Asus P5A not working
Reply 20 of 42, by fool
Crazy means that the multimeter start with a low value and then it goes up up up up
That happens when you have large capacitor connected in parallel with the multimeter charging up.
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 22 of 42, by fool
Nemo1985 wrote on 2023-02-04, 18:24:
I see thank you... Should I try to measure again until I get the highest value?
If it rises to some "highish" value it's OK.
I would be more interested about those low ohmic values 200-300 ohm.
Reply 24 of 42, by bloodem
Well, if the readings are correct, at first glance it does look good (although, for some reason, you measured 15 pins on HIP6013, even though it only has 14 pins 😁 ). Indeed, the pins on HIP6013 with sub 300 ohms are suspicious, but might be OK.
In this case, I would compare resistances with your working board (rev 1.03). The two boards should be very similar (if not identical) when it comes to the CPU power delivery. Also check the MOSFETs for shorts.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 25 of 42, by Nemo1985
bloodem wrote on 2023-02-04, 18:45:
Lol I thought something was wrong, I measured one 0.l twice, corrected.
How can I check the mosfets for shorts?
Reply 26 of 42, by bloodem
Nemo1985 wrote on 2023-02-04, 18:47:
In the exact same way (after checking the datasheet of the MOSFETs). Only the ground should have very low resistance.
Reply 27 of 42, by Nemo1985
160.89 KiB
From left to right (I measured the complete legs only):
0.1
0.1
Up to 2k and down
8.17m
156.59 KiB
0.1
452
8.13m
I get roughly the same values from the working board.
I'm going to measure the values for HIP6008 and HIP6013
Reply 28 of 42, by fool
I made reference measurement from controllers. No CPU & power attached.
HIP6008:
>3k
8M
23k
13k
8k
5k
INF
>12k
zero
8M
>2k
6M
38k
38k
7M
1.4M
and HIP6013:
7M
>3k
7M
7M
3,5k
>12k
zero
>1k (480)
6M
38k
INF
INF
INF
38k
Reply 29 of 42, by Nemo1985
Thank you very much, I remeasured the values, the most sure difference is on pin 4 of the HIP6013, I get 0.L which I suppose means infinite, while you get 7m.
Same goes for pin4 on the other chip, I get a completely different value from yours, I tried with continuity and it seems in short.
Reply 30 of 42, by fool
Nemo1985 wrote on 2023-02-04, 20:00:
I'm staring at value of HIP6013 pin#8 = PHASE = regulator output. Do you have something connected to the board?
Pin#4 in HIP6008 is traced to VID select jumper, what probably shorts it to ground?
Reply 32 of 42, by fool
Nemo1985 wrote on 2023-02-04, 20:10:
It has the cpu and a memory module and the cr coin battery, I disconnected the ATX cable.
I remeasured just to be sure, it starts low as 200 and goes to 450.
If you get low value even without CPU and RAM installed there could be something wrong with the diode or capacitor.
EDIT: I guess that value is fine. When I measure it rises to 1k then drops down to 480.
Reply 33 of 42, by Nemo1985
Without cpu and ram I get a value of 480 on HIP6013 pin#8.
You are right about pin4, being connected to vid could it be the reason for different values in resistance?
Any guess about what capacitor or diode is responsible?
Reply 34 of 42, by fool
What does this mean?
HIP6008 PIN#9: 2k and then goes down
It should be connected to ground, giving close to zero resistance.
Reply 35 of 42, by Nemo1985
fool wrote on 2023-02-05, 08:19:
You are right, I redid the reading, ot the upper part of the chip, I get 0.2
Sometimes I get crazy readings by the way, the latest pin when I started to measure gave me 55k and now it gives more than 2m and goes down...
Probably I'd need to desolder the controller but I'm not good with this stuff, I barely desolder caps.
Reply 36 of 42, by fool
Values looks now good enough.
For what it looks now is that 45N03 MOSFET is not functioning nor getting control from HIP6008 to it's gate pin. Those mosfets are hard to measure in-circuit and also to remove.
Reply 37 of 42, by Nemo1985
Thank you for the help once again.
I can't locate this mosfet, the ones near the controller are pbyl or nec, there is a third one near the ide ports but it's smaller.
I can try to buy one and then find someone who is able to properly desolder and solder the new one.
Reply 38 of 42, by fool
Lower green arrow is pointing to that Vcore MOSFET transistor. It can be some other type. 45N03 is just the one I have in my board.
