First post, by ante1234and
hi!
i'm trying to get one unit whole blood working on my win98 pc, i purchased the game on gog but after i setup the sound and everything, i get a error saying "spawn error" something.
i can't also get sound because every time i setup the sound, set it at irq 5
when i test the sound, the whole setup program crashes.
what causes this? i fixed the sound but can't still get the game to run 😕
Reply 1 of 2, by gerry
is the gog version ms dos via dosbox or is it some port? having fixed the sound it seems you still have some dependancy missing - maybe gog forums contain a similar question?
otherwise, if you continue to have problems, it'll almost certainly work on your modern system with whatever launcher gog uses - not as much fun as using a pc 'of the era' i know
Reply 2 of 2, by Azarien
gerry wrote on 2021-11-01, 08:55:
One Unit Whole Blood is a DOSBox version.
