First post, by fabbrimichele75
Hi there,
I am trying to restore my old 286 motherboard Octek Fox II 286.
I still have the original SIMM RAM modules that used to work.
But now when I try to run the board via an ATX to AT adapter I get the following error message:
"INVALID SWITCH/ MEMORY FAILURE".
Do you think guys is something that can be fixed replacing the SIMM modules? Or could the problem be the motherboard itself?
Cheers,
Michele
