First post, by jheronimus
Hi, all
Just bought this card, going to get it (hopefully) in about 10 days:
116.95 KiB
This is a Mountain Racecard-286, a 286 upgrade card for XT computers. The card is actually made by PC Technologies.
Unlike cards like Orchid Tiny Turbo this board does not have a hardware switch or a socket for the XT CPU, the CPU speed is chosen through software. I was wondering whether anybody has the drivers for this card and/or the jumpers description.
Supposedly many versions of the card were available: the original PCT 286 Express, Tandy 286 Express, Kodak/Verbatim Data Life CPU Card, Micro1 286 SpeedCard, Viktor Speed Pak 286 and Maynard Surpise!286, though there is no way of telling which of them are identical and which of them are not.
These cards are also mentioned in a review in 80 Micro, and it looks like they were priced differently:
171.31 KiB
According a different review (can't find the link at the moment) the cards also differed in functionality: e.g., some cards were EGA-compatible and others used an earlier design from PC Technologies that wouldn't work with EGA.
Does anybody have any additional info on this card or any of its variations? So far I've only been able to find the manual and drivers for the Tandy version of 286 Express card, but it remains to be seen whether or not these drivers will work for the Racecard-286. The board layout is definitely different, and the card has DIP switches instead of jumpers:
629.98 KiB
MR BIOS catalog
Unicore catalog
Reply 1 of 11, by Horun
Very interesting ! I never saw a CPU upgrade card that actually had the removed 8088 plugged back into the Upgrade card.
Will look around but do not think will find anything. You might PM feipoa as he has worked with more cpu upgrade cards than anyone AFAIK.
Reply 2 of 11, by jheronimus
Horun wrote on 2021-03-24, 02:57:
I think for XT accelerators that is actually a norm rather than exception. The odd thing here seems to be a lack of a hardware turbo switch
Thanks, will do!
MR BIOS catalog
Unicore catalog
Reply 4 of 11, by jheronimus
Doornkaat wrote on 2021-03-24, 10:42:
Maybe you switch between processors using one of the typical key combinations used for switching between turbo and deturbo mode on other machines?
That is definitely how it’s done, but judging by the Tandy model of the card, you need to either load a .sys driver or use a utility for that. I don’t think this card has a BIOS of its own.
MR BIOS catalog
Unicore catalog
Reply 5 of 11, by feipoa
Unfortunately, I have never used this accelerator card before. User Anonymous Coward has pretty much tested every 286 upgrade known to exist. I think he's your best bet for info.
Reply 6 of 11, by Doornkaat
jheronimus wrote on 2021-03-24, 10:53:
Oh, ok. You can probably tell I have next to no clue about those cards.😅
Reply 7 of 11, by jheronimus
Still waiting for the card, but in the meantime it has dawned on me. Here's another photo of the card:
-racecard_286_mountain_accelerator_cpu_isa_card_ibm_5150_pc_5160_7___2mhz_orchid-3_156.jpg
322.81 KiB
I thought the 8088 should be piggybacked into the end of the cable that goes into the motherboard CPU socket, but apparently it is not. The socket on the card is for the 287 FPU. So the card only has one CPU and as such doesn't need to switch between the two.
Furthermore, I've found a review on the original PCT 286 Express card, and it specifically mentions that the card didn't come with any driver disk:
487.29 KiB
So, the good news is that I don't need to find any software for the card. The bad news is, of course that if it works, I'm going to lose XT compatibility. My 1000SX does have original Tandy DOS3.2 installed with a modified mode.com utility that can slow the CPU down, and it worked reasonably well even with a V20, though.
MR BIOS catalog
Unicore catalog
Reply 8 of 11, by Horun
heheh yeah I had never heard of one that you put the 8088 in to the upgrade but have very limited experience with the old XT cpu upgrades.
Well is good you do not need a driver and think most back then would have bought the upgrade (instead of buying a new computer) to run Windows 2 or newer apps on it and not for old XT style gaming... just a thought.
