TinyLlama (Vortex86EX SBC)
Reply 240 of 661, by Deksor
Not exactly, but it'd be more useful than what I suggested but in the meantime maybe this could be done
Reply 241 of 661, by Eivind
Deksor wrote on 2022-12-02, 17:38:
Quite a novel idea, Deksor! 😀 But unfortunately this could not easily be implemented with the current rev1.1 of the board.
That said, revision 2.0 will have a HIDman built in. A prototype of this is currently in production over at JLC... 😉
I'm still on the fence about whether to _also_ include physical PS/2 port(s) - I guess that will depend on how well the HIDman turns out to work with this system. We'll soon see...
The LlamaBlaster sound card
ITX-Llama motherboard
TinyLlama SBC
Reply 242 of 661, by Eivind
Heads-up: as of right now, the SOM-128-EX modules are back in stock over at DMP!
No VGA modules (yet) though...
TinyLlama SBC
Reply 243 of 661, by Deksor
The price has increased quite a bit though, it went from 38$ to 55 !
Can't wait to see what's coming for rev 2 😁
Reply 244 of 661, by tabm0de
Deksor wrote on 2022-12-02, 21:35:
All thanks to tinyllama haha
naa, nothing yet...
Reply 245 of 661, by tabm0de
Eivind wrote on 2022-12-02, 21:17:
Would been nice if vga was in stock since the shipping cost is so high 😀
Ps don’t miss my post about seabios version :p
naa, nothing yet...
Reply 246 of 661, by Eivind
tabm0de wrote on 2022-12-02, 22:20:
Try sending them a mail and ask! I'm sure it doesn't hurt to let them know their products are in demand, I believe they produce these modules in quite small batches.
The current rev1.1 BIOS is a slightly modified version of this repo, which is again a fork of the original SeaBIOS repo at around June 2014, which would have been approximately SeaBIOS version 1.7.3 - 1.7.4 I believe.
I have successfully tested the very latest version of SeaBIOS on the TinyLlama as well, when exploring the PS/2 emulation (see earlier in this thread), but it didn't seem to change anything we care about. I might update it to use that version later down the road, but it requires me to put in all my extra code (CPU speed, L1 cache config, boot tune, load/save from SPI, etc), possibly needing to update a bunch of stuff to get that working. Not a high priority right now, but it'll probably be done later.
TinyLlama SBC
Reply 247 of 661, by tabm0de
Eivind wrote on 2022-12-02, 22:39:
Try sending them a mail and ask! I'm sure it doesn't hurt to let them know their products are in demand, I believe they produce […]
Ye I can see why that wouldn’t be priority if it’s much to change, the hub solution isn’t a problem for me as long win 3 works haha as it isn’t really a mouse required fps machine serial ball mouse is all good 😀
naa, nothing yet...
Reply 249 of 661, by Aaron707
My parts have arrived! Time to start building! Thank you to @florian3 f0r selling me an SOM and VGA board. I have revision 1 of the bottom half of my case done. Going to do a test print later today and see if I got the spacing on things right.
    544.61 KiB
Reply 250 of 661, by tabm0de
Aaron707 wrote on 2022-12-10, 20:14:
Looks nice 😀
naa, nothing yet...
Reply 251 of 661, by Aaron707
Eivind wrote on 2022-12-02, 18:09:
Quite a novel idea, Deksor! :) But unfortunately this could not easily be implemented with the current rev1.1 of the board. That […]
What are dimensions of 2.0 PCB? Pic?
I printed a bottom and finished designing a top. Bottom was good, but needed some changes. Once I soldered my pcb and components some of the bottom capacitors and pins were hitting the standoffs. Going to test my board next then print the case again.
    191.68 KiB
    213.9 KiB
Reply 252 of 661, by Eivind
Aaron707 wrote on 2022-12-12, 18:51:
The prototype board is 100x100 mm. It has two additional daughter boards on the top side, a tiny HIDman implementation and a Wemos D1 Mini (ESP8266). I'm currently testing the HIDman, haven't gotten to the modem/ethernet over wifi stuff yet. If all turns out well, I should be able to get everything down to about 100x77 mm, but not sure if it's worth another spin. Might keep the prototype form factor.
I'll post pictures when I've soldered everything together, just playing with the USB HID stuff for now.
Edit: oooh, and I forgot to mention - almost all components, both smd and tht, both sides, are soldered by JLC now. That is very nice for someone who doesn't exactly love soldering. 😀
That looks soooo good! 😁 What CAD software are you using? I wanna make one when you're finished! Just gotta find a filament with the proper oldskool beige color! 😉
TinyLlama SBC
Reply 253 of 661, by Aaron707
I think my case size should just fit 100x100 by mounting the fan somewhere else or omitting it. Great news about less soldering, but I think that is half the fun as well.
Just tinkercad because its free and super easy to use. It has its own set of shortcomings and limitations but is good enough for simple stuff. I have been getting better the more I use it. But don't want to go back and redo my design completely to make the improvements I learned.
I ordered some of this beige PLA to try last night. Its suppose to match Amiga 500 beige exactly:
https://www.printedsolid.com/products/jessie- … x-1kg-beige-500
The other option is to just paint the case. I found the rustoleum ivory bisque is a great computer parts color. I painted my cheap mechanical keyboard case with it recently and it looks very good.
Reply 254 of 661, by tabm0de
Aaron707 wrote on 2022-12-12, 20:39:
I think my case size should just fit 100x100 by mounting the fan somewhere else or omitting it. Great news about less soldering […]
So Aaron707 can i throw money at you to maybe order one for me? 😉 they dont ship to sweden 🙁
naa, nothing yet...
Reply 255 of 661, by Eivind
tabm0de wrote on 2022-12-12, 20:56:
Huh! I just sent them an email asking if they'd be willing to make an exception OR knew where I could get a similar color. Instant reply, no to both. What a weird business model, not wanting to make money.
TinyLlama SBC
Reply 256 of 661, by tabm0de
Eivind wrote on 2022-12-12, 21:20:
I asked them few days ago, the owner likes retro pc that’s why they have the colors 😀
“ im sorry not at this time i believe there is something in the works but we do not have anything definite yet ”
When I asked for shipping to Sweden 😉
naa, nothing yet...
Reply 257 of 661, by Aaron707
Possibly, I guess I should have ordered more than one to get their free shipping! Hoping to have it by this weekend to test out.
I wanted to try this, but shipping to USA was high: https://colorfabb.com/silk-grey-ral-7044 It is the same color as vintage macintosh computers.
I picked up some cheap "bone white" PLA from amazon but it doesn't have enough pigment and is see-through on thin surfaces but does look decent enough.
Reply 258 of 661, by tabm0de
Eivind wrote on 2022-12-12, 19:04:
Maybe in the future we can have parallel or simple scsi controller onboard 😉 so we can run our original cd games 😜
and ye sadly only ports that does take the space more then the components that are required 😒
That is if there isnt any real good fakecd's out there 😀
naa, nothing yet...
Reply 259 of 661, by NRoach44
tabm0de wrote on 2022-12-14, 07:25:
I was thinking of making a modified TinyLlama with a PC/104 header, mainly for the flexibility allowing me to make other weird custom cards to slap onto it. It seems to be quite a versatile interface, with a not-huge footprint too.
Maybe I've seen too many of Rasteri's videos....
