Socket 5/7/SS7 (Motherboard) Tweaker (Released)
First post, by Sphere478
Related projects:
Sphere's PCB projects.
Edit: thread rename
the thread has morphed into a pcb project
the goal of the project is to try and combine all the known tweaks for socket 5/7/SS7 onto one pcb that allows the user to implement or fully disable all these mods with the flick of a switch
First off, I'm going to opensource this, I'll post incremental Files as the prototypes develop feel free to use them or modify them as you wish or see fit. (and at your own risk of course) but it is probably unwise to order/use any versions that have not been prototyped in physical form and confirmed to be working without error first.
Resistor values:
-WB/WT
observed to work in WB with 1k pull up on asus p5a 1.05, 1.06. (pull down not testable on p5a 1.05, 1.06 as board defaults to this value anyway.)
behavior unknown on other boards
-BF0,1,2,Tillamook BF2. (pull up)
intel specs pull up at 2.2k(or less),
2.2k observed in action on tyan s1564,
kingston interposer observed in action at 330-ohm,
330-ohm observed working in tillamook l2 cache thread
personal note: higher the better, try 2200-ohm first
-BF0,1,2,Tillamook BF2. (pull down)
intel specs pull down at 500-ohms(or less)
kingston interposer observed in action at 25-ohm,
personal note: higher the better try 100-500 ohm first
-vccdet:
0-ohm shown working in tillamook l2 thread (requesting testing to find a higher working safer value)
-BRDY(c):
- ADS(c):
Latest Gerber:
Re: Socket 5/7/SS7 (Motherboard) Tweaker
OP:
Bf0, Bf1, Bf2 Multiplier Mod
It’s about time we had a thread with a better explanation/guide for this mod
I’ve seen it referenced in several threads (forget which ones) but maybe I missed it, but no really good guide about how to understand what is going on there or what needs done. I think with more understanding, this guide could be used on any s5/s7/ss7 motherboard (if needed).
So firstly, I myself want to understand more of what is going on here. Then, I will update this post with a guide on how to add full SS7 three register multiplier support to any motherboard
71.27 KiB
So here we have socket7 (this, I believe will work also on socket 5, though most, or all the chips that use these higher multipliers won’t work on socket 5 because of the single plane voltage.)
And here are the locations of the famous BF(x) pins:
168.47 KiB
I need to understand how these multipliers are programmed.
pull up?
pull down?
open ?
Do they accept one, two, or all three of those signal types?
Clues:
(Solved) Cyrix 400gp/366gp multiplier settings
More clues:
Re: Tillamook 266MHz and working L2 cache?
On the tillamook, it seems at least one of the signal types is discovered by pull up (to 3.3v). Is the other open or pull down?
More clues here:
Kingston TurboChip socket 7 voltage regulator related questions
Re: Kingston TurboChip socket 7 voltage regulator related questions
^so according to this, pull down to gnd is confirmed.
And I think I recall in some of the other posts that referenced a bf mod the problem was that the pin was either not pulled up or not pulled down and the solution was to pull it up or down via resistor.
So
Since it seems that switch on the kingston interposer is meant to pull those signals to ground as the switching mechanism for programming. And my motherboards don’t use 3 pin jumpers for the bf signals, simply on or off.
I am assuming that the signals are meant to be pulled high via resistor, and for programming direct shorted to ground via jumper?
Edit:
On my interposer I am seeing 25 ohms to ground when switch is in on position
But I’m not discovering any connection to anything when the switch is off, suggesting the registers accept open as a signal.
Which is kinda flying in the face of the tillamook extended mod.
Edit2:
Okay, I think I’m understanding more here
I’m playing with the interposer without a motherboard here
I have 330 ohms to vcc3 (3.3v) which is pass through from the motherboard which explains why I have nothing there when switch is open (no mobo)
A quick pop into a mobo and there it is, plain to see 3.3v (passing through it’s assumed, the 330 ohm resistor)
So I believe it’s now figured out.
BF0, BF1, BF2 are programmed via pull up or pull down using a 25 ohm switched to ground and a always on 330 ohm linked to VCC3 (3.3v) which means that the tillamook extended mod is dangerous if installed into a ss7 mobo and pulled to ground via switch
Reply 1 of 115, by Sphere478
Okay, with latest developments in the tillamook thread I am more fully understanding this,
It seems,
You want to be sure that BF0, BF1, BF2 all show about 330 ohms or so to VCC3 (3.3v)
I believe that will solve some of the issues that some mobos have with setting higher multipliers namely socket 5 boards (Can anyone confirm?)
Next, you want about 25 ohms on your three switches to ground (vss). And obviously you just add this switch to your BF2 pin on older mobos.
Reply 2 of 115, by Sphere478
25.67 KiB
okay, I think I got it
how's it look? that look right?
of course any vss or vcc pin can be substituted for one another (respectively)
Edit: I’m a dumbass and connected them all together.. 🤣
Reply 3 of 115, by Sphere478
I updated the diagram top show the WB/WT mod also. (from K6-2/3+ Success on Asus P5A 1.06 - simple mod)
26.31 KiB
This gets me to thinking, maybe we could make a small pcb that we can solder on the back of the board with little dip switches and smd resistors on it
Kinda like this Re: Adding 3.3v to pci
Btw, we may be able to change the resistor values on the bf mod to 1k and 10k or 100 and 1000 I suspect that the low values I saw on the kingston aren’t as high as will work. And higher is better, (safer) one might assume that values that work for wt/bw should also work for bf
Reply 4 of 115, by Sphere478
Are there any other mods that could be added to this theoretical pcb?
https://www.pchardwarelinks.com/586pin.htm
Description of pins
Seems there is some image quality loss on the modified image, so here is a
Higher res pic:
71.27 KiB
KEN#, CACHE# Cache pins may be for enabling or disabling cache. It could be added.
SMI#, SMIACT# could be used to set SMI (No Idea of this would help with anything)
BHOLD, idk if this can be activated by a pin but some mobos have a special bus option for cyrix chips.
There are several things listed for dual processor functions on intel,
One in particular interest. Is how might we be able to set redundant processor mode. Perhaps by enabling of a signal on one of these pins?
Reply 5 of 115, by Sphere478
487.2 KiB
Catsay shared this^
So pull down should be 500 or less
And pull up should be 2.2k or less
Reply 6 of 115, by Sphere478
ilembitov on discord just used the guide to do this to a pentium mmx 😀 and says it’s working.
It appears they are pulling bf1 to ground which should be relatively safe, but a higher ohm resistor may have been another approach that may have safety benefits. (The kingston used 25-ohm, the intel doc recommended 500 ohm or less for pull down, where as the kingston pulled up with a 330 ohm and the intel doc said less than 2200ohm )
261.71 KiB
I also re did my tillamooks
1.87 MiB
The tillamooks put bf2 one pin in toward the core so a link needs to be run between it and the normal position.
Many motherboards, specifically socket 7 (non super) don’t pull the bf2 pin high. So the 0 ohm link isn’t enough to make it work. It also needs to be pulled high. But a 0 ohm link to bf2 would not be a good idea, if you were to pull bf2 low you would the. Have a short.
So you must use a resistor I used a 330 ohm like what I observed on the kingston interposer.
I tried it in my socket 7 mobo and 266 4x setting is working when the motherboard is set to 2x without any need to add a option to pull bf2 to ground.
Some tillamooks had a 4.5x multiplier, I am wondering if pulling it low will show that setting. (Something I will experiment on later)
I’d like to get some help in this thread with a pcb project that can simply be soldered to the back side of the mobo and would have smd resistors and dip switches. Or jumpers.
Reply 7 of 115, by Sphere478
I’m curious, about something…
The 233mmx supported 2x-3.5x
But
Later on the tillamook intel thought to put the bf2 pin here: (shown is the 233mmx p55c not tillamook diagram)
84.7 KiB
The tillamook supports multipliers up to 4.5x
It’s possible that intel had planned on this prior to the tillamook, but never implimented it. Especially given that your typical pentium mmx can often handle 266 mhz some even 300mhz
….. any chance the 233 mmx p55c ended up with something there on that pin that we don’t know about? (Because ss7 mobos dont use that pin, and it’s marked as n/c, it may have gone un noticed) I know it says NC. But we could confirm..?
Tillamook SMP and multiplier unlocking investigation thread.
In this thread I discovered a few pins marked NC were actually connected to something.
It’s a long shot but…. Easy to try.
Reply 8 of 115, by H3nrik V!
You'll need separate pull up and pull down resistors per pin. The diagram you show is effectively shorting all three BFx pins, making all have the same level
Reply 9 of 115, by Sphere478
H3nrik V! wrote on 2022-03-20, 09:50:
Oh okay, so the pull up resistors should be on each line? Good catch. Thanks. I’m ashamed to say I missed that 🤣 it’s so obvious.
A special thanks to computerguy096 for testing the tillamook bf2 pin (but on a p55c) to see if there was a hidden bf2 pin on the p55c
He saw nothing but a open connection 🙁
Next let’s see if we can find the fabled 4.5x setting on the tillamook by giving bf2 a pull down
Reply 10 of 115, by Sphere478
how's this?
27.5 KiB
ugh, I wish I could upload bitmaps
As for the pcb, this also could be implemented (tillimook mods)
I’m not sure if any of these links may interfere with different model processors though… obviously they don’t seem to be of any harm in different mobos when a tillamook is used.
There are some reports of people needing to disable some of these mods on tillamooks to make them work right from one mobo to the next. So making them switched may be a good idea.
202.61 KiB
I also got to thinking that castellated holes could be used to recess a dip switch block as low down as possible for more clearance so as to allow motherboard to be more easily mounted
another idea, remote switches so that they can be more easily changed in a case
Reply 11 of 115, by wiretap
Here's a KiCAD v5 PCB-only file you can mess with. I also generated the gerbers in there too. The board outline will probably have to be brought in closer to the pins to clear the ZIF lever.
If you were to build this, I'd recommend milli-max individual pins soldered through the board so it can go into the ZIF socket on the motherboard easily, then the CPU would be on the top side PGA style.
socket7-mod.zip
290.97 KiB
99 downloads
My Github
Circuit Board Repair Manuals
Reply 12 of 115, by Kahenraz
I just saw this thread, but it isn't clear to me as to what this mod actually does. Would someone please summarize it for me or link to another relevant thread?
Reply 13 of 115, by Sphere478
wiretap wrote on 2022-03-20, 19:15:
socket7-mod.zip
I was figuring this would be soldered to the BACK of the board 😀
Like the pci slot thing I linked
Which brings up another thing,
We should put a castellated edge with a 3.3v tap for those 3.3v slot things
But lower profile outline is a good idea.
Many, all of the holes will have to wider so that they can go around the solder domes and then solder can be poured into the ones we wish to connect to, many of the others can simply be left not plated as to make trace routing easier.
Kahenraz wrote on 2022-03-20, 19:21:
I just saw this thread, but it's it clear to me as to what this mod actually does. Would someone please summarize it for me or link to another relevant thread?
Did you mean that it “isn’t” clear?
Basically there are several mods you can do to socket 5/7/ss7
I’ve linked to several of these threads
One makes the p5a mobos work better by toggling wt/wb (which can be handy on other mobos as well.)
There are also mods that make tillamooks work on desktop boards, issues there are voltage detect, l2 cache, and multiplier pin issues
We can also tap the cpu for 3.3v for the pci slots, especially if the cpu is dual plane. The 3.3v is over powered for a dual plane cpu so there is amperage to spare and can be used for the pci slot
And finally there are the multipliers.
There are four pins that I am aware of related to this, (three normal ones, and one for tillamook)
On many motherboards eapecially socket 5 bf0/bf1 aren’t properly pulled high, it’s a easy fix, and on socket 7 bf2 isn’t pulled high. Again a easy fix.
My goal is here to combine all these into one easy to install device that simply solder a few points on the back of the motherboard and presto, you now have not only the mods but also ways to shut them off and change their settings via switches.
Reply 14 of 115, by Sphere478
Some notes:
The voltage detect mod should probably have a resistor pad and a switch
Cache mod #1 should have a pad and a switch
Cache mod #2 should have a pad and a switch
I believe the tillamook bf mod might be able to just be a link, but to be safe we should give a pad and a switch.
The bf2 tillamook resistor mod will be addressed at the same time as the bf0,1,2 mods
The last schematic should be good for the bf mods
We will have to do some digging into how to implement the wt/wb mod in a way that will work with all mobos.
My consern is the mobo probably already has pull high and pull low resistors for it and we will have to over power them.. (while the system may be pulling the opposite way)so perhaps pads for both, and values can be determined later? It seems that a double throw switch is required here to over ride the existing pull up/pull down signals? Am I right?
Also another concern is the affect of tillamook mods on other processors
Reply 15 of 115, by H3nrik V!
Sphere478 wrote on 2022-03-20, 10:41:
how's this?
You need 3 separate 25 Ohms as well 😀
[Edit; had posted my reply inside quotation]
[Edit 2 - Never mind, you don't need, I guess] 🤣
[Edit 3] You might not need 3 separate pull-downs per se, but you'll might experience unexpected behavior from having one shared, as current through it will change depending on how many switches are closed, i.e. better safe than sorry.
Reply 16 of 115, by Sphere478
H3nrik V! wrote on 2022-03-21, 06:20:
You need 3 separate 25 Ohms as well :) […]
how's this?
Yeah, I was figuring that one would do, I think the kingston is wired like that. But may as well add 2 more what can it hurt…
Can anyone think of any mods that we have missed?
Reply 17 of 115, by Sphere478
Edit: an image of the prototype from wiretap
1.94 MiB
new schematic
103.45 KiB
. check me for errors. I couldn't decide if the wt/wb should be a tripple throw so it had a neutral position or if it should be two switches seems like two switches is best because it is easy. since it has resistors that should make it safe incase both are turned on. so I think this should work.
I haven't put in resistor values yet.
I made the bf more complicated but I like that this way everything on the board can be totally disabled just by flipping a switch and go totally passive
everything has resistor pads, whether they need it or not. I'd hate to find out later they were needed and not have them (if you don't feel like installing them bridge it with solder)
this all means 12 switches. gonna get a little crowded, but I think it's doable.
does anyone else have a suggestion for mods needed?
I assume there isn't a problem combining all the vcc3 into one rail and tapping it for pci 3.3v power (when using a dual plane cpu)
For use with these:
Reply 18 of 115, by Kahenraz
I did the resistor mod on my ASUS P5A recently, but a dip switch on the CPU would be a lot nicer. I would rather not have this bodge on my board if it can be moved to the CPU. That way it can be easily enabled or disabled for testing.
Reply 19 of 115, by Sphere478
Kahenraz wrote on 2022-03-21, 13:46:
The idea is to have this on the back of the motherboard
Alternately, eventually, this may be able to be incorporated into catsay’s power leap interposer that adds cache.
It’s not impossible though that a version of this couldn’t be added to the cpu it’s self but the pcb would have to be very thin
There is just more room for switches on the back of the mobo, also breaking out the 3.3v for the pci is a secondary goal
“ Cat, what resistor values should be used on my schematic?”
Catsay wrote:
 330Ohm and 1Kohm should be fine
For other pullups/downs than BFx you can also use like 10K
The important thing is though that fast pins that get latched after reset (used as strap bit value initially and then for fast data transfers) use 'fast' resistors, this meaning low value resistors
