Reply 160 of 177, by Sphere478
ph4nt0m wrote on 2023-01-22, 03:02:
I see you still haven't got rid of those Sanyo CG capacitors. These are not even low ESR actually.
a capacitor upgrade would be a nice addition to this motherboard. Low priority atm.
Next time I build it, I may do this. It is currently in my motherboard storage.
Sphere's PCB projects.
Reply 161 of 177, by RayeR
Sphere478 wrote on 2022-01-21, 20:32:
I wonder if a interposer is possible to upgrade the legged footprint to a bga mount
Yeah it is possible but not easy to solder on board. I made it 2 years ago for LPC546xx MCU by NXP because of chip shortage on global market. I designed a board with TQFP package but then only BGA left available when time come to components ordering. Because I need to continue with FW development I designed a small 4-layer interposer that has BGA footprint on top side and TQFP counter pads on bottom side. I 1st needed to put solder on interposer pads and the board pads, properly align it and reflow with hot air. Then I measured if all TQFP pads are connected properly to BGA pads and use hotair again to solder on the BGA chip. It was a lot of fun 😀 I belive the same would be possible.also for bigger chips...
http://www.ebastlirna.cz/modules/Forums/files … erposer_760.jpg
Reply 162 of 177, by Sphere478
Very nice! Good job 😀
Reply 163 of 177, by Sphere478
Radeon 9800 pro with 9700 pro cat 3.1 drivers
K6-3+ 570 (modded from 2+)
Freeway ultra
How can I improve my score?
    1.03 MiB
Reply 164 of 177, by supercordo
Sphere478 wrote on 2024-01-21, 17:01:
Radeon 9800 pro with 9700 pro cat 3.1 drivers K6-3+ 570 (modded from 2+) Freeway ultra […]
Freeway ultra
No idea with that fuzzy picture.
Reply 165 of 177, by Sphere478
supercordo wrote on 2024-01-21, 17:35:
Freeway ultra
Sorry vogons takes forever to upload images from my phone and often errors out so I try to make them zoomed in as possible to get them to upload easier
I recalled previous experience with these via chipsets how much of a difference single sided and double sided made from a speed and stability perspective.
I did manage to find a set of 256mb x 3 sticks that gave 768mb stable that I was running for a few weeks now. But just decided to try 1 x 128mb single sided and 2 x 128mb single sided as a test.
So far 256mb 2x128 single sided has been the fastest. About to try 384mb
    1.07 MiB
Reply 166 of 177, by Kahenraz
I will sometimes use LitPhoto to resize my photos when uploading and it works very well. It can also do bulk operations on many files at a time, as well as the option to delete the original.
https://play.google.com/store/apps/details?id … coffee.litphoto
55.27 KiB
Reply 167 of 177, by Sphere478
Thanks 😀
I’m making progress!
This config is overclocked from previous 112mhz fsb 5.5x core 384mb of ram. 3x single sided pc150 pc150 pc133
I’m trying to recall if I made a cheat sheet for dip settings earlier in thread. Is there a 105 fsb option?
    1.27 MiB
Reply 168 of 177, by Sphere478
By the way, I have two geforce 3 ti 500s at my disposal but can’t seem to get them to work in 3d on one, seems to be a driver issue. And the other won’t post on this board
Reply 169 of 177, by supercordo
Sphere478 wrote on 2024-01-21, 18:58:
Do you have the memory interleave driver installed?
https://www.georgebreese.com/net/software/rea … v015_readme.htm
Reply 170 of 177, by Sphere478
supercordo wrote on 2024-01-21, 22:30:
No… 🤔🧐 you are using this? How much does it help? I’m gonna try it!
Okay, so I went tot he parent webpage but it won't let me download the zip. can you rehost here?
Reply 171 of 177, by PC Hoarder Patrol
Sphere478 wrote on 2024-01-22, 00:15:
Thru Wayback 😀
venabler_v015.zip
14.92 KiB
16 downloads
Reply 172 of 177, by RayeR
Try older driver version, maybe that you tried use 686 instructions (CMOV...)
Reply 173 of 177, by Repo Man11
I'm surprised that this motherboard doesn't have the option to enable memory interleave in the CMOS settings. I can confirm that the Breese patch works - I tested it with Windows 98 on my Epox board, which does have the option to enable it in the CMOS settings. With it disabled in CMOS, using the patch gave me the same small boost in memory bandwidth as having it enabled did without the patch.
Reply 174 of 177, by Sphere478
RayeR wrote on 2024-01-22, 02:16:
7.76
Repo Man11 wrote on 2024-01-22, 02:29:
Can someone modbin or something this freeway ultra bios to add the option?
Reply 175 of 177, by RayeR
Sphere478 wrote on 2024-01-22, 04:22:
7.76
OK, this is really old ver. I wonder it already supports GF3. I used such low versions with TNT2 these days...
Maybe you can try something a bit newer 1x.xx-3x.xx.
How exactly it doesn't work? Also have you installed latest AGP drivers for chipset? I remember that those crappy chipsets + AGP was a pain in the....
Reply 176 of 177, by Repo Man11
Maybe. I used Modbin to see if I could enable bank interleave on my Soyo 5EMA+, but it wasn't hidden, it wasn't there at all (and BIOS modding beyond that is above my pay grade). So I used the Breese patch on that board.
Reply 177 of 177, by Sphere478
RayeR wrote on 2024-01-23, 17:10:
OK, this is really old ver. I wonder it already supports GF3. I used such low versions with TNT2 these days... Maybe you can try […]
7.76
That driver is the one that gets the best frame rates, trying to get it to work
