First post, by 0xCats
So this will be a relatively straight forward post.
I'm searching for a bios for a rather rare board, and I'm hoping one of you here maybe also has this board and is able to dump the contents of the BIOS chip.
https://theretroweb.com/hardware/motherboards … ion-mb-p5n-dpv3
The board is 430NX chipset based and supports two Socket 5 Pentium processors.
As far as we (Ultimate Hardware 2019) know it is made by Sprint Manufacturing Corporation sometime in 1994.
http://www.win3x.org/uh19/motherboard/show/4725
I have recently restored this board and gotten it running again (sort of) the original bios is corrupted and through a lot of bios hacking I have managed to get the BIOS of the Chaintech 5IDL0 working on this board. This BIOS however is also partly not suited to this board, it does not setup the internal or external caches, among many other things, it also cannot read any of the GPIO board jumper pins and as a result of various quirks runs absolutely terrifyingly slow. In addition PCI/IDE setup is a mess and it will not boot those either. Only thing I have managed to boot is PXE network devices. But there also things like iSCSI fail too due to complex reasons with how award bios handles disk boot and iscsi.
The BIOS version 0208 of the Asus P4P54NP4D also works but PCI and LBX setup fails, and ISA video cards are also not initialized, yet I can tell that the board is actually running since it will attempted to boot disks and shows the relevant post codes.
Originally the Sprint board came with an AMI Core bios dated 10/10/94.
Here is a link to the bad one:
https://theretroweb.com/uploads/mobos/sprint- … 01bx-tdip32.bin
Here is a picture of this rare board and it actually running to some extent.
I hope someone can help, if they have a such a board or even a dual socket 5 that looks similar enough if you could read the bios contents out and send them to me.
a6103fda1bcd613.94711492
502.57 KiB
150.23 KiB
Thank you
The Cyber Cat
There are two types of devices, those that know they've been hacked and those that don't yet know they're going to be hacked.
Reply 1 of 16, by Horun
Interesting ! It looks like a OEM Micron motherboard. Cannot find anything...
Reply 3 of 16, by 0xCats
As a progress update I have now managed to get cache and various other elements functional.
Also disk controller enumeration etc is working.
I'm now using an AOpen DP5 motherboards BIOS which has been adapted to run on this board.
Some chipset logic configuration is still required however with the documentation at hand it's going somewhat ok.
The next trick will be to get the board to consistently set the masked [7:6] bit chipset registers init values for 52h.
Currently I am using a reset quirk of the chipset to set those bits (essentially bug programming).
Essentially when cold posting the board the cache register is programmed with incorrect cache configuration parameters for the AOpen platform and as a result cache is not configured correctly.
So what I do is post, then I remove the cache config jumper, (bit 6 high) and then reset and I get the inverted logic sampled and bits 7:6 are configured as 10.
92.05 KiB
As you can see this has given good results 😁
153.56 KiB
Reply 5 of 16, by 0xCats
No pictures this time, but finally I can report I have managed to restore full speed and full cache functionality using a custom crafted AwardBIOS 4.50PG adapted from the AOpen DP5. Itself yet another undocumented unseen dual pentium motherboard.
Will post more once I have the time and a proper PCI IDE card haha. PXEBooting a P586 architecture via iSCSI over gigabit is a bit of an alice in wonderland adventure worthy of it's own thread. 🤣
Next up will also be modding the board with a stronger VRM and getting higher multipliers, plus syncing the APIC for fast dual processors.
And just for fun let me give the laundry list of faults this board had:
1. Both 3.3V Linear LDO voltage regulators for CPU Vcore had failed (likely cooked to death), the heatsinks on them are pathetic.
2. 430NX had loose pins on two sides (bad terrible solder)
3. S82379 SIO had loose pins on bottom edge.
4. Keyboard rom socket had a spider nest under it and corroded pins.
5. One of the 433 LBX chips had loose pins all around. (yet again crap solder)
6. two address lines of BIOS chip were cut
7. 1 CPU address pin on primary socket had a bad corroded joint.
8. 2 ISA address and 2 ISA data lines on back were scratched through
9. AT header power pins had cold joints (reflowed)
10. Original BIOS is corrupted and will more often not post than post, large part of chipset setup logic is FUBAR
11. degraded SMD capacitor on Address Line 30 (used for strapping cache config after PWR-OK edge) was causing cache config flipping between 256/512K.
Reply 6 of 16, by 0xCats
So as an update. It turned out that the cache I originally though working was a fluke. A bunch of chips and the buffers for them were degraded.
A while ago I actually went about testing the cacheless wonder. Well here are some more images.
When did you ever see Vintage Edition CPU-z with the Socket Dropdown active? 😜
66 KiB
Vintage Edition with more SOCATS???
65.11 KiB
COARS!
Windows 2000 installed (without L2 cache active) -oh horror
The memory subsystem performance was astonishingly dreadful.
After some testing done using a custom build of the chipsandcheese memory latency tool we came to suspect the reason for this is that the OS partly uses the L2 cache to speed up page table lookups.
Without this, memory address generation and lookups quickly become absolutely dreadful beyond about the 256KB size.
Here is a cache enabled 430TX compared using a somewhat different processor.
54.08 KiB
Memory latency plot vs 430TX PMMX 233
The memory latency here shockingly is worse than the worst Nvidia GPU OpenCL could still be run on in 2021.
For a GPU to outperform a CPU's memory latency in any way is pretty hefty.
20.22 KiB
430NX vs 9500 GT
Anyways, I've finally received some new cache chips for this thing today, finding 3.3V Supply Low Voltage TTL rated SRAM is a PAIN.
Reply 7 of 16, by 0xCats
Next modifications that are about due:
- Already modified BIOS for very low AT and PCI clk ratios
- Replace all the slow 74F244/245/373 series logic chips with ultra fast 74ABT series. (MOAR MHZ!!!)
- Replace the crystal oscillator can driven FSB with a custom PLL PCB and inject any desired FSB frequency.
- Wire all the multiplier options from the socket to an addon switchblock.
- Split the 3.3V Voltage plane at the sockets and install a custom VRM PCB ontop of the linear Vreg 3 pin footprint via headers. (Pentium MMX SMP!)
- Design a new cache interface PCB that goes ontop of the existing async SRAM sockets but allows the use of a single 512K Pipeline Burst SRAM chip. (512K is the max 430NX supports)
- Attempt 100MHZ FSB speedrun
Reply 8 of 16, by PC@LIVE
Hello and congratulations on the work and the motherboard.
I have seen the excellent work done, to adapt the BIOS, and to improve the performance, I guess the voltage regulators are linear, in that case going up the frequency would have more heat to dissipate, so I would recommend 166MHz. Perhaps we can go further, but to produce less heat it would be necessary to use cpu for laptops with reduced voltage, this should guarantee operation at lower temperatures and therefore greater reliability, these are ideas that I made myself (maybe am I wrong?). In several VXs with linear regulators I have had problems with 200 or 233MHz CPUs, perhaps changing the heatsink on the mosfets (with a bigger one) and adding a fan would work better.
On a VX and a TX with switching regulators, on the other hand I don't have these problems, and I have AMD K6-2 CPUs at 360 and 400 MHz, the limit is due to the FSB that reaches 83MHz at the maximum, but since you want to reach 100, maybe it would be possible that it works more stable if you used a 90MHz FSB, especially if you can make (divider 1/3) that the PCI goes to 30Mhz, instead of 45MHz with divider 1/2.
With fsb 90 a 233MMX would go at 315Mhz, and it would be a very good frequency for that CPU, then having two would be even better, but reaching and exceeding 300 is possible, but it is not guaranteed that it will be stable and reliable over time.
I will gladly follow the developments of your work, I am very interested in this thing of the FSB 100, in my opinion those who have tried have failed because the divider 1/2 makes the PCI work at 50MHz.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 9 of 16, by 0xCats
After much toil and suffering I have a new update.
L2 cache is working again FINALLY!!
1.1 MiB
Here is proof of that alongside a quick test of aida64 version 2.50.
1.19 MiB
Now that this is all working I can actually start optimization work alongside getting this bios code tweaked to the max potential.
Reply 10 of 16, by 0xCats
Time for the real stuff!
1003.48 KiB
I've gotten the latest Linux Kernel booted and running on this thing.
1.08 MiB
So how much storage does your pentium 1 have?
Ah yeah a casual 1TB disk, nothing much...
175.75 KiB
Reply 11 of 16, by 0xCats
Just realized I never actually posted a picture of my custom BIOS for this board.
So here you are:
168.53 KiB
Reply 12 of 16, by s.mouse
Sorry to bump old thread
I came across this thread trying to identify a board I recently picked up, which appears to be the single cpu version of this board. https://theretroweb.com/motherboards/s/sprint … f.-co-mb-p5n-sp
It looks like you have got the board functional with your bios witchery, I have dumped the bios for my board it may be of use, not sure if it would be the same bios being the single CPU version. Interestingly it says "Evaluation Rom - not for sale" I wonder why; perhaps my board some kind of pre release revision?
After reading your findings regarding loose pins on the solder joints I had a close look and also have identified a loose pin on one of the 430nx chips so thanks for pointing that out, I agree the board has (bad terrible solder). I will carry out repairs at some stage when I have the time
94.06 KiB
86.85 KiB
72.22 KiB
53.33 KiB
Bios dump
https://drive.google.com/drive/folders/11YoTM … aDm?usp=sharing
Reply 13 of 16, by 0xCats
Wow this is pretty amazing!
I'm surprised that it is an Award BIOS and not AMI like mine originally was.
What chip does yours use for the SIO?
109.39 KiB
Is it S82378 or S82379 ?
It would be great if you could post some high quality images of the board, then I can add them to TheretroWeb.
Reply 14 of 16, by s.mouse
The chip is S82378ZB
Just an update on my experience with the board since posting
I re-soldered the pin i found disconnected on the S82433NX closest the cpu socket and found the chip was running extremely hot. After inspecting the S82433NX data sheet I discovered pin 150 which was disconnected should be tied to 3.3 volts however the motherboard trace is tied to 5 volts. I disconnected the pin and the chip now runs at normal temperature (the pin is tied to the other 3.3 volt pins internally so it works fine). It seems the pin was disconnected intentionally as sprint made a mistake when designing board.
I have found the board freezes constantly trying to run windows 95. I have tried EVERYTHING. Removed L2 cache and disabled, stuffed around with every bios setting, tried various IDE controllers/ video cards, different ram. Windows just freezes at random points. And also corrupts data on the hard drive. I have monitored cpu voltage it drops to 3.194 volts which I wouldn’t have thought would be enough to cause such problems but i don’t know. I replaced the 2 capacitors filtering the 3.3volt mosfet output also. Replaced both 66mhz and 14.318mhz crystals. Ive tried windows 95a and windows 95c. The board doesn’t appear to freeze in DOS and runs through all benchmarks/ cache tests etc from phils benchmark pack. However I haven’t pushed system as much as i would on windows 95 reading/ writing data etc. I cant figure it out I think the S82433NX is possibly partially damaged due to feeding it 5 volts but I have no idea 🙁
Reply 15 of 16, by 0xCats
s.mouse wrote on 2022-08-30, 04:26:
Sorry to bump old thread […]
Bios dump
Hey, it's been a long time since I responded. But would it be possible for you to upload higher resolution images for TheRetroWeb project?
I've already added the low resolution ones from you
Reply 16 of 16, by 0xCats
If you'd like you can also join the RetroWeb discord (link on the website footer).
And we can help you get this board fixed.
