generally declined to late 80s.
Some daisywheel printers able to graphic print through "dot" sign. Probably this actually single-needle print was very-very slow. The sign of "graphical" capability of daisywheel printer is a metal insert in "dot" sign. Just my TEC F10-40 has metal dot sign and needs to check his graphical capabilities.
