Reply 60 of 124, by Mumak
andunn wrote on 2021-12-02, 13:53:
Model 30 still has the blank screen issue, wierdly the image corruption on next program launch does not appear every time. Model […]
Mumak wrote on 2021-12-02, 10:30:
Posting v1.61 in a attempt to fix the PS/2 issues you've seen (except the hang at GUS check).
Model 30-286 memory amounts are fixed and everything else seems to be OK too.
Model 50 MCA bus info is still not working, when I hit "Enter" an empty "MCA Slots Configuration" screen appears for a fraction of a second and then goes back to the "Bus Info" screen.
Thanks for the report!
Posting v1.62 to hopefully fix both issues:
[version pulled as there's a newer one]
Please let me know the results.
Reply 61 of 124, by andunn
Mumak wrote on 2021-12-02, 18:42:
Video issues on the Model 30 seem to be solved and everything else looks OK too.
The MCA slots configuration screen now shows up on the Model 50. However, the adapters listed are incorrect - see attached picture of IBM's config utility.
    150.82 KiB
    123.08 KiB
    137.98 KiB
    135.95 KiB
    reports_162.zip
    6.11 KiB
    41 downloads
Reply 62 of 124, by Mumak
andunn wrote on 2021-12-02, 21:52:
Thanks!
Here's v1.63 to fix the MCA details:
Reply 63 of 124, by andunn
Mumak wrote on 2021-12-02, 22:26:
I have good news, everything works now!
Thanks!
    123.24 KiB
    ps2_m50.zip
    2.38 KiB
    36 downloads
Reply 66 of 124, by PC@LIVE
I think it will be very useful on the old-MB that I have on the bench, I will try to try it on the Siemens D1107 with PII 350, it is a slot1 with 440BX chipset, 128MB of ram, I have to add a sound card and see to connect an HD, currently I use the usual IDE-CF adapter, the memory card is 256MB with DOS (it was for a 386 or 486).
I have already downloaded the file, for the HWI16 version I will see in these days to fix the faulty power supply of the 286, I hope to be able to fix it, but this cannot be said if I do not start working on it.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 67 of 124, by douglar
I have a 12Mhz Packard Bell 286.
Thje system has a 1MB Trident 8900c
HWinfo16 v1.7 says:
                             HWiNFO16 v1.7
┌─────────────────────────────Video Information─────────────────────────┐
│ Video Chipset: Trident 9000i A/B/C │
│ Video Card: Unknown │
│ Video Memory Size: 1,536 KBytes of DRAM │
│ Video Card Bus: Unknown │
│ Video RAMDAC: Unknown or Standard VGA │
│ Video BIOS Manufacturer: Quadtel, TRIDENT │
│ Video BIOS Version: C3.0 │
│ VESA Support: Present (VBE 1.2) │
Reply 68 of 124, by Mumak
douglar wrote on 2021-12-26, 19:49:
I have a 12Mhz Packard Bell 286. […]
HWinfo16 v1.7 says:
                             HWiNFO16 v1.7
Please attach the HWiNFO Debug File (run with -d parameter). I need to check a few details why is this...
Reply 69 of 124, by GuillermoXT
This is a Debug file of my Tandon 286
Network : 8019AS
Graphics: TVGA 9000A
System Ram 1024 KB
XMS Card: 3MB
XTIDE-CF Card + 1GB Compact Flash Transcend
CPU: AMD 286 @8mhz
FPU: Intel 10MHZ running 5mhz
Seems to recognize as a compaq?
My Retrosystems:
PIII on GA-6BA running Win98SE
AMD K6 233 on GA-586HX with Win95
Tandon 286-8MHZ Running DOS 6.22 on XTIDE-CF
M326 486DLC + 4c87dlc (Dos+Win3.11)
ECS UM4980 AMD DX2 80 5V (Dos & Win3.11)
Reply 70 of 124, by Mumak
GuillermoXT wrote on 2021-12-31, 16:34:
This is a Debug file of my Tandon 286 Network : 8019AS Graphics: TVGA 9000A System Ram 1024 KB XMS Card: 3MB XTIDE-CF Card + 1GB […]
Network : 8019AS
System Ram 1024 KB
XMS Card: 3MB
CPU: AMD 286 @8mhz
Thanks, but can you please also either manually walk thru all screens or use -r parameter and generate a new report + debug files?
Reply 71 of 124, by douglar
Mumak wrote on 2021-12-26, 21:05:
HWinfo16 v1.7 says:
                             HWiNFO16 v1.7
Sorry for the delay. The floppy drive didn't want to work for a while.
Files are attached.
    PB286.zip
    4.44 KiB
    38 downloads
Reply 72 of 124, by Mumak
douglar wrote on 2022-01-05, 22:01:
HWinfo16 v1.7 says:
                             HWiNFO16 v1.7
Files are attached.
Thank you. This issue will be fixed in the next build.
Reply 73 of 124, by vstrakh
Is it ok to use this build on a 386 pc, or detection of cpu's above 286 was entirely removed?
I have a 386DX40 board with IIT 3c87 math coprocessor.
This app version does not show the cpu type or frequency, and misidentifies the coprocessor for Intel 8087 @ 122 MHz.
It detects the chipset correctly (UMC 82C491) and shows the audio card in the Peripherals section, but fails to show anything in the System Information->Bus Info section.
Reply 74 of 124, by Mumak
vstrakh wrote on 2022-01-21, 20:52:
Is it ok to use this build on a 386 pc, or detection of cpu's above 286 was entirely removed? I have a 386DX40 board with IIT 3c […]
HWiNFO16 is as per thread title only for 8086-286. For 386 and later use HWiNFO for DOS.
Reply 75 of 124, by twix
I have just ran the latest version of HWINFO16 on a IBM model 30 PS/2 (having replaced the 8086 with a Nec V30). The question that I have is whether the tool is able to report the IRQ assignments correctly. According to the information that I have been able to find, the model 30 8086 only has 8 interrupts (0-7). COM ports are on 3 and 4, HDD on 5, floppy on 6, and LPT1 on 7. HWINFO16 reports 16 IRQ's, but this does not seem right. I tried to run MSD on this machine, but it locks up when probing for the IRQ's. Any thoughts?
Reply 76 of 124, by Mumak
twix wrote on 2022-02-12, 14:28:
You're right, this doesn't seem to be reported properly. AFAIR, XTs have only 8 IRQs and this is not properly accounted for in HWiNFO16. I'll try to fix this in the next build.
Can you please post the resulting LOG and DBG files from HWiNFO16? I'd like to see how it worked and whether there's anything else needed to be adjusted.
Reply 77 of 124, by twix
Mumak wrote on 2022-02-12, 14:33:
Here are the debug and log files. They are a bit disappointing maybe. The debug file prints a list of actions, not the results. The log file is not complete, as in the peripheral section the process hangs on the detection of the GUS on port 210. I think that this particular failure has been reported before.
    HWINFOD.LOG
    16.21 KiB
    38 downloads
    HWINFO.LOG
    12.77 KiB
    40 downloads
Reply 78 of 124, by twix
twix wrote on 2022-02-12, 16:24:
Ah, I know see that the GUS problem may be caused by the presence of an ethernet card. I have an UMC UM9008F, so I will pull that and redo the check.
