Reply 40 of 124, by vstrakh
No crashes with updated version, full automatic report is done:
HWLOG_15.ZIP
5.19 KiB
41 downloads
The peripherals section in all versions reports "Keyboard controller: N/A", means it could not be identified or not detected at all?
I also wonder why -v (verbose) log actually produces smaller report. Seems the PnP sections are missing, and nothing really "verbose" is present 😀
Reply 41 of 124, by Mumak
Thanks for the feedback, I'm happy that this is resolved now.
"Keyboard controller: N/A" means it couldn't be detected.
Verbose mode is to produce the report file silently without showing the GUI/progress.
Reply 42 of 124, by Susanin79
Greetings,
Here is the fresh update for IBM 5160, running with 1.5 version.
Now the overall performance is better than in version 1.2. The drawing speed is the same, for example it takes 18 sec from program run till welcome about window appears. The longest step at this moment is ISA Bus scan, it takes 3 min. 1 min 45 sec takes LPT scan and 1 min 25 sec takes drive detection.
What was fixed in compare to previous run:
- now it can detect BIOS manufacture
- it can now properly detect MFM drive
Issues:
- math co-processor speed still shows wrong data - 102,7 Mhz
- no ISA cards was detected
- no FDD was detected
- it crashes when I try to run Videoadapter section. See video here.
Ready to test next versions )
    ibm 5160 v2.zip
    4.55 KiB
    45 downloads
Reply 43 of 124, by Mumak
Susanin79 wrote on 2021-11-29, 13:25:
Greetings, […]
Greetings,
Issues:
Thanks for the detailed report! According to the video you posted it seems it's crashing at "Checking: Trident, IIT". Is that right?
Reply 45 of 124, by keenmaster486
Oh boy. I've always hoped you would do this. Thanks!
I am in possession of an original IBM PC/AT decked out with a bunch of expansion cards. I can test the program on it later this week.
World's foremost 486 enjoyer.
Reply 46 of 124, by zyga64
Ok. Version 1.5 raport:
- CMI8330 PnP is now correctly detected ( I think this is the most detailed description I have seen),
- Cirrus Logic VGA now correctly connected to ISA bus (instead of MCA),
- when UM9008F is plugged in program still hangs at: Checking: GUS [port 210]
Strange behavior: when I'm checking Mainboard Info -> Bus Type: ISA -> ISA and other devices first time after starting the program
it shows both sound card and ethernet as: "NE2000 or compatible Ethernet Adapter" respectively at ports 0220 and 0300,
but exiting this screen (level up to Bus info) and returning, makes the sound card item disappear (only the ethernet card remains).
Of course sound card is still in Bus Type: ISA PnP
I'm attaching debug+report files for both situations (with and without ethernet card).
I can also check with RTL8019 ISA ethernet (in PnP mode and NE2000 compatible jumper configurable mode) and another sound card, if it will be useful.
    without_ethernet.zip
    5.25 KiB
    43 downloads
    with_ethernet.zip
    4.36 KiB
    44 downloads
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 47 of 124, by Susanin79
Mumak wrote on 2021-11-29, 14:34:
Yes, exactly right after the Trident IIT each time. Will try new version tomorrow. I need to use my 386 bace PC as a "proxy" to move files into XT. I decided to keep this XT as possible authentic as I can, so no any CF to IDE adapters is installed )
Reply 48 of 124, by Mumak
zyga64 wrote on 2021-11-29, 17:22:
Ok. Version 1.5 raport: - CMI8330 PnP is now correctly detected ( I think this is the most detailed description I have seen), - […]
- Cirrus Logic VGA now correctly connected to ISA bus (instead od MCA),
Thanks! This has given me sufficient information to filter out the false NE2000 adapter. I could also add reporting of the valid NE2000 adapter's MAC address in the next version.
Reply 49 of 124, by Susanin79
Mumak wrote on 2021-11-29, 16:23:
Posting v1.51 to hopefully fix 8087 FPU clock and display corruption on the IBM EGA adapter:
HWI16_15.ZIP
Here is the fresh tests. FPU clock now is fixed. Display test still fall with the different error right after Weitek. See video of crash.
Evgeny.
    89.06 KiB
    ibm 5160 v3.zip
    3.08 KiB
    39 downloads
Reply 50 of 124, by Mumak
Susanin79 wrote on 2021-12-01, 14:01:
HWI16_15.ZIP
Evgeny.
Thanks! Happy to see the FPU clock correct 😀 Is "Checking: Weitek" the last item you can see correct during the video test?
Reply 51 of 124, by Mumak
Posting v1.6 to:
- Hopefully fix display corruption during graphics card scan on EGA
- Remove phantom NE2000 devices on some systems
- Show NE2000 MAC address
[version pulled as there's a newer one]
Reply 52 of 124, by Susanin79
Mumak wrote on 2021-12-01, 14:35:
Yes, the last one before the program crash.
Reply 53 of 124, by mbsystem
Hi. Just for info or suggestion, in -Virtual 386 DOSBox- you can replace the S3 VGA Crash by 'unknown' or a message like : ' please try with HWINFO.EXE '.
I know this is not for a virtual environment.
    5.49 KiB
    No downloads
    HWINFO.DBG.TXT
    2.93 KiB
    41 downloads
Reply 54 of 124, by GuillermoXT
Very good i will test it on my Tandon 286 8MHz, 1mb ram, 3mb xms module, isa ethernet, SB16 CT2940 and TVGA9000A 512kb graphics running on xtide cf 1GB with Dos 6.22.
My Retrosystems:
PIII on GA-6BA running Win98SE
AMD K6 233 on GA-586HX with Win95
Tandon 286-8MHZ Running DOS 6.22 on XTIDE-CF
M326 486DLC + 4c87dlc (Dos+Win3.11)
ECS UM4980 AMD DX2 80 5V (Dos & Win3.11)
Reply 55 of 124, by andunn
Nice to see support for pre-386 systems. I tested v1.51 on my older IBM PS/2-s a few days ago.
On the Model 30 (8530-002) everything seems to work except "Video Information" - screen goes blank after checking for Matrox MGA. I can still quit the program by pressing "Esc" a few times and then the DOS prompt looks okay, but when i run the program again the display is corrupt (partially shifted to the right).
Model 30-286 (don't know the exact model, it's a bare motherboard) gives a fatal error when checking for GUS on port 250. Also, the "System Information" shows wrong memory sizes, the machine has 1Mb (4x256Kb SIMMs). Not sure if the machine type is correct or not, AFAIK the models 30 and 25 used the same motherboards.
The program seems to be lacking the MCA adapter detection part on Model 50 (8550-021), it shows the bus type as MCA but no adapters are listed. Otherwise seems to be working OK.
    reports.zip
    9.53 KiB
    40 downloads
    149.49 KiB
    143.46 KiB
    143.68 KiB
Reply 56 of 124, by Mumak
andunn wrote on 2021-12-02, 09:04:
Nice to see support for pre-386 systems. I tested v1.51 on my older IBM PS/2-s a few days ago. […]
Thanks! I'm analyzing those reports to see how can I fix/improve things. Just one question - on the Model 30 are you sure the video adapter problem starts right after "Checking: Matrox MGA-I, -II, -64"? Is it possible that there could be something else shown afterwards?
Reply 57 of 124, by Mumak
Posting v1.61 in a attempt to fix the PS/2 issues you've seen (except the hang at GUS check).
BTW, "IBM PS/2 model 25, 286-10, LW-type 37" and "IBM PS/2 model 30, 286" share the same PC Model IDs, the difference is in BIOS date. "06/28/89" should be the Model 25 according to sources, though not 100% sure about this.
Reply 58 of 124, by andunn
Mumak wrote on 2021-12-02, 09:24:
On the Model 30 are you sure the video adapter problem starts right after "Checking: Matrox MGA-I, -II, -64"? Is it possible that there could be something else shown afterwards?
Took a video clip of the screen with my phone and indeed it shows "MediaVision MVV452" before the screen goes blank. Couldn't see that before, it's only a few frames in the video and too fast to see with bare eyes.
Reply 59 of 124, by andunn
Mumak wrote on 2021-12-02, 10:30:
Model 30 still has the blank screen issue, wierdly the image corruption on next program launch does not appear every time.
Model 30-286 memory amounts are fixed and everything else seems to be OK too.
Model 50 MCA bus info is still not working, when I hit "Enter" an empty "MCA Slots Configuration" screen appears for a fraction of a second and then goes back to the "Bus Info" screen.
    248.33 KiB
    106.19 KiB
    reports_161.zip
    10.08 KiB
    42 downloads
