Reply 34 of 353, by h-a-l-9000
@whocrazy: You could also try other drivers like http://www.digsys.se/adf.html, and my new version (which still has no BIOS support). Maybe your application can be configured to use the UART directly instead of INT14h BIOS?
About the new "version":
Configuration:
The configuration can be changed on-line within Dosbox. At the prompt, type 'serial1 modem', if you want a modem on com1. For a real serial port, type 'serial1 directserial realport:com1'. 4 serial ports are supported.
In the config file, it has moved to the BIOS section. I had to rename the entries from comX to serialX because of a config change issue.
Directserial:
- line error messages more detailed
- more tolerant handling of received data, so a slowly running application has a bigger chance to get it before RX overflow occurs
Modem:
- accepts connection only if a modem-aware program is running (DTR on)
- tested with the following terminal software:
Telix
Bananacom
SBBS with both MS Telnet and terminal running in Dosbox as client
BNU FOSSIL driver (not everything tested)
- tested with the following games:
Tyrian
Radix (Demo)
C&C 1
Warcraft
Warcraft2
Descent
Descent2
Terminal Velocity
TZone
F-29 Retaliator
- Does not work for:
Moo2 (1.3 patch, lower version even less) - It can connect, but shows me clock mouse pointer after I chose my color, and nothing more happens.
I've also been working on the IPX emulation, and have been able to make some more games work. But maybe at a high price: It uses up a hardware interrupt, as I can't think of any other way to make the protected mode runtime switch to the right context for event notification.
- Additional working games (always only 2 players tried):
Tyrian
Radix
Moo2
Warcraft
- still not working:
C&C1 (Multiplayer game can be started, but immediately says "Games are out of sync" and also does some illegal reads, which are caused by a zero pointer. It does not crash anymore, though.
These games are still working despite of me messing with IPX:
Warcraft2
Terminal Velocity
Descent (I think)
Descent2
Testing with more than 2 players and other would be required.
