Reply 20 of 36, by Sphere478
debs3759 wrote on 2022-03-04, 02:13:
I've sent him messages before, no reply.
Sphere's PCB projects.
Reply 21 of 36, by debs3759
try messaging naked1300 on the CPU-World forums. He'll get an email to his hotmail account (which I can't give out, as I only see it as a moderator). He may no longer use the email on his website. He was last active on CPU-World last March.
Reply 22 of 36, by Sphere478
debs3759 wrote on 2022-03-04, 02:21:
sent 😀
thoughts on how to go about the multiplier question?
Reply 23 of 36, by debs3759
Sorry, no.
Reply 24 of 36, by weedeewee
the cpu galaxy guy can also be found on facebook.
I've several times seen him post his videos there.
can't recall the name though
think it was peter something...
edit: do a search in the vintage pc enthusiast group on fb
Do not ask Why !
Reply 25 of 36, by Sphere478
I recently re did the mods to my tillamooks and in doing so, all the multipliers now appear to be accessible to me.
At 66fsb
I can go through the different jumper settings and attain these results
133mhz (2x)
166mhz (2.5x)
200mhz (3x)
233mhz (3.5x)
266mhz (4x)
Unfortunately no 4.5x is among them.. 🙁
And all three jumpers seem to be having an effect.
My best guess is that Intel locked the 4.5x setting on my chip. How they did that still remains a mystery. But it doesn’t seem proper pull ups and pull downs and trying all the different jumper configs are the answer.
For the time being I believe the 4.5x multiplier may still and possibly forever be out of reach for 266 and lower tillamook owners..
If anyone has a 300mhz model, I want to talk to you.
Reply 26 of 36, by Sphere478
I just talked to someone who has a broken green pcb style 300 they are saying that the chip defaulted to 4.5x when it used to work. I’m not sure if that means the other multipliers didn’t work or not. Or if the multiplier this person was using just happened to be the right one, but their experience seems to verify that a 4.5x multiplier exists on the 300 and suggests tillamooks in general may have it internally, though as no way to unlock the multipliers on mmx p55c chips has yet been discovered, it is assumed that these may also be beyond our reach
Reply 28 of 36, by Sphere478
rmay635703 wrote on 2022-04-13, 15:50:
Golden tigers didn’t use to be very expensive,
Would have to analyze the pinout and decap but I’m guessing the fixed multiplier makes sense in a laptop
Well my plastic 266 has all sorts of multis that I can set
Reply 29 of 36, by rmay635703
Sphere478 wrote on 2022-04-13, 19:47:
I guess that’s the difference between a surface mount laptop chip and a traditional chip used in embedded/industrial applications.
Reply 30 of 36, by Sphere478
rmay635703 wrote on 2022-04-13, 19:49:
I have a pcb style 233 but I dare not install it as pins are damaged. Would be interesting to confirm it.
Reply 31 of 36, by Sphere478
https://forum.vcfed.org/index.php?threads/dua … llamooks.74956/
Reply 32 of 36, by 0xCats
So as someone currently in the process of designing a dual socket motherboard and intimately familiar with the Pentium design I have been asked to add some details here.
When Intel went about designing the Tillamook processor they where not developing the next great Pentium CPU, it was developed in a matter of months as a stopgap Ultra Low Power mobile solution for embedded systems and bridging the cost gap to the complex and high power Pentium 2 Mobile processor board.
As such the Tillamook is a very low effort and I mean this in the truest sense die shrink of the Pentium MMX from .350 micron to .250 micron with many features and corners being cut to eliminate complexity and reduce power consumption.
This is where I reference the given documentation for the vanilla Pentium embedded "Intel Embedded Processor with voltage Reduction Technology" as Intel engineers themselves called it, showcasing these signals already removed.
55.85 KiB
160.32 KiB
Further information about specifically the processor can all be found at Section 3.1 within Intel Document 273203-001 titled "Embedded Pentium® Processor with Voltage Reduction Technology" as intel themselves called it.
And then for Tillamook, this being the "Low-Power Embedded Pentium® Processor with MMX Technology".
Reference Intel Document 273184-003 Section 3.1.
I have also gone about testing associated control registers for this signals on a Tillamook processor, and interaction with these results in hard lockups, resets or nothing at al..
182.3 KiB
The signals and their related control registers have all been removed completely.
There are two types of devices, those that know they've been hacked and those that don't yet know they're going to be hacked.
Reply 33 of 36, by Sphere478
Yeah, I’m known for beating a theory to death to wring out all hope, but Even I think there isn’t much hope here.
These registers you are talking about, that’s through software? So you’re saying it’s not only missing the pins connection but the functions are shut down in the core? I recall I believe finding some connection on a few pins. So not all are technically NC But it doesn’t matter as you say as others are totally open, And the result of whatever they did is obviously no smp, and there doesn’t appear to be much(anything) we can do about it.
I’m still trying to figure out what’s going on with the 4.5x multiplier though. Best I can figure, intel locked it out like they did the 3.5x on the (not all). pentium mmx 200 for example. Anyway, as far as I can tell there IS a 4.5x multiplier, it does exist.
But I don’t have a 300 to experiment with.
Another interesting note is the two 233 tillamooks I have have the 4x unlocked. Which is odd.
Reply 34 of 36, by 0xCats
Yes they are totally non functional on the the processors I've tested.
They also don't output the correct expected signals on PBGNT, PBREQ, PHIT, PHITM and and the DPEN doesn't drive the D/P signals appropriately to indicate dual processor or active processor mode.
The pins are just floating or High/Low with not even noise coming out of them.
Reply 35 of 36, by Sphere478
0xCats wrote on 2022-06-05, 13:53:
Great info. Thanks catsay.
Edited last post
Btw, yours is a film chip right? Mine are plastic like desktop mmx chips
Reply 36 of 36, by 0xCats
Of note also is the issue that the Tillamook CPU's where largely first manufactured for the TCP320 thin film carrier package on which the private bus signals are absent.
These where then also packaged into the PGA carrier form.
As such the actual connection to the die for the private bus signals is not exposed at all.
I would have gone as far as modifying/micro-drilling a carrier package to get access, but it's just not on the table due to the package not having them wired out.
