Windows 11 has been released
Reply 20 of 252, by buckeye
The stinking pile of "horse manure" in this release is for a local account install you have to upgrade to the pro version.
Seems like this is just an hollow upgrade full of fluff, focused mainly on new ways to follow yer every move. Is it me or does
this release seem opportunistic in the wake of the "manufactured pandemic" especially as ms said W10 was supposed to be
the last version. Bull.
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 21 of 252, by DosFreak
Upgraded fine using: https://gist.github.com/AveYo/c74dc774a8fb81a … reationtool-zip
Haven't tried booting the ISO yet
TEST DESKTOP
*Issues in Device Manager are for the F1300 and the Yamaha sound card. The FX1300 does have Vista 64bit drivers but those signed drivers don't work for 11.
CPU: Intel Core 2 Quad Q9650 @ 3.87GHZ FSB:431MHZ @ 1.35000v
CPU Cooler: Zalman CNPS9900A LED Ultra Quiet CPU Cooler Replaced fan with Noctua NF-P14 FLX 140mm Case cooler
Motherboard: Gigabyte X38-DQ6
Memory: 16GB DDR2 F2-6400CL5D-8GBPQ @ 862Mhz CL5-6-6-17 @1.8v
GPU 1: Zotac Geforce GTX 980 Ti 6GB AMP! Extreme GDDR5 ZT-90507-10B PCIe
GPU 2: Quadro FX 1300 128MB PCIe
NIC: Realtek RTL8111 PCI-E Gigabit
Audio: Audigy 2 Platinum 6.1 SB0240 (9x-8.1)
Audio: Realtek (Windows 10)
Audio: Yamaha YMF724E-V DOS-XP (Possibly Vista-10 32bit)
Monitor Acer XB271HU 27" 2560x1440 "Acer Predator XB1"
DVD 1: Blu-ray LG UH12LS28
DVD 2: Plextor DVD-R PX-760A
SSD: 2x Samsung SSD 860 EVO 1TB w/ StarTech.com M.2 to SATA Adapter
HD: Seagate Ironwolf 10TB ST10000VN0004 (XP+)
Case: CoolerMaster ATC-110 Replaced fans with 4x Thermaltake TT-8025A-2B 80mm Case Cooling Fan
PSU: Corsair RM850x
USB3: Inateck PCI-E to USB 3.0 (5 Ports) (KT5001) w/ Amebay 5.25 Inch Front Panel USB Hub 2port 3.0, USB 2.0 for Computer Case
    295.82 KiB
Make your games work offline
Reply 22 of 252, by cyclone3d
The Serpent Rider wrote on 2021-10-05, 09:03:
that PC will no longer be supported and won't be entitled to receive updates
Finally! Now we can install windows updates offline in peace.
Updating XP this way is great.
I haven't set up WSUS offline to do this for Windows 7 yet... Though I just upgrade Windows 7 machines to Windows 10.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23 of 252, by Joseph_Joestar
imi wrote on 2021-10-05, 14:19:
Windows 11 is really the best thing that could have happened.
...it'll finally make me switch to linux 😀
That's what happened to me a few years ago. When Windows 7 went EOL, I permanently switched to Linux. I've been using both in parallel for years before that though.
Can't say I miss Windows much, but then again, I don't play many modern games. And the ones that I do play, I can get on consoles instead.
Reply 24 of 252, by xcomcmdr
Bruninho wrote on 2021-10-05, 14:07:
I thought that it already was? Since VS Code is an electron app?
I'm talking about Visual Studio.
Visual Studio Code has nothing to do with it, and is an inferior product.
Same for VS for Mac.
Reply 25 of 252, by cyclone3d
buckeye wrote on 2021-10-05, 14:22:
The stinking pile of "horse manure" in this release is for a local account install you have to upgrade to the pro version. […]
I haven't tried the Home version yet. In the Pro version, when it wants me to connect to a network, I just click the link that says "I don't have Internet" and then it asks if I want to continue with a "limited account".
On my own machines, I always set it up with my MS account though. That way, licenses can be moved freely to new systems. You can't do this with an offline account. Ended up having to use one of my spare licenses when I upgraded a system for a friend because I had originally set them up with an offline account and didn't have them set up an MS account and log in to it before I did the upgrade.
YMF7x4 Guide
Reply 26 of 252, by Bruninho
xcomcmdr wrote on 2021-10-05, 14:52:
I'm talking about Visual Studio. Visual Studio Code has nothing to do with it, and is an inferior product. Same for VS for Mac. […]
Ah, well. I do not use VS or VS Code anyway 😜
My preferred IDE for my area of work is Coda 2, from Panic. Two minutes using VS Code was enough for me to reinstall Coda 2 and pay for a license, years ago. Panic at least gave me a 70% discount.
JOBS, Steve.
Reply 32 of 252, by The Serpent Rider
You don't need that for Windows 7. There's a separate project which can patch existing Windows 7 SP1 or image with all updates, excluding telemetry bloat - UpdatePack7R2
Reply 33 of 252, by matze79
Windows has mated with OSX and KDE now look on the Result 😳
For German Windows 7 and XP there are Updatepacks,
https://winfuture.de/downloadvorschalt,2671.html
Reply 34 of 252, by The Serpent Rider
I hope I can add a TPM 2.0 chip to upgrade to Windows 11.
It looks like TPM 2.0 is not all sunshine, rainbows and improved security though. Valorant is a fresh example of DRM enforcing via TPM, which should rise some concerns.
You can unofficially switch Windows 7 Pro language though, so there's no need for separate language update packs for Vista or Seven.
Reply 35 of 252, by matze79
Hell yeah Disk Rescue Companys will dance in Joy. TPM + Disk Encryption, imagine if your Mainboard dies and you where to lazy for Backups. 😁
At least China will have concerns, TPM Chips are banned since 1999 there.
Reply 36 of 252, by cyclone3d
matze79 wrote on 2021-10-05, 17:34:
Hah.. you are supposed to keep the recovery code in case something like that happens.
Or, ya know, you could always just not encrypt disks on your home systems.
YMF7x4 Guide
Reply 37 of 252, by cyclone3d
xcomcmdr wrote on 2021-10-05, 16:18:
An I7 6700K (2016 era) system should be able to upgrade, in a sane world.
It would be less of a hassle than migrating (again) to Linux. :p
You'll have to see if your motherboard supports a TPM module. If not, then you will need to get one that already has it or that accepts an add-on one.
YMF7x4 Guide
Reply 38 of 252, by buckeye
Can anyone comment on gaming performance hits? Keep reading W11 slows everything down.
Noticed a couple of posts got "vaporized". What's up with that?
Reply 39 of 252, by cyclone3d
I watched a youtube video about that. Sounds like some virtualization crap that is going to be implemented but also sounds like it should be able to be disabled through the registry:
https://youtu.be/MRdfMPj1Rzg
My main/gaming computer is only running a 5th gen Xeon so I'm not even going to try Windows 11 on that... waiting to get a Ryzen or Threadripper setup before I go to Windows 11 on my main PC.
Haven't tried gaming on my laptop that has a Quadro P4000 since I put 11 on it.
YMF7x4 Guide
