First post, by Eddyworker
hello, it is the first time that I write in this forum. I have followed him for several years and have learned many things. I have a 6800gt a400 windfast on a winxp and win 98 dual system, it works fine on both. In windows 98 I use the 77.72 drivers, the latest version fails at more than 60hz. I use an acer vg270 monitor through a dual dvi-d hdmi adapter. In the nvidia control panel I see all the frequencies that the monitor carries but when I exceed 75hz the monitor stays at 62hz, nvidia shows me that it is at 144hz but the monitor control panel at 62hz and I also notice the frequency drop . This happens in any resolution. In windows xp does not exceed 75hz. I have tried creating custom resolutions with various programs and the image is corrupted. I have tried several nvidia cards and always have the same problem on all windows os, only the 1050 or newest works fine. However with an ati 9200 ddr it works fine at 1280x1024 120hz. What is the problem here? Is it the monitor or an nvidia limitation? I would appreciate your comments. Thanks
