First post, by keropi
- l33t++
I present you the ACTION REWIND - a clone card of the original IBM PC Action Replay card
It is basically the same card that LGR showcases here: https://youtu.be/usaioMbE8EQ - except it is newly made and uses a cpld to re-create the discrete PAL chipset of the original - reverse engineered by JimWest.
The rom version installed is the latest v4.8 one that worked with the original action replay chipset.
You can use all functions of the Action Replay software - for all intents and purposes this clone card will work the same as the original card.
There is a domed sticker in every bracket so one can't mistake the port for a serial one and the control board is made friendly to be cased (in case someone designs a 3d printed enclosure or something).
I have made a simple website for this card that also contains purchase info: http://action-rewind.eu
Price is 85eur shipped worldwide via registered airmail, cards come fully assembled with a 180cm cable for the control board.
Thanks for looking! 😀
