Reply 1840 of 1905, by Kekkula
Ran quick tests with beta firmware on my 1.x card.
Usb mode now works, at least cd mode.
Sb mode also works, tested quickly with world of xeen.
Gus mode works, tested with epic pinball.
As always xcom: ufo defence and panzer general does not work in gus mode.
Reply 1841 of 1905, by polpo
One more beta release, if this goes well I'll release it as v4.1.1 final. https://github.com/polpo/picogus/releases/tag/v4.1.1-beta.1
In this one: fixes bad clicking in single-cycle DMA audio in SB mode (more than the typical clicking that non-autoinit SB titles can have).
creator of PicoGUS and PicoIDE
Reply 1842 of 1905, by Feallan
I have a small suggestion for future board revisions of PicoGUS - the wavetable connector could use pin numbering to avoid any possible confusion. One pin is marked but to be honest I only noticed it after staring at it for a good while 😁 Maybe the common triangle marking would be more visible
Reply 1843 of 1905, by vutt
I had little bit time to test my hw v1 PicoGUS yesterday with v4.1.1-beta.1. Focused on DOS demos. Happy to report no issues on VIA Apollo Pro 133T platform. It run just fine even with CPU L1 cache disabled. And yes second reality had stereo sound with SB16 emulation.
Anyways run into issue with Duke3D. In SB16 mode it insist that high DMA must be between 5-7. Hm...
Another observation - Dark Forces imuse setup is reporting SB16 DSP ver 4.05 so PicoGUS emulates very early SB16 version
Reply 1844 of 1905, by Yoghoo
vutt wrote on 2026-04-23, 15:58:
Just set it to 5 and than edit the config file and set the high dma to the same value as the low dma. From the PicoGUS wiki:
Because PicoGUS is an 8-bit card, it does not support high DMA for Sound Blaster 16 support. This is actually a mostly-supported configuration for SB16: several versions could be jumpered to disable high DMA, and the Creative Vibra 16X/16XV does not support high DMA at all. Almost all SB16-supporting software is fine working without high DMA, or configuring the same DMA channel for both low and high DMA.
Reply 1845 of 1905, by eliot_new
NeoG_ wrote on 2026-04-16, 22:36:
eliot_new wrote on 2026-04-16, 21:24:
Hello, I have plugged in the PicoGUS into an Acorp ALi5 Mainboard. FW 3.2.0. When I load pgsunit with = SB parameter, I hear sound in Doom1, Doom2 normal sound blaster A220, I7, D3 as jumpered on the PicoGUS. But as soon as I select = gus in my boot menu, I don't hear any sound in Doom1, Doom2. This is astonishing, as the same PicoGUS is working with the same MSDOS 6.22 bootmenu on a Asus ALi5 Mainboard without any problems. Tomorrow I will post here my config.sys and autoexec.bat. Maybe some mainboards really have problems, or is it the ISA slot not accepting the PicoGUS?
I am using a PicoGUS in an ACorp 5ALI61 without any issues, so there is going to be some kind of configuration issue somwhere
Ok, here is the solution, it took me almost 1 day to figure it out.
History behind: I bought 2x PicoGUS 2.0 and 3x AWE64 value for cheap.
One pair of PicoGUS 2.0 and AWE64 value worked perfectly 3 months ago along with the onboard ESS1938S Chip on my P5A Rev. 1.4.
Then I bought 2 additional AWE and 1 extra PicoGUS as well as an Acorp ALi5 and a Shuttle HOT-637A i440LX.
After that I began to rotate the soundcards without thinking about the consequences.
I always used the same sd2ide adapter with the same SanDisc 32GB sdcard and MSDOS 6.22 along with Phils Boot Menue and some extra entries into Autoexec.bat for SOLO-1 XOR AWE64 XOR PicoGUS.
I knew that CTCM is saving values into CTPNP.CFG and thought I can easily rotate every sound card to every mainboard.
Finally CTCM began to freeze as well as the PicoGUS software (ultrainit or how was the name?)
I observed the following:
1 of 3 AWE64 worked on Acorp but only in ISA slot number 2, the PicoGUS only in slot number 1, none of them in ISA slot 3 and they always wanted irq 5, dma 1.
All 3 AWE64 and all 2 PicoGUS worked flawlessly on the Shuttle iLX440
None of the 3 nor of the 2 worked on the P5A.
1 hour ago I got a genius idea :
First: I deleted Serial No from CTPNP.cfg
Second: I loaded the defaults into the Bios of P5A
Third: I rebootet into MSDOS 6.22 and suddenly CTCM assigned A220, i10, D3, H7, P330, T6
Fourth: I figured out, that CTMC saved those values into C:\SB16 rather than on C: where I first searched and found an old ctpnp.cfg with i7,D1, H7
The lessons to be learned:
1. i440LX and maybe i440BX, i815EP boards are forgiving and don't mind if you rotate sound cards
2. ALi5 mainboards are like Elephants
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Reply 1846 of 1905, by MadMac_5
It took me a while to get the footage edited, but I just finished making a video comparing the PicoGUS 4.0 Sound Blaster 16 emulation to a real CT2230 on my PIII-550/440BX system. Check it out at https://youtu.be/EZdxE6j73gA, and bring along your best headphones or speakers! And, if you want to give it a watch/listen without YouTube audio compression let me know and I can upload it to OneDrive or the like for sharing.
Reply 1847 of 1905, by NeoG_
Interesting tidbit about Tyrian being hard to get working on anything but an SB16, I've never actually had it fail to run OPL on any soundcard haha
Also, I observed the same slight OPL3 slowdown in Descent in your video (7m40s) compared to hardware OPL3, it's less apparent in level 2 than in level 1
Reply 1848 of 1905, by carlostex
NeoG_ wrote on 2026-05-04, 04:27:
It's utter BS.
Reply 1849 of 1905, by crusher
MadMac_5 wrote on 2026-05-04, 03:59:
Thanks for this comparison video. I asked that myself how the GUS SB16 emulation will sound against a real SB16. Especially as the PicoGUS is an 8-bit ISA card.
I was curious if that makes a huge difference.
I will watch (and hear!) this later when at home.
Reply 1850 of 1905, by NeoG_
crusher wrote on 2026-05-04, 11:14:
Being an 8-bit card doesn't change the sound, you can get 16-bit transfers by double pumping the 8-bit bus which is supported by most SB16 drivers. The Creative Vibra 16XV also uses this configuration.
Reply 1851 of 1905, by theelf
Thanks for this comparison video. I asked that myself how the GUS SB16 emulation will sound against a real SB16. Especially as t […]
My 486DLC motherboard, dont support high DMA, i have a awe64 sharing low and high dma, like set blaster=a220 i5 d1 h1 t6
Sound quality? exactly same, but if you want to reproduce for example a 44khz 16bit stereo PCM on windows 3.1 you will notice the big slowdown, or you reproduce at 22khz or 8bit or mono... etc
About DOS, because is not multitasking you will not notice exept your cpu is too slow for 16bit content + 8bit dma
Reply 1852 of 1905, by vsharun
Just my CC, to let you know, PicoGUS struggles to work thru LPC to ISA adapter (Re: dISAppointment - LPC to ISA adapter - ISA on modern motherboards)
While in port mode - ok (impulse tracker - flawless), no go in DMA mode. Issues with FM synth in Wolf3d.
Yes, LPC to ISA adapter is picky about that, but, who knows, maybe there's some trick and voila ?
Reply 1853 of 1905, by MadMac_5
carlostex wrote on 2026-05-04, 08:14:
It's utter BS.
I've had issues with PCI sound cards, but ISA ones have been mostly trouble-free. I should have been more specific, thanks for the corrections. 😀
Reply 1854 of 1905, by Hayko
Wow now i got the dune2 working (sound blaster pro). All the sounds works as it should be. Dont know is it the new firmware or something else..
Reply 1855 of 1905, by NeoG_
The other thing I noticed is that the FX in Doom is significantly clearer on the PicoGUS than an SB16 - I assume that is because it's not doing the sample rate dependent lowpass filter that a real SB16 does? I noticed that Descent in GUS mode sounds a lot clearer than a real SB16 as well, that's probably the same reason.
Reply 1856 of 1905, by crusher
Now we need a dual card feature.
One in GUS mode and the other in SB mode for games that support it. That would be the ultimate killer feature.
Reply 1857 of 1905, by NeoG_
crusher wrote on 2026-05-07, 06:14:
I have a PicoGUS and SB16 in the same computer, which games can take advantage of it?
Reply 1858 of 1905, by myne
I think they're saying that the pico should present itself as though it is two cards, and only run the appropriate one for the current application.
I thought there was an exe/com file to reconfigure the picogus that could easily be added to a batch file and achieve the same result in about 2 minutes.
I built:
Reply 1859 of 1905, by NeoG_
myne wrote on 2026-05-07, 06:41:
That's already a feature, you can switch the card mode at any time in batch scripts using the pgusinit utility, the switch takes less than a second
