First post, by Velociraptor
I've a card that works for sound and I'm trying to get the IDE to work for a CD drive on my 386, which has one other IDE channel on the multi I/O card.
I understand that I need to initialise the IDE by running SACDROM.SYS in CONFIG.SYS before I run VIDECD.SYS.
The SETUPSA.EXE allows me to specify which pair of ports the two IDE ports use, and also the IRQ. I've tried putting those into the command line for VIDECD.SYS. Last night I got one working but I can't recall what I had done and I can't seem to repeat it. VIDECD.SYS doesn't like all of the options I can choose from either.
Has anyone found an explanation for this and can point me in the right direction?
