ATi RagePro OpenGL files
First post, by marxveix
I have many OpenGL versions for Rage Pro based cards, but i do not have all of them. If you have some other versions, please share download link. At the moment i made quick list, what i have, but i also upload them if someone needs them. I would like to get other RPro OpenGL files as well, i am missing 1073,1079,1087,1100,1106 and possibly other versions, so please help to get as much as possible, Thank you!
MiniGL
4.10.1036
OpenGL
4.11.1051
4.11.1058
4.11.1060
4.11.1065
4.11.1068
4.11.1076
4.11.1077
4.11.1085
4.11.1091
4.11.1094
4.12.1094
4.12.1096
4.12.1103
4.12.1104
4.12.1107
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 1 of 170, by debs3759
Can you upload a rar or zip of the full set? Would save a lot of searching when it comes time for testing them 😀
Reply 2 of 170, by marxveix
debs3759 wrote on 2021-03-15, 10:51:
Of course, i upload them later today. 1068 is fast for me and 1073 should also (for older OpenGL games).
Reply 3 of 170, by debs3759
Thanks
Reply 4 of 170, by marxveix
Uploaded here, i hope it helps. If there is some kind of mistake, let me know, i have all listed opengl files available.
ragepro-opengl.zip
Reply 5 of 170, by debs3759
Access is forbidden to that page (403 error)
Reply 6 of 170, by marxveix
debs3759 wrote on 2021-03-15, 18:56:
I can download it, direct link:
https://www88.zippyshare.com/d/KdvhyJx6/25322 … epro-opengl.zip
Also uploaded same file to my page, direct link:
www.hingetee.ee/meedia/rage/opengl/ragepro-opengl.zip
Reply 7 of 170, by debs3759
Second link works, thanks. The first link will work for you if it is your site or you are registered there, but it didn't for me 😀
Reply 8 of 170, by marxveix
debs3759 wrote on 2021-03-15, 20:33:
Second link is my site, first one was file share site, that should work for everyone, without registration for uploads and downloads.
Glad that you got them!
You got Rage128/Rage128Pro, for that videocard, OpenGL version 1238 should be fast (i have that also).
These OpenGL files are only for Win9x and i look for Win9x RagePro OpenGL files only (at the moment).
GLQuake works well up to 1094, after that, it has some screen glitches, but 110x works fastest, like that.
Maybe it is my pc setup, strange that Quake works little faster with K62 300-350,not at 400-500Mhz.
OpenGL 1068 is faster with Quake 2, than other versions so far, even faster than OpenGL 1076 or 1077.
Reply 9 of 170, by debs3759
I have Rage Pro cards as well. I'll be sorting through several large boxes of cards soon (too fatigued at the moment after having the AZ vaccine), and digging out all my cards suitable for 98 and earlier to test in a Batman's Revenge and a PVI-486SP3 board.
Reply 10 of 170, by marxveix
I found two MiniGL betas, Glbeta2 4.10.1010 and GLbeta3 4.10.1021 and i have 4.12 and 4.11 versions of 1091 and 1094, but these two 4.11 and 4.12 versions seems similar to me. Also i have found OpenGL 4.11.1084, 4.12.1095 and 4.12.1106 and i am missing from already mentioned ones, 4.11.1071 version.
Anybody have used 110x OpenGL-s for glquake, i get timedemo demo1 30fps with my k6-2+@350Mhz, but screen has flickering with them, any fix would be nice. With OpenGL 1068 with same pc i get 28.3fps, which is second best at the moment and game screen picture is correct, also 1068 seems fastest with quake2 and my 5.38/5.40 3dcif compatibe drivers, fps is 24.6 (without any tweaks in both of the quake games).
Would i get better performance with pentium 2 + rage pro and quake games?
Tested Quake2 v3.20 with AMDK6-2+ 400Mhz and OpenGL 1068
Original:
640x480 - Rage PRo LT 8MB
timedemo 1
map demo1.dm2
fps 24.6
More FPS to Quake2 OpenGL with cfg file
Autoexec.cfg:
timedemo 1
map demo1.dm2
fps 26.6
OpenGL Bi-linear disabled+Autoexec.cfg:
timedemo 1
map demo1.dm2
fps 28.5
Reply 11 of 170, by marxveix
Anybody has other OpenGL versions available for Rage Pro/LTPRO/XL/XC/Mobility-P/M and Windows 9x?
MiniGL
4.10.1010
4.10.1021
4.10.1036
OpenGL
4.11.1051
4.11.1058
4.11.1060
4.11.1065
4.11.1068
4.11.1076
4.11.1077
4.11.1084
4.11.1085
4.11.1091
4.12.1091
4.11.1094
4.12.1094
4.12.1095
4.12.1096
4.12.1103
4.12.1104
4.12.1106
4.12.1107
At the moment i have these, i update download link if needed.
Reply 12 of 170, by dr.zeissler
First of all it's great that the RageProLT supports opengl at all. But I have some problems with the quality.
1. OpenGL works with 16Bit not more
2. OpenGL texturefiltering looks very bad . Not only the textures but also the always visible dithering/raster all over the screen.
3. Light's do not look korrekt on DoomGL/GLHexen (Flame is not visible inside the Light and color gradient is not smooth)
4. Beside that some early D3D features do not work too (table-fog)
Ony chances of getting more quality out of openGL ?
Reply 13 of 170, by marxveix
Hi dr.zeissler
I do not know how to modify any OpenGL file, i just searched and collected them for Rage3 based cards, i like ATi RagePro/LT/XL!
1. In OpenGL you just need do use 16bit, not more, 32bit does not work for these cards. Even some D3D games need 16bit only, like Moto Racer.
2. Rage XL has improved bilinear filtering on transparent textures compared to the Rage Pro. Rage XL is A die shrink of the Rage Pro that runs with lower power consumption, higher frequencies and has image quality fixes. Newer Rage XL PCI (4752) cards have compatibility issues for older PCs PCI slots and 3DCIF, Rage XL AGP works well.
3. I do not have played those GL games, but maybe you can try all OpenGL versions out, latest OpenGL 4.12.1107 should have most bug fixes? Rage3 cards are somehow limited, but these are first ATi 3D cards, that you could play 3D games at playable speed, not like S3 Virge or ATi Rage1/2. Rage3 chipset is quite capable. You can use RagePro-Tweaker and disable OpenGL Bi-linear filtering if you like, it speeds up performance and try Rage XL out.
Maybe OpenGL Switcher (for OpenGL) helps:
http://www.3dfxzone.it/dir/3dfx/utilities/?objid=3
4. ATi Rage XL has improvements that you may like, it has Fog Table integration. I love my Rage XL 8MB AGP (Compaq), it has also sharper 2D and 3D output quality, better than other RagePro/LT/XL i have. D3D, OpenGL, 3DCIF APIs in Win9x and most DOS games work well, what more you want, oh yes, it can accelerate DVD playback.
Look for: 3.11.3 Function Support Differences between RAGE XL and RAGE PRO
http://old.vgamuseum.info/images/stories/doc/ … tions_dec03.pdf
Reply 14 of 170, by marxveix
I would like to get Rage OpenGL ICD 1073, it should have multitexturing support in it. OpenGL ICD name atoglrp9.dll (before 5.40), atio9xad.dll (5.40) or atio9xae.dll (J5.xx). 1073 should be before 5.40 releases, but i am not 100% sure, anybody has 1073 OpenGl ICD?
Talk about this 1073 and other RagePro OpenGL versions:
http://www.rage3d.com/board/showthread.php?t=1022
Reply 15 of 170, by Kahenraz
All of these links are dead. Does anyone have a backup?
Reply 17 of 170, by agent_x007
Upload to vogons drivers for posterity ?
Reply 19 of 170, by marxveix
marxveix wrote on 2021-03-24, 20:36:
Anybody has other OpenGL versions available for Rage Pro/LTPRO/XL/XC/Mobility-P/M and Windows 9x? […]
MiniGL
4.10.1010
4.10.1021
4.10.1036
OpenGL
4.11.1051
4.11.1058
4.11.1060
4.11.1065
4.11.1068
4.11.1076
4.11.1077
4.11.1084
4.11.1085
4.11.1091
4.12.1091
4.11.1094
4.12.1094
4.12.1095
4.12.1096
4.12.1103
4.12.1104
4.12.1106
4.12.1107
I uploaded all these versions here, if someone can, upload also to vogons archive, i have not done that before, Thank you!
https://www.upload.ee/files/14683268/Rage3-GL_Win9x.zip.html
