First post, by tutankhamen
Hello guys, I recently bought a pair of AdvanSys ABP-5140/42 SCSII adapter and TOSHIBA XM-3501B CD-ROM and I didn't expect that finding the driver will be so challenging. So, maybe someone has it or can point me to the right direction?
Thank you!
Reply 1 of 12, by Pierre32
Welcome.
There is this pack here, but it doesn't specifically list your model: https://www.vogonsdrivers.com/getfile.php?fil … 786&menustate=0
You probably found this one pretty quickly and would have seen that it's just bait. But the filename shown here "AdvanSys_ABP-5140_5142_driver_and_manual.zip" could aid your search.
http://www.storagedrivers.com/drivers/531/531176.htm
Here's the Wayback capture of the original download page. The download links look dead but you can see the original file was called "dosfiles.exe" https://web.archive.org/web/20010331080028/ht … /fastultra.html
Have a look here too. Do a ctrl-f in the descriptions of each CD and see if anything looks promising: https://archive.org/search.php?query=ad ... oftware%22
Or maybe weedeewee has the drivers:
weedeewee wrote on 2022-05-03, 15:18:
My google & archive fu is letting me down, so I'm throwing this question out here. […]
Does anyone have a fully equipped Advansys ABP-5140/42,
ie the one with the floppy drive controller on board & the eeprom for the bios
and would said person be so kind to share some
clear photos of the card
and a
copy of the bios?
I've got one without floppy & bios and want to try to add the bios to it and if the chips can be found, the floppy controller as well.
Thanks.
Reply 2 of 12, by weedeewee
Pierre32 wrote on 2022-07-03, 09:49:
Welcome. […]
Welcome.
and a
copy of the bios?
Thanks.
Pierre, nope, I don't have the drivers, and the archive site you linked to also does not have the drivers. I hit the same site myself just a few minutes ago. Google for the filename + advansys only leads to a japanese site, which links to the original site that the archive site is from... so no go 🙁 (yet...)
Do not ask Why !
Reply 5 of 12, by weedeewee
Pierre32 wrote on 2022-07-03, 10:21:
This might be something: http://ftp.mpoli.fi/pub/hardware/HDD/OTHER/ […]
ctrl-f advansys
Promising looking downloads:
ADV-DOS.ZIP
ISADISK1.ZIP
ISADISK2.ZIP
the ADV-DOS.zip contains dosfiles.exe, which contains ADVASPI.SYS v2.6c and ADVANCD.SYS.
ISADISK1.ZIP contains ADVASPI.SYS v2.41
Nice find Pierre32 !
Do not ask Why !
Reply 7 of 12, by weedeewee
Pierre32 wrote on 2022-07-03, 10:42:
Report back if it does the job, and we'll get it uploaded to Vogons Drivers 😀
Here's to hoping that tutankhamen will do that testing & reporting swiftly.
Now still have to find the bios and hi-res photo so I can have it be bootable and maybe add the floppy part.
Do not ask Why !
Reply 8 of 12, by PC Hoarder Patrol
tutankhamen wrote on 2022-07-03, 08:51:
Thank you!
The DOS / Win 3.x compressed package is called WINFILES.EXE (attached), and the instructions can be found here - https://web.archive.org/web/19980116235225/ht … upp/dosread.htm
The ISA config utility which allows IO port address, Hardware IRQ, and DMA Channel changes is called CFG5140.EXE (attached)
winfiles.exe
453.7 KiB
42 downloads
CFG5140.EXE
20.64 KiB
45 downloads
EDIT - suspect the @weedeewee link might have all the above (& newer?) but added for reference anyway
Reply 9 of 12, by weedeewee
PC Hoarder Patrol wrote on 2022-07-03, 11:06:
Actually, it was Pierre32, and the ADV-DOS.ZIP contains dosfiles, winfiles, etc...
might as well add the link... http://ftp.mpoli.fi/pub/hardware/HDD/OTHER/ADV-DOS.ZIP 😀
Do not ask Why !
Reply 10 of 12, by tutankhamen
Thank you very much guys! You're awesome! I started from ADV-DOS.ZIP proposed by Pierre32 and later by weedeewee. It contains DOSFILES.EXE archive which has all the stuff I need. README says just run INTSTALL.EXE and it copies all required files for the adapter, CD-ROM and HDD, as well as add all the required changes to CONFIG.SYS and AUTOEXEC.BAT. So, everything works now! Thank you very much again!
Sorry for blury image: https://photos.app.goo.gl/oG3eumpWchZ9tAJr5
Reply 11 of 12, by tutankhamen
winfiles.exe
CFG5140.EXE
DOSFILES.EXE would be better since it's smaller and contains DOS installer which makes everything easier.
