Reply 20 of 42, by Kiteless
PC Hoarder Patrol wrote on 2021-07-21, 10:43:
Glad you found the ISO useful - you can find the manual (rev A4) here
http://www.win3x.org/uh19/public/motherboard/ … a4777462618.pdf
You rock! Thanks so much! And yeah ISO is awesome. Full of all kinds of goodies. Way more than I'm used to seeing a mobo manufacture put on there. Truly a "CD Pro" haha.
// J
YouTube channel
https://www.youtube.com/channel/UCTfnRX4AWhbYJuguUcEff-g
Main Systems
NuXT
IBM 5140
486 DX4 100Mhz (Mainly DOS)
AMD K6-2 500Mhz (Mainly DOS)
AMD Athlon 700Mhz 9700 Pro (Win 98)
Pentium D 3Ghz 4670 AGP 8x (Win XP)
Reply 21 of 42, by computerguy08
SETBLASTER wrote on 2021-03-12, 02:22:
This is a mega pack of stuff for that motherboard that i made. […]
It contains:
-Old websites with info and tutorials on how to fix some of the problems, specially with sound blaster cards, it has bios, drivers, etc.
-Some of the websites are not available anymore so i saved them using wayback, and i was able to get most of the files hosted on those websites too.
-For example there is a site that talks about problems with the motherboard and that site gives you a link to other 2 sites, and those 2 sites have files in it. I saved all sites to pdf and all files on the site are on the pack.
- INCLUDED ALSO THE LATEST MODDED BIOS FOR K6-iii , mod by Tim Stinnett
https://www27.zippyshare.com/v/BQevuyeq/file.html
Now if there is an angel out there in this forum.....
I would really like to have an ISO image of the original Driver CD that came bundled in the box of the motherboard, I have only seen it Once, on ebay, asking 300 dollars for it.
Do you still have this pack ? (original link is dead)
Reply 22 of 42, by SETBLASTER
computerguy08 wrote on 2021-07-22, 12:29:
It contains:
yes, here you go
https://www.mediafire.com/file/iwo9udqv83rrfo … /va503.rar/file
Reply 23 of 42, by Horun
Thanks !
Reply 24 of 42, by pinesal
SETBLASTER wrote on 2021-07-25, 01:09:
It contains:
yes, here you go
Link is dead again, have another?
Hang out in the 90s with me on Twitch: The 90s Retro Gaming https://twitch.tv/90snick_pinesal
Retro Battlestation:
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
Reply 25 of 42, by Sphere478
I have one if there are still unresolved issues anyone needs help with.
Yes k6-2/3+ is supported with latest bios from my recollection. And I was able to get usb working.
Sphere's PCB projects.
Reply 26 of 42, by SETBLASTER
Sphere478 wrote on 2022-02-19, 05:09:
yes ´please share link! i want to download it
Reply 27 of 42, by Sphere478
SETBLASTER wrote on 2022-03-19, 04:42:
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
This is CHKCPU’s webpage. (Jan)
DIY Bios Modding guide Jan Steunebrink k6-2+/3+ 128gb
More reading
Reply 28 of 42, by aitotat
I managed to find VA-503+ couple of days ago and it came with the USB riser card. I wouldn't have guessed that the riser card is rare. I just assumed it was included with every motherboard.
I took couple of pictures.
1.26 MiB
1.18 MiB
Reply 29 of 42, by Sphere478
aitotat wrote on 2022-03-19, 08:32:
I managed to find VA-503+ couple of days ago and it came with the USB riser card. I wouldn't have guessed that the riser card is […]
Oooo good find!! Yes very rare.
If you post really good measurements and a list of components and a diagram someone here may be able to make a gerber and mouser project for it
Reply 30 of 42, by Cuttoon
Those are probably rare AF since they only ever were optional in retail boxes, as stated in the manual:
25.67 KiB
And going by ASUS standards, "optional" was a somewhat imprecise way of saying "nonexistent".
I wonder whether those stabilising diodes and capacitors on that bracket ever made any practical difference in use. Other than that, it's basically inferior to generic cables, dictating the slot to use.
@OP: If it's about file transfer, you should go with a 2.0 PCI card anyway.
BTW., another friendly archive of old FTP sites, including FIC and the manuals:
http://cwcyrix.nsupdate.info/ftp-archives
I like jumpers.
Reply 31 of 42, by Sphere478
Cuttoon wrote on 2022-03-19, 09:34:
Those are probably rare AF since they only ever were optional in retail boxes, as stated in the manual: 2022-03-19-101557_1680x1 […]
Socket 7 and usb 2.0 are a bad mix better to use a hub on the usb 1.1.
If you install a card and run 3dmark (nothing using the card) then pull it out and run it again you’ll see what I mean. Could mean 1/3 to 1/4 better score
Reply 32 of 42, by Cuttoon
Sphere478 wrote on 2022-03-19, 10:03:
Thanks. OK, that is weird. Sure it applies to all chips? I've read the VIA ones were usually causing trouble. But I think I have at least three different manufacturers on the heap.
I like jumpers.
Reply 33 of 42, by PC Hoarder Patrol
😀 😀 😀 Who needs useful stuff like USB riser cards when you can join 1St Buddy and their NOVUS Club forum at https://web.archive.org/web/20000510063524/ht … inboard.com:80/
18.62 KiB
1St Buddy even had his own song (I apologise in advance) - https://web.archive.org/web/20010612095042/ht … oad/fic2000.mp3
107.32 KiB
Reply 34 of 42, by Sphere478
Cuttoon wrote on 2022-03-19, 10:11:
give it a try and report back there is a thread about it here somewhere
here it is
Which USB 2.0 cards for old motherboards
Reply 35 of 42, by aitotat
I took more pictures and made some measurements. USB D+ and D- pins just seem to be directly connected to USB ports. So it looks like all the components are for power supply filtering and fuses. There are many SMD capacitors so do correct me if I'm wrong.
Reply 36 of 42, by omega552003
It contains:
yes, here you go
Mind uploading it to Archive.org so randoms like me quit pestering you 🤣?
Reply 37 of 42, by Sphere478
aitotat wrote on 2022-03-19, 15:22:
You freakin rock!!! Good job!
Now to get a pcb wizard into the thread :p thank you so much!!
Reply 38 of 42, by SuperDave
PC Hoarder Patrol (or someone who happen to grab this ISO), you wouldn't happen to have a link to that CD Pro ISO would you? I'm about to get my FIC VA-503+ and I would love all those drivers and utilities. Thank you ahead of time!
Reply 39 of 42, by PC Hoarder Patrol
SuperDave wrote on 2022-10-20, 21:22:
@SuperDave, welcome to Vogons 😀
I don't have a live link to the compressed ISO atm, but it's still on my file server and am happy to UL a new copy to MediaFire - give it an hour or so and I'll update this post with the link
https://easyupload.io/bocjv4
