First post, by dataino.it
- Member
Hello everyone, I have this card and I would like to fix it but someone has thrown a hammer on it and the voltage regulator is missing, kindly is there any owner of this card that tells me what component is it?
I found this exact motherboard today and I'll post detailed pictures with it tomorrow. 😀
The missing regulator is a Fairchild Semiconductor NDP603AL N-Channel Logic Level Enhancement Mode Field Effect Transistor 25A, 30V. RDS(ON) = 0.022Ω @ VGS=10V https://pdf1.alldatasheet.com/datasheet-pdf/v … D/NDP603AL.html
It was a PITA to read the specs as the big capacitor was in the way. Mine has a 9536 date code.
I also tried to make good pics with the entire board.
Good luck!
gallery: https://postimg.cc/gallery/dk3txQ0
