Gateway 2000 overdrive build
Reply 20 of 50, by Sphere478
Okay, so… win 3.11, windows 95, or….?
Linux?
Sphere's PCB projects.
Reply 21 of 50, by fosterwj03
With a POD83 and 32MB of RAM, you have a lot of options. It will run Windows 3.1 and Windows 95 with no issues. Windows NT 3.51 and Windows NT 4 will also work well. If nothing else, it will rock DOS 6.22.
Reply 22 of 50, by Sphere478
I’m kinda leaning toward 95 maybe go all fancy and do a plus pack or something. Lol
What about a mac os hackentosh? System 7.1?
Or linux or beos?
Reply 25 of 50, by Intel486dx33
From my experience when you use the CF card the PC Bios will assign some sort of Hard drive type/size config to the CF card. But that does not matter what hard drive type/size the bios gives to the CF card. When you boot the computer and fdisk the CF card. The CF card will let you partition it to 2gb partitions.
Reply 26 of 50, by Intel486dx33
Thats PC was originally designed to be a DOS/Win3x computer.
But with the upgrades you added it is more than capable to run Win95.
You could even add a PCI USB 2.0 card if you are going to run Win95c
You can download Win95c from internet and it comes with USB drivers but you will need to add the USB driver update.
Also you might want to add Network card ( 3com 3c509 ) and use a WiFi extender adapter to get on your home network ( TP-link )
Reply 29 of 50, by MarkP
Sphere478 wrote on 2022-07-20, 02:27:
Linux?
This thread may give you some useful information- Which operating systems work on i586?
Reply 30 of 50, by Sphere478
Ah my old thread! Gonna have to give it another look through. 😀 forgot about it haha
Intel486dx33 wrote on 2022-07-20, 10:39:
Thats PC was originally designed to be a DOS/Win3x computer. But with the upgrades you added it is more than capable to run Win […]
No pci on this mobo 🙁
Oh, os2 would be fun
Reply 31 of 50, by Sphere478
Which isa video card for gateway 2000 with pentium overdrive?
Reply 32 of 50, by Sphere478
Woohoo!
Progress!
I upgraded the video memory to 1bm
I installed a post card, a sound blaster, a scsi card, and a xt-ide.
Gonna see if I can get a OS on the scsi now.
file.php?id=143344&mode=view
Reply 33 of 50, by Sphere478
Thanks to tonk for helping with this:
https://www.datasheetarchive.com/pdf/download … O&term=VL82C480
Gonna try for 64 mb
If I can find some 32 chip 32 mb simms. Anyone know where to find some?
Reply 34 of 50, by Sphere478
Did some more playing around with it today.
I got my adapter for 80 to 50 pin.
And installed a 15k rpm 140 something gb drive
It shows as 8-9gb though.
Scanning the drive goes past 100% in the controller utility 🤣.
Anyway, gonna wait to do more prob till my new gotek gets here I ordered one for it.
Reply 35 of 50, by Sphere478
1.51 MiB
1.05 MiB
1.5 MiB
1.72 MiB
1.62 MiB
It lives!!
It is actually pretty snappy! Had to test it out with myst and sc2k of course!
Gonna try and run some benchmarks on it later.
Finally got the scsi working. It seems to have been some setting in the scsi bios that was causing issues.
I installed a 140gb 15k rpm drive on a 80 to 50 pin adapter, bought a terminator and it is all working. But only 8gb of it. (Thoughts?) anyway, 8gb is enough for most of what I wanna do with it, but not enough to hold all my dos games. Getting to at least 32 gb would be nice.
If I haven’t mentioned already, I got the cache, ram, and onboard video memory all maxed out it seems? 256k, 32mb, 1mb
I installed windows 95c btw. Might be fun to play around with linux later but for now this is working fine.
Reply 36 of 50, by chrismeyer6
That sounds like a great win95 system! Is the drive itself jumpered for a smaller size or some sort of compatibility mode? What file system did you use for 95c fat 16 or fat32?
Reply 37 of 50, by maxtherabbit
Sphere478 wrote on 2022-09-13, 12:48:
which one?
in discord you said you changed settings in DOS, so was it DOS or the SCSI BIOS or both?
Reply 38 of 50, by Sphere478
I didn’t say I changed settings in dos.
“ Still can’t get drive to show up in dos
Ooo changed some settings, I think it may be working now!
It sees the drive!!!”
Not sure what setting. I set everything back to default except larger than 1gb drive support and that worked.
I’ll probably go back in and start tweaking things till I break it and then I will know.
chrismeyer6 wrote on 2022-09-13, 13:00:
It seems to be a scsi controller bios limitation? Idk. Kinda new to scsi.
I assume it is fat 32 being 8gb
I don’t believe any of the jumpers are set to a size limit.
    1.27 MiB
Reply 39 of 50, by chrismeyer6
Yeah none of those jumpers should set a size limit. It might have something to to with the scsi card. Which card are you running as their might be a bios update for larger hard drive support.
