Reply 20 of 23, by octopus
Shreddoc wrote on 2022-02-07, 20:47:
Correct. Dangerous Dave does not support sound cards. […]
octopus wrote on 2022-02-07, 19:22:
Dave: speaker sound
octopus wrote on 2022-02-07, 19:26:
setupds tells me the DNA is not available
Please show us a photograph of that error message.
You where correct to doubt me: I reinstalled the YMF and it actually says 'Can not detect DMA at channel 1'
Sorry for providing the wrong info.
I took three pictures, one of the output of setupds /s , one of the configuration in the DS-XG utility and one of the error message.
Changing the DMA in SET BLASTER, the .ini and in the config file doesn't change the error, I tried DMA 0, 1 and 3
155.1 KiB
353.32 KiB
334.66 KiB
Reply 21 of 23, by Joakim
Some people report that PCI sound cards can vary between slots on the same motherboard, might be worth a shot.
Compatibility seems to vary a lot between motherboards, some chipset just don't work, but should work at some motherboards up to around pentium 4 era.
Reply 22 of 23, by Shreddoc
octopus wrote on 2022-02-06, 09:39:
The Diamond Edge is indeed a bit of a special thing, I have the extension card with 2 ports for the Sega Saturn controlers. I'm keeping it around for when I run into one of those controlers.
Coincidentally, LGR has just taken a look at this. So, the value has just risen 🤣
Reply 23 of 23, by octopus
Shreddoc wrote on 2022-02-08, 22:51:
That's pretty awesome actually!
And I thought it was a weird unpractical card when I found it..
Joakim wrote on 2022-02-08, 16:57:
Yeah, I'm hoping to try the other slots this weekend
