First post, by mrfusion92
This is the card.
1.83 MiB
This is the issue. There is no physical damage in the card, it's very clean and nearly mint as you can see in the above photo.
Bands are visible in BIOS and DOS mode too.
Can be bad DRAM chips?
1.19 MiB
1.58 MiB
Reply 1 of 10, by pentiumspeed
This is mentioned in gona's compatibility video card list especially when used with LCD panel.
Cheers,
Great Northern aka Canada.
Reply 2 of 10, by Jo22
Um, does anybody know what's cauaing this issue?
It can't be the fault of the chips or the chip makers.
A noisy chip would never have had made it through quality testing.
Could the lack of filter/smoothing caps be the reason for the vertical bands? Or noisy PSUs?
Or are the cheap LCD monitors to blame?
Are their electronics not able to handle the pixel clock properly?
Reply 3 of 10, by mrfusion92
I use an OSSC, does it count as LCD panel?
Also the card was definitely working sometime ago, but I tested it in a different motherboard and power supply. But I don't have them anymore.
Reply 4 of 10, by pentiumspeed
mrfusion92 wrote on 2023-01-15, 01:03:
All devices that uses oversampling rate to read analog to digital and scaler to rescale the image to fit given resolution of digital output possible, depending on quality is more affected than other, if so, that qualifies. Remember LCD panel is digital, not analog means the conversion happens similar way with OSSC.
Cheers,
Reply 5 of 10, by drosse1meyer
pentiumspeed wrote on 2023-01-15, 02:06:
Cheers,
Agreed, if OP has a CRT they can cross reference with, and/or adjust OSSC settings to see if the banding can be minimized.
There have also been a number of posts as of late regarding vertical lines aka 'jailbars' and which seem to be mostly a result of converters/upscalers and/or modern LCDs.
Reply 8 of 10, by mrfusion92
It was the OSSC, this is photo while card is attached to my Samsung LCD.
1.85 MiB
No more bands\jailbars, the photo quality is a bit crap but I can assure in rl the picture is good. As @darry said I probably tested this card directly with the monitor, I just didn't remembered that.
I'm disappointed by the OSSC, I tried change some settings (LPF, etc) but nothing solved the issue.
Reply 9 of 10, by Tiido
You need to spend some time with sampling settings on OSSC, it is clear the pixel clock that is assumed for the specific input is not quite right and adjustments are necessary. Pixels per line figure needs to change but by how much I don't know.
