Reply 20 of 29, by Jo22
Windows 95 has a built-in file transfer program that can use parallel LapLink cables.
It's called 'Direct Cable Connection'.
https://m.youtube.com/watch?v=YHyrsVihry8
https://techgenix.com/wxpdcc9i/
Alternatively, it might be possible to transfer data via serial connection.
Nullmodem or IrDa, for example.
HyperTerminal can be used to get communications software onto the laptop.
Protocols lile Kermit, XModem/ZModem etc can be used.
Reply 21 of 29, by Ensign Nemo
Jo22 wrote on 2022-09-22, 04:59:
Windows 95 has a built-in file transfer program that can use parallel LapLink cables. It's called 'Direct Cable Connection'. […]
Thanks, I wasn't aware of that program. Unfortunately, I'm having a hard time finding laplink cables for a reasonable price over here. I can get a cheap serial null modem cable on Amazon, so that might still be an option for transferring files at least.
Reply 22 of 29, by rasz_pl
You wont find laplink cables anywhere as their usage peaked 25 years ago 😀 What you will find absolutely everywhere with a printer is old LPT cable. It takes 30 minutes for absolute amateur to rewire Printer cable to laplink with a basic soldering iron. You could even go as crazy as splicing individual cables by hand with no soldering, like repairing a bicycle lamp 😀
Another alternative https://www.yyzkevin.com/pcmcia-pico-w-card/
Reply 23 of 29, by lolo799
rasz_pl wrote on 2022-09-23, 13:13:
A pcmcia compactflash adapter will still be cheaper than yyzkevin's last experiment.
Other neat ideas:
-making a serial null modem cable out of dupont cables
-using minimodem to transfer data via the speaker http://www.whence.com/minimodem/
Reply 24 of 29, by Ensign Nemo
I've started looking for parallel cables. There's been a few come up locally, but they've all had that centronics plug on the end. I'll keep looking, as something should come up sooner or later.
Reply 25 of 29, by Ensign Nemo
A pcmcia compactflash adapter will still be cheaper than yyzkevin's last experiment. Other neat ideas: -making a serial null mo […]
Other neat ideas:
Amazon has serial null modem cables for $8, so I wouldn't need to make one. The only problem is that I'm not sure if I can image the HDD over serial. Norton ghost mentions parallel and network in their manual. Still, that might work for transferring files. I don't mind if it's slow. That's part of the charm, reminds me of downloading games from BBSes as a kid.
Reply 27 of 29, by rasz_pl
Ensign Nemo wrote on 2022-09-23, 16:48:
I mean ask a teacher/parent/coworker/friends if they have their old printer cable laying around. Get two free cables, rewire as needed.
Reply 28 of 29, by lolo799
Found those projects for serial transfer:
https://github.com/trevorg16/serial-hd-img
https://github.com/tschak909/disk-xfer
https://github.com/fysnet/mcopyata
Using a combination of dd and nc would work too.
And I suppose that with interlink, Ghost or any other Dos based imaging software would be able to use the remote drive to save the dump, whichever way the two machines are connected.
Reply 29 of 29, by Ensign Nemo
I just picked up an older Toshiba Tecra A3 for $20. It should have an IDE HDD, so I should be able to back up the Hitachi drive with clonezilla. Now I'll just need to find a solution for transferring files. I'll be keeping an eye out for pcmcia cards that are a reasonable price. I'll probably pick up the null modem cable from Amazon since it's really cheap.
Thanks again for all of the suggestions.
