HDD Clicker - HDD Sound Simulator
Reply 20 of 104, by Jura Tastatura
dreamblaster wrote on 2022-09-30, 16:04:
I'm expecting a first batch in the next weeks,
PM me if interested, for priority vogons access to HDD clicker 😉
can't PM because I'm a noob, but I want it and I want it NOW! 😁
Reply 21 of 104, by dreamblaster
Jura Tastatura wrote on 2022-09-30, 16:20:
You can also contact me through https://www.serdashop.com/Contact ,
dont forget to mention your vogons username to get priotity treatment 😉
Thanks for your support !
Reply 22 of 104, by dreamblaster
HDD Clicker Enclosure coming soon
Reply 25 of 104, by Jura Tastatura
keropi wrote on 2022-10-04, 11:39:
does it matter since it is an internal device?
maybe I want to display it inside the case with translucent/tempered glass side panel? 😁
it doesn't matter really, TBH.
Reply 26 of 104, by keropi
Jura Tastatura wrote on 2022-10-04, 12:05:
you need the RGB version for this!
Reply 27 of 104, by Jura Tastatura
keropi wrote on 2022-10-04, 12:54:
and DELUXE version should include small display and a rotary knob to alter sound. 😉
Reply 29 of 104, by dreamblaster
Prototyping
    272.08 KiB
    265.02 KiB
Reply 30 of 104, by BitWrangler
Can one swap out the bleeper for a 75W PA horn to emulate the full might and majesty of an ST-412 ?? IDK if that's quite enough to shake the desk tho. 🤣
Reply 31 of 104, by Jo22
BitWrangler wrote on 2022-10-06, 17:57:
Something like this ?
23.55 KiB
Source: https://commons.m.wikimedia.org/wiki/File:Bluesmobile_at_House_of_Blues_Dallas_-_3-4_view.jpg
Reply 32 of 104, by BitWrangler
That's gonna be a tad over the top size wise, I guess plan B would be getting a servo to whack a 3/4" wrench between two hefty standoffs.
Reply 33 of 104, by Jo22
BitWrangler wrote on 2022-10-06, 18:08:
Hm, yes. Sounds reasonable.
Reply 34 of 104, by wiretap
Another idea for a deeper HDD sound -- a solenoid. It could be mounted to the chassis so it gets the similar vibration to a normal HDD. See the clunker keyboard as an example: https://mechwild.com/product/clunker/
My Github
Circuit Board Repair Manuals
Reply 36 of 104, by Sphere478
wiretap wrote on 2022-10-06, 20:31:
What about a cell phone clicker? Like the thing apple used to make you think you pushed the home button when it didn’t really move
Sphere's PCB projects.
Reply 37 of 104, by wiretap
Sphere478 wrote on 2022-10-07, 21:55:
Don't know, I never owned an iPhone, but it sounds too small, or maybe it was a vibration motor.
My Github
Reply 38 of 104, by digistorm
wiretap wrote on 2022-10-07, 22:15:
Nope, Apple doesn’t use them for ages now. It’s an actuator, that they can control in software to make clicks or vibrations. It would be useable for something like this. Because a real HDD also makes your case vibrate a little and amplify the noise
Reply 39 of 104, by dreamblaster
first prototypes
still need a small fix to enable the external connection feature
(allows to connect a second speaker/buzzer/.. for even more noise)
    429.04 KiB
