First post, by MoG91
Good Afternoon Everyone,
I have a Dell XPI that I’d really like to get working that’s missing a charger. Unfortunately the other Dell chargers I have don’t fit it and I can’t seem to find it online. Does anyone have a recommendation on where to buy this from? Or maybe a good universal one that could work with this Or does anyone have one they could personally sell? Thanks in advance for any help,
Reply 1 of 5, by cyclone3d
Where are you located?
If in the USA, Amazon has an aftermarket one for $17.99:
https://www.amazon.com/Kircuit-Adapter-Latitu … r/dp/B082W45W1H
Here is a used Genuine Dell adapter on eBay for $14.99 (I would go with this one):
https://www.ebay.com/itm/AC-Adapter-Pow ... 694032960
Really, all you need is to look for is the power adapter model number, which is PA-6.
If you search by that, a ton of options come up.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 2 of 5, by MoG91
cyclone3d wrote on 2021-03-05, 22:47:
Where are you located? […]
Unfortunately that’s not the charger. I have one of those and it doesn’t fit! I’m not quite sure what the model is and I’m having trouble figuring it out. I took a picture of the port here
Edit: Also I’m located in the US
Reply 3 of 5, by Thermalwrong
You need to look for the Dell PA-1 charger, you can also search for "dell 18.5v" and get some results that way. It's got quite a distinctive plug with that rounded end.
Here's what one looks like from a search:
279.27 KiB
146.5 KiB
243.16 KiB
I should really buy one of these some day, lately I just run laptops off of my bench PSU and home made adapters.
Also, one of the Dell XPi CD P150 ST laptops I received did come with an aftermarket charger like the PA-6 plug, but they'd jammed it/cut it down to fit and worked. I don't like using aftermarket chargers though.
Reply 4 of 5, by cyclone3d
Ah, ok. I forgot they were slightly different. I have an XPi CD and some PA-6 chargers.. have a PA-1 as well but I didn't actually double check t make sure which one fit... I haven't messed with that laptop in quite a while.
Yamaha YMF7x4 Guide
Reply 5 of 5, by MoG91
Thermalwrong wrote on 2021-03-06, 02:14:
You need to look for the Dell PA-1 charger, you can also search for "dell 18.5v" and get some results that way. It's got quite a […]
Should it work fine if I cut a PA-6 plug? I have a few of those and wouldn’t mind cutting one a little with a dremel. I don’t know much about this end of it and am a little scared to modify it. But thank you so much. This is at least coming up with the results for what I need!
Edit:I actually found it on eBay when looking up “Dell 81407” now that I have the dell part number! And it was $11. Better than the $50 I was looking at spending before. You guys are awesome thank you so much,
