Reply 820 of 858, by mockingbird
rasz_pl wrote on 2024-04-10, 21:20:
Whole point of using rp2040 is that chips like AD1848 are easy to implement in software
Would AD1848/CS4231/CS4248 not be much more difficult than SB DSP 2.x which is what PicoGUS emulates now?
(Decommissioned:)
Reply 821 of 858, by Tiido
Much easier because there's no MCU to emulate, just some registers and state machines.
Reply 822 of 858, by polpo
So here's something that's not possible on the PicoGUS 2.0 card, but is on the 1.x cards as well as the Femto: WiFi. Thanks to yyzkevin again, NE2000 emulation is working on the PicoGUS with a Pico-W. It'll still be a while before it's polished: it'll need support from pgusinit to set the SSID and WPA2 password, and I'm also going to start storing card settings in flash so you don't have to run pgusinit all the time.
322.2 KiB
323.65 KiB
Reply 823 of 858, by Delphius
polpo wrote on 2024-04-15, 00:24:
That is super cool. Can this run along side other firmware or is it a separate uf2 to do this?
Reply 824 of 858, by polpo
TBD if it can run alongside other firmwares. WiFi uses a lot of RAM and requires its own IRQ so that will limit the other emulations it can coexist with. It may be possible to have a custom ne2000 packet driver that can multiplex the IRQ with the sound card but it's probably not going to be perfect.
Reply 825 of 858, by appiah4
Holy shit that is so awesome!
Reply 826 of 858, by Cbb
please explain does the card emulates MPU401 alongside (i.e. simultaneously) with sb or gus emulation or not?
ps may be that info was posted before, but in the first post not mentioned and it's 42 pages to read made me ask directly )
also did anyone checked if F-29 Retalliator detects MT-32 connected to this card (running current firmware)?
Reply 828 of 858, by Kekkula
Since the cards are unobtainium, could someone make a tutorial how to order pcb's with smd components soldered from some pcb manufacturer? I glanced the github repo but couldn't figure out how to do it.
I think at least pcbway has some kind of project page where you can order ready made projects, I think that the project creator gets some commission too.
Reply 829 of 858, by polpo
It's been a bit too long since my last batch but I wouldn't exactly say the cards are unobtanium. Between myself and https://jcm-1.com/ we have 1000 cards currently in production that will be available in the next few weeks. Getting more sellers lined up outside of the US is in the works as well.
BTW I haven't used PCBWay because they aren't very competitive with their assembly costs. I don't think making the design available through their shared projects makes sense, either, since those would be small orders. If someone were to order 10 boards for example, it'd cost about $100/board. PicoGUS is cool and all but as the creator and knowing all of its warts it is not in my opinion worth $100.
Reply 831 of 858, by rasz_pl
With SB and NE2000 now possible it makes more and more sense to plop one or two more rp2040 on the PCB and let them talk over fast serial bus.
Reply 833 of 858, by appiah4
Kekkula wrote on 2024-04-16, 18:21:
Ok thanks for the reply.
Here in Europe cards are hard to come by 😉
Order your 1.x PCBs from JLCPCB and your parts from LCSC, solder and enjoy..
Reply 834 of 858, by Piligrim-23
Hi,
I have assembled three PicoGUS V2.0 boards, and two of them work fine, but on the third board, clicks and crackles are heard when playing sounds and music, as if listening to a vinyl record.
What could be the problem? Maybe someone has come across such a case? I have already replaced the PCM5100A chip twice, but it has not given any positive results.
Link to the recorded audio file:
https://drive.google.com/file/d/13oy0wXh3Ue7P … K353x5l1JZ/view
Reply 835 of 858, by dj_pirtu
Suddenly I'm getting this error that GUS is not responding on port 220 but in 200?!?
Edit: with emm386.exe it works on port 220 but only with himem.sys it gives that error, this is strange...
Edit2: and after few boots the same error with emm386.exe too. This started with the sb-firmware.
Reply 837 of 858, by HomeLate
I think I have a few pcb's left (1.1/1.2, no 2.0) after I build a few cards for some friends. Contact me if you want me to build you one.
Reply 838 of 858, by dj_pirtu
Pickle wrote on 2024-05-04, 15:13:
dj_pirtu wrote on 2024-05-04, 13:17:
any other cards in your pc using a port address?
3COM ISA Ethernet card... Could it be that it has lost it's configuration, need to check that out.
Reply 839 of 858, by Pickle
dj_pirtu wrote on 2024-05-05, 16:27:
yeah ive had time where network cards conflicted. Id remove it just for a simple test. The best was when i had one set to 0x200 and couldnt figure out why my keyboard was moving on its own.
