First post, by Mahler
I have Dosbox v0.74-3 running on Linux, Ubuntu 20.04.4. When I quit full-screen mode (Alt+Enter) the screen resolution has not been restored to 1920x1080. I need to close the Gnome session and login Ubuntu again to restore the screen resolution. How can I solve this problem?
Reply 1 of 4, by zirkoni
Set DOSBox full screen resolution equal to your desktop resolution:
fullresolution = 1920x1080
If there's no resolution switching then there shouldn't be any such problem.
https://youtube.com/@zirkoni42
Reply 2 of 4, by Mahler
Yes, fullresolution=1920x1080 solves the problem. However, in this case I have the box in the center of the screen where there is an image. There is no 1920x1080 image in full screen mode.
Reply 3 of 4, by Mahler
The output=opengl has solved the 2nd issue.
Reply 4 of 4, by Azarien
fullresolution=desktop
is more convenient as it means "use current desktop resolution whatever it happens to be"
