Reply 20 of 37, by weedeewee
AV9107-03 generates frequencies from 2 to 120 MHz
AV9107-04 12.5 - 130 MHz
AV9107-05 40 - 80 MHz
AV9107-10 25 - 50 MHz
though these last two are DIP 8 packages
too bad for the lack of datasheet for the part that is on your mainboard. KDN-0147C
you can look at the AV9107 info, trace the FS0-FS3 pins and give it to old trial and error approach. 😀
Just make sure you don't short any voltage rails directly to ground.
Do not ask Why !
