Adding 3.3v to pci adapter(Released)
Reply 180 of 192, by Kahenraz
I recommend a POST code diagnostic card. They aren't expensive, and you won't cry if blows up. It will also display an LED for the 5V rail.
You'll still need a video card, so many buy a cheap one. The Chinese Rage XL cards on eBay all require 5V and won't boot without it.
Lots of cheap Rage XL PCI graphics cards for Socket 7 on eBay and Aliexpress
Reply 181 of 192, by Sphere478
NachtRave wrote on 2023-02-19, 12:37:
LOL. That was just a random piece of solder wire that had fallen there. I just didn't catch it in time for the photo, haha. :3 […]
Sphere478 wrote on 2023-02-18, 22:09:
What is with the wire laying on the mobo where you tap for the psu?
🤣. That was just a random piece of solder wire that had fallen there. I just didn't catch it in time for the photo, haha. :3
Well, I worked up the courage to test it... And, I got a post beep! I immediately turned it back off, cause, me'sa scared. :3
I guess that means that I just now need to hook up a monitor to it and test but hearing that post beep and not seeing any magic black smoke pop off as soon as it was turned on is an amazing sign.
I mean, without the mods, it wouldn't even post beep. It would do a vid-card-not-detected beep code, so I am definitely thinking this may actually work. I just need to hook it all back up now and make it nice. I also had an AWE64 Gold audio card that I wanted to put alongside this orpheus.
Awesome news! Fingers crossed! ^ Post card is a good idea 😀
Sphere's PCB projects.
Reply 182 of 192, by NachtRave
Oh, it posted just fine, I just didn't have a monitor hooked up. I've been knee deep in coding for other things so haven't had as much time to devote to this just yet.
Next step is getting my scope on it and checking out that waveform under load. Now that it's posting, it's just a matter of seeing how the ripple pattern looks when gaming. I am super hopeful that the Nvidia 5500 card will win out though, so far so good!
Reply 183 of 192, by Sphere478
Great news! :p
Reply 184 of 192, by NachtRave
So it looks like it definitely boots up and everything, but it also looked like it may have some drop out after running for a short while. Here’s where the current waveform stands on the scope. Might experiment with adding a few extra caps on top of the 0603s I have.
By drop-out I mean screen turns off and you get the beep-code for missing video card upon reset. First time I ever saw a computer do that but I guess that's how it works when your video card says nopity nope. I take that it isn't filtered enough? Hmm...
Any tips/help with what settings I should turn on with the scope? Tried to the picture when it had finished doing an averaging window run (so you see some valid avg/min/max readings)
Another option is to start work on another proto-board for a pentium style cap-field for filtering. Basically just a bunch more of the small ones. A field! A field of caps to count! Uh ha ha ha! =p
Update: Okay, so definitely think I have narrowed it down to simply just heat - those LDOs produce a lot of it! It gets pretty spicey hot, so I suspect that it may be dropping out due to such. May need to design a little fan mount for it. :3
    1.33 MiB
    Video card bios screen (apologies for cutoff by OSSC overlay)
    1.09 MiB
    Scope view of 3v3 signal off DX4 Overdrive circuit. Voltage is ~3.347 on meter, 5v running ~4.8v
Reply 186 of 192, by Sphere478
You could build the pico psu adapter and just run a wire from it. Or use a male sata pigtail. Or use calamitylime’s power supply: (see pcb projects in sig)
Again, I’ll remind everyone, the capacitors probably aren’t going to be a one size fits all, and most people probably are fine to just not use them.
Each card will have its own noise that different caps may be ideal for.
Reply 188 of 192, by Sphere478
Kahenraz wrote on 2023-02-26, 04:49:
What can we do to measure for and select the appropriate capacitor value?
Install on desired motherboard, install desired card. Hook up to an oscilloscope and see what frequencies you are seeing your noise at.
Long story short, different capacitors will respond to different frequencies differently.
It is best to get your reads from as close to the item you are trying to stabilize as possible. Perhaps from the card even.
Here is a quote from a convo I was having with a friend of mine who understands this a little better.
71.67 KiB
There is also the try it and see approach. If you buy a capacitor assortment you could play with the values till you had the cleanest signal.
Reply 190 of 192, by Sphere478
megatog615 wrote on 2023-07-17, 10:12:
Is it not ideal to have a similar design to the ISA Voltage Blaster?
Many mobos don’t route the signals
Reply 191 of 192, by kingcake
Sphere asked me to post this here:
I made a mini PCI Voltage Blaster for +3.3V. This is useful for those +5V keyed cards that need +3.3V to work. Like the "new" Chinese made ATI Rage XL PCI cards all over eBay.
As noted above, many +5V only boards do not route the +3.3V pins. So you'll need to bodge a few of the +3.3V pins to each other on the back of the mobo.
Also, this mini version is only good for about 500mA max. Won't work for PCI GPUs that need a lot of power.
This is open source: https://github.com/chadr/PCI-Voltage-Blaster
676.46 KiB
I made 10 of these up when I was testing out stuff. If anyone wants one lmk. Just cover postage and I'll send one or two out.
Reply 192 of 192, by Sphere478
Very nice. :p good job! 👍
