Reply 20 of 90, by Grzyb
VGM files can contain music for various sound chips.
Universal VGM player would need to emulate all the chips.
I guess Mod Master doesn't emulate anything, and can only play a file if matching hardware is present.
BTW, there was an idea to emulate CMS using OPL2 or OPL3, but it seems it wouldn't sound 100% correct - Idea CMS emulation via TSR
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 22 of 90, by FreddyV
davide.guida@gmail.c wrote on 2022-04-18, 05:04:
It's the VGM you put in the zip file. GB_MONI1.VGM Audio card is a Soundblaster 16PnP, my PC is an Amstrad PC2086 XT 8MHz. The […]
The error is : Replay error: CMS not found.
Thanks
Hi,
It is normal this file is for CMS/Game Blaster.
Even if a CMS chip is present you need to declare its I/O port in the devices config menu.
There is no CMS in a sound blaster 16
Reply 23 of 90, by matze79
FreddyV wrote on 2022-04-21, 05:03:
The only .MOD player supporting VGM. 😀
Ah ok 😀
Does it play native, or call external programs like sbvgm ?
Reply 24 of 90, by FreddyV
matze79 wrote on 2022-04-22, 18:31:
Ah ok 😀
It is native, AND use SBVGM for not supported devices/Files.
Just place SBVGM in the same folder.
Reply 25 of 90, by ltning
FreddyV wrote on 2022-04-05, 06:14:
ltning wrote on 2022-04-04, 18:00:
It doesn't seem to see more than 1MB on GUS PnP/InterWave .. is this known?
Yes, not implemented.
For the moment, I never used a module with >1Mb samples :)
It would be pretty impressive to see a 286 play back a 8MB XM file :D
Do you own or have access to a PnP so you could develop/test?
I'd love to use modmxt on all my computers; the "playlist" functions and such are the best I've come across.
/Eirik
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 26 of 90, by FreddyV
ltning wrote on 2022-04-26, 18:57:
It would be pretty impressive to see a 286 play back a 8MB XM file :D Do you own or have access to a PnP so you could develop/te […]
For the moment, I never used a module with >1Mb samples 😀
It would be pretty impressive to see a 286 play back a 8MB XM file 😁
/Eirik
Thanks,
Yes, I have a GUS PnP
Reply 27 of 90, by genocho
Hello, I have tried the mod master xt v1.0 with my gravis ultrasound max and when I play a mod for example I only hear part of the mod completely cut off and without synchronism, it is heard in chunks. My gus max is well configured (jumpers) and works well in pinball fantasies and other gus players. I'm using it on a 286 with 4.11 drivers, any idea what the problem could be freddy?
Thanks.
Reply 28 of 90, by FreddyV
genocho wrote on 2022-06-17, 00:11:
Thanks.
Hi,
The GUS MAX use GF1 like the standard GUS so it should work.
Can you try removing the Config file ? (MODMXT.CFG)
Reply 29 of 90, by genocho
FreddyV wrote on 2022-06-17, 11:39:
Hi, […]
Thanks.
Hi,
I removed the cfg file and same issue, sound like channels cut off and on all the time, it sounds, but with this strange behaviour.
I checked the mixer on the gus and all fine like it should be, and like i said the gus works fine with other players and games.
No idea what else to do or check.
Thanks.
Reply 30 of 90, by ltning
genocho wrote on 2022-06-17, 15:15:
I removed the cfg file and same issue, sound like channels cut off and on all the time, it sounds, but with this strange behavi […]
Hi, […]
Thanks.
Hi,
Thanks.
Have you tweaked your ISA bus speed? I have had similar issues when the bus speed has gone >10MHz with GUS Classic, perhaps the Max is more sensitive?
/Eirik
~ love over gold ~
Reply 31 of 90, by genocho
ltning wrote on 2022-06-17, 15:26:
Hi,
Thanks.
/Eirik
The 286 mainboard is at 8mhz now, same problem, i dont know if can change the isa bus speed.
I think is some kind of incompatibility with the gus max, anyone tried mod xt with a gus max ?
Thanks.
Reply 33 of 90, by 8bitbubsy
4 channel mixing @ 30kHz on an 8086 8MHz without stuttering is really amazing. I'm also a bit amazed at how fast the 150kB module loads to RAM after you select it in the file browser. Feel like sharing the source code?
386:
- CPU: 386DX-40 (128kB external L1 cache)
- RAM: 8MB (0 waitstates at 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: SB Pro 2.0 + GUS 1MB
- ISA PS/2 mouse card + ISA USB card
- MS-DOS 6.22 + Win 3.1
- MR BIOS
Reply 34 of 90, by FreddyV
Some test files
    Tandy.zip
    170.33 KiB
    89 downloads
    CMS.zip
    158.53 KiB
    91 downloads
Reply 35 of 90, by FreddyV
8bitbubsy wrote on 2022-06-17, 20:57:
Hi,
The maximum mix speed depends on the module as well, if it does not need to mix 4 Channels all the time.
Where have you seen 30KHz ? the limit is more around 26/28KHz
Basically, I used a lot of trick, 6 Buffers, Channel mix paused if the buffer calculation is too late, don't do a ADD, but a MOV for the first channel mix (Faster and avoid to clean the buffer before)
The sample loop is extended at the end of the sample, to not test if the sample end is reached all the time.
So, even if the CPU Does not follow, we can't hear problem in the sound.
For the module load speed, it can be much faster if you convert the file to the .MMM format.
I plan to release the code, as a sound system.
I already shared it with some ppls.
Reply 36 of 90, by ltning
FreddyV wrote on 2022-04-29, 16:51:
/Eirik
Thanks,
Need a nice module to test with? :)
/Eirik
~ love over gold ~
Reply 38 of 90, by sparky4
i found a bad bug in 1.00
load the modm from floppy from a directory not \ and swap it out and try to get it to load the new floppy's parent directory
hit up and down arrow keys and bam! glitches!
😁 this software is awesome keep it up! <3
    1.25 MiB
    bug
wwww
Reply 39 of 90, by FreddyV
sparky4 wrote on 2022-07-19, 15:11:
i found a bad bug in 1.00 […]
Who still use floppy ? 😀
