CRT Terminator Digital VGA Feature Card ISA DV1000
Reply 60 of 78, by clb
The FPGA that we are using is a Gowin one. So far we have had a decent relationship with them, and have received quick tech support (although sometimes of a bit of a junior nature that we've observed, or something lost in translation) and also free samples readily available just by asking. Their boards have been decent, although not perfect - in early development we took a few months to find errata and reverse engineer some of their RAM behavior.
The snafu we now have had with them is due to a certain order/production mixup. They have given a friendly reply to us so far, even though we are tiny hobbyists.
Reply 61 of 78, by dirkmirk
I've expressed interest in the crt terminator in using old 386,486 PCs.
I'm hoping to get good results hooking up a Gigabyte Auros F04U (48" OLED), is this the type of monitor something you guys had in consideration?
I would be using cirrus logic CL5434 & S3 868 type of cards.
When you state that 256 color mode is the initial target, is this device upgradable by firmware to improve support if required for higher resolution and color modes (i.e 800x600/1024x768 16 bit)?
It would be nice to play around with windows 95/98 at mid 90s targeted resolution and color depth.
Reply 62 of 78, by clb
dirkmirk wrote on 2024-01-03, 08:08:
Gaming monitors are unfortunately not something that we've tested. So far testing has focused on older flat panels and some 1920x1200 displays (that we consider appealing for the 1600x1200 pixel perfect upscaling possibility). In my lab I have the following:
Fujitsu-Siemens P19-1 YEGA519530
Dell 2007WFP
Dell 2007FPB
ASUS ProArt PA248QV
Sony SDM-X73
BenQ BL3201PT
BenQ ET-0029-B
HP EliteDisplay E241i
Philips Brilliance 252B9/00
(of which Philips Brilliance 252B9/00 and ASUS ProArt PA248QV work the best, and they are 1920x1200)
I have a Diamond Speedstar 64 1 MB PCI CL-GD5434 in my lab, which works nicely with CRT Terminator; except that there is a unique quirk in that card specifically that it forgets PCI bus palette snoop settings on every video mode change.
I wrote a TSR to fix that, which seems to work decently.
110.06 KiB
I don't seem to have a S3 868 card in my lab, the closest that I do is a S3 864:
157.47 KiB
Although I don't have a recollection of having put this card through much testing, so I'm not 100% sure how it fares. _Some_ S3 cards (might be just in the Trio line?) have a vendor/firmware-specific behavior that in order to get output from the Feature Connector, a S3-specific register must be enabled. SNOOP.EXE does that, and so can be placed in autoexec.bat, but it unfortunately means that on those cards there won't be any image during boot until that executes.
Iirc this is due to a hacky limitation of S3 (Trio?) they have that Feature Connector lines are shared with VRAM, or something like that.. so enabling the Feature Connector requires disabling half of the VRAM. (4MB -> 2MB maybe? I'm a bit hazy on the details when writing this right now)
I am afraid that this will likely not be possible.
CRT Terminator does have the option to upgrade the firmware after release, so we can mitigate problems after shipping.
However, the underlying reason here is that the Feature Connector is only a 8-bit data bus.
We observe that few rare VGA cards do output 16-bit and 24-bit color modes over the 8-bit bus by double and triple-clocking the video, which means the clock speed of the bus doubles or triples.
Some cards don't output 16-bit and 24-bit color modes via the 8-bit Feature Connector at all, but they just output the lowest 8 bits of the 16-bit video signal, and the highest 8 bits are discarded, making the hi/true-color output completely unusable. (yeah, spent some two and half weeks double and triple checking that to believe) I hunted for a possible VGA/RAMDAC register that might be able to change this behavior, but never was able to get any to work.
Some reverse-engineered notes about RAMDAC chips hint to the possibility of DDR signaling 16-bit modes over a 8-bit bus, but despite searching, we haven't been able to find and activate a single card/RAMDAC to do this. So there may be some future mysteries unsolved or to be debunked.
VESA standardized their later "VAFC" connector to run at max 37.5 MHz clock speed, which is essentially the same for this 8-bit Feature Connector bus. That speed is good for 800x600 @ 256 colors max.
In testing, some cards run a bit better, e.g. at 40-50MHz, but sadly not nearly as much better to be able to cope with the 2x or 3x pixel clock speed that would be required for 16-bit and 24-bit video modes.
So I recommend assuming that it won't be possible to get CRT Terminator to output new video modes after shipping, we want to be very cautious to avoid building up any disappointments in expectation.
Reply 63 of 78, by laseractive
Back in the days, there were a number of TV tuner and MPEG-1/2 cards that could be connected to the VGA Feature connector using a ribbon cable. I assumed that the VGA Feature connector was an input only connector where you could feed video signals that are genlocked over the computer VGA output. But I guess it is both input and output (IO). Did you test the CRT Terminator with the signals coming from the Hauppauge WinTV, Sigma Hollywood Plus, Sigma X-Card or others? This would be an interesting experiment to try out. Sigma calls this a PDI = Parallel Digital Interface ribbon cable. The PDI cable could also be connected to deinterlacer/scaler cards like the PDI Sweetspot or Immersive Holo3DGraph. I am interested in your feedback on this? Christian
Reply 64 of 78, by clb
That is an interesting idea.
The Feature Connector does go both ways on a lot of ISA and PCI VGA cards. On AGP cards, we oddly see it only working as an input (or are missing some configuration in AGP space to turn it to go around).
We haven't tested any of these other accelerator cards. If their signal is compatible with Feature Connector (hsync, vsync, display enable and 8 bits of pixel data), then it is possible that those could be compatible.
Reply 65 of 78, by mkarcher
clb wrote on 2024-01-03, 13:01:
This mode is not just in RAMDAC.TXT, but can also be found in original DAC data sheets. That mode is also known as "Sierra mode", because Sierra RAMDACs likely were the first successful DACs that supported this mode. You can find it in the SC15025/SC25026 data sheet as "Pixel repack mode 1a" (2 DDR 8-bit transfers, i.e. 1 clock period, per pixel for 16bpp) and "Pixel repack mode 3a" (4 DDR 8-bit transfers, i.e. 2 clock periods, per pixel for 24 bpp; 8 bits ignored). I also associate that mode with Tseng graphics chips, but failed to find it in the ET4000W32 data sheets scans I have. I did find it in the ET4000AX datasheet, though! Figure "2.3.2-1 CRTC Output Timing" shows SDR transfers as well as DDR transfers on the 8-bit pixel port. The DDR transfer is labelled "high color mode", and the SDR transfer is labelled "excluding high color mode". High color mode is enabled by setting both bits 4 and 5 in attribute controller register 16h. This combination is labelled "reserved" in the W32 data sheet, but there is a note "to support ET4000 Rev. G's high color mode, configure CRTC and ATC to 8-bit per pixel (256 color mode) and clock AP<0:7> with double clocking". As my scans of the W32 data sheet contain no OCR, I didn't extensively search how to "clock AP<0:7> with double clocking", so maybe the W32 chips require external help.
I recently had a ET4000AX ISA card at hand in which the POST screen explicitly mentioned "Rev. G" which seems to be the required revision to get the DDR mode. At the moment, I don't have the system at hand to take a photo of that card, or look at VGA museum to find any scans over there, but I might be able to get there next weeks. I expect that card to use DDR high-color modes, if it has a high-color DAC at all.
EDIT: The Diamond Speedstar 24 is likely a good starting point to hunt for that DDR mode.
Reply 66 of 78, by clb
Since writing that previous note, I have been able to find two adapters where the DDR signaling is readily observable: WDC WD90C31A-LR (my card has that Sierra SC11487CV-80 RAMDAC) and Trident TGUI9440 (Integrated RAMDAC). This DDR signaling does come through the Feature Connector as well.
Oddly though, both of these adapters stop using DDR signaling in any higher resolutions, and they turn off the output signal lines going to the Feature Connector altogether. So the usefulness of this mode may be limited. (Are there great VESA based games that use 320x200@15/16bpp, 320x240@15/16bpp or similar?)
Reply 68 of 78, by mkarcher
clb wrote on 2024-02-09, 10:34:
For the WD90C31-based card, that seems strange. Typically, the pixel data lines on the feature connector are physically connected to the 8-bit DAC pixel input port, so there should be no way for the pixel data to "disappear" from the feature connector. The clock might be controlled separately, and it is not completely unimaginable that the clock signal is shut off in modes that are deemed to be "feature-connector incompatible" for whatever reason. On the TGUI with its integrated RAMDAC, the chip designers obviously have the freedom to internally connect the RAMDAC using different signals than the feature connector, so it's not as strange on that card as on the WD card.
Reply 69 of 78, by clb
It was the Hsync, Vsync and Display Enable signal lines that went down, although the pixel clock signal was still present. Not sure what was the state of the pixel color data lines (though even if they were still signaling, reconstructing the visible picture without hsync,vsync and DE would be quite tough)
keenmaster486 wrote on 2024-02-09, 16:34:
Higher resolutions like what, 640x480? Because it would be nice to get 640x480 high color in Windows.
Sadly this adapter was only giving 320x200 and 320x240 in 15bpp.
Although I have been able to get 640x480@16bpp working on some other adapters (that utilize SDR signaling). But, I don't want to get your hopes too high here, since be it SDR or DDR, both frequencies are out of spec of the connector. We cannot really guarantee that it works.. which is why we are recognizing the < 37.5 MHz spec that VESA advertised.
Reply 70 of 78, by mkarcher
clb wrote on 2024-02-09, 19:42:
640x480 at 60 Hz uses a dot clock of 25.175 MHz. If you use DDR transfers for the pixels, the clock signal is still 25.175 MHz, even though you need to transfer 16 bits per cycle. I would consider that "in spec" if the clock is supposed to stay below 37.5 MHz. There is a quad tri-state line driver next to the DAC on the WDC 90C31 board I can find on the VGA museum. That chip could be used to conditionally enable or disable signals on the feature connector.
Reply 71 of 78, by clb
The VESA specification never standardized a DDR mode, so it is basically out of spec by omission.
Looking at the required setup and hold times for SDR signaling on that 37.5 MHz, they say that for a clock period of 26.6ns, the minimum setup time is 10ns and required hold time is 2ns. Theoretically 2*(10+2) = 24 < 26.6, so one could argue that a DDR signal should fit within the timing frame.
But still, these are several decades old hardware, so every case will be a bit of a ymmv thing.
Reply 73 of 78, by clb
Heya,
things are moving along, although a bit slowly in the past month and a half due to that "real life" work stuff.
We have got components, the big thing being that our FPGAs have arrived, so no more waiting on chip shortages at least. Recently we have been figuring out shipping logistics, packaging, user manual, and other "secondary" things. It feels like the "last 10%" part indeed is the remaining 90% of the things.
So it's right now that "Soon(TM)" stage I suppose. 😀
Reply 75 of 78, by Pierre32
clb wrote on 2024-05-18, 21:22:
Heya, […]
Heya,
Actually you might be able to answer a question on video signal. I'd like to use this with a lovely 4:3 beige LCD, which does 1280x1024 @ 75hz. But only has a VGA input.
I know that the CRTT's HDMI port outputs DVI-D, which needs some active conversion to analogue. Do you have any thoughts on how adapters such as this would go with that?
9.69 KiB
(Trying to determine if any of those will handle 70hz is a whole other story...)
Reply 76 of 78, by mkarcher
Pierre32 wrote on Yesterday, 10:22:
Why would you use the CRT terminator if you need analog VGA input anyway? Is the quality of your VGA card that bad that you hope to get a better signal by using an external HDMI-to-VGA converter than you get using the integrated RAMDAC of your VGA card?
Reply 77 of 78, by clb
Converting the DVI-D output of CRT Terminator to analog VGA directly is something that I haven't tried.
The best way to use CRT Terminator is to utilize what is coined "MultiMode", which is an operation mode where the upscaled output video resolution is dynamically adjusted on the fly based on the input video mode that CRT Terminator is getting in. This helps dynamically switch between e.g. 720x400 text and 320x220 graphics without manual intervention, while preserving the 4:3 aspect ratio in output in both modes. In MultiMode operation, the video resolutions that CRT Terminator generates can vary wildly, and are somewhat unconventional in terms of timings (but adhere to CVT video timings generation format, and observed to be compatible in testing with dozens of old and new LCDs).
I've no idea how such DVI-D -> VGA converters might interpret this kind of MultiMode operation.
As a fallback if the output display is not compatible with MultiMode, CRT Terminator does also have a fixed resolution output mode. It can output one of the following fixed resolutions:
0: pass through output the given input video mode as-is.
1: 640x480 @ 60Hz @ DMT. 25.2 MHz pixel clock. htotal = 800, vtotal = 525
2: 800x600 @ 60Hz @ DMT. 139.96 MHz pixel clock. htotal = 1056, vtotal = 628
3: 960x720 @ 60Hz @ CVT. 55.8 MHz pixel clock. htotal = 1248, vtotal = 748
4: 1280x720@60Hz @ DMT timings, 74.25 MHz pixel clock. htotal = 1650, vtotal = 750
5: 1024x768@60Hz @ DMT timings, 65.0 MHz pixel clock. htotal = 1344, vtotal = 806
6: 1200x900 @ 60Hz @ CVT. 88.2 MHz pixel clock. htotal = 1584, vtotal = 934
7: 1280x960 @ 60Hz @ CVT. 100.8 MHz pixel clock. htotal = 1696, vtotal = 996
8: 1280x1024@60Hz @ CVT-RBv2 timings, 86.4 MHz pixel clock. htotal = 1360, vtotal = 1054
9: 1364x1024 @ 60Hz @ CVT. 91.065 MHz pixel clock. htotal = 1440, vtotal = 1054
10: 1400x1050 @ 60Hz @ CVT-RBv2. 95.4 MHz pixel clock. htotal = 1480, vtotal = 1080
11: 1680x1050 @ 60Hz @ CVT-RBv2. 113.4 MHz pixel clock. htotal = 1760, vtotal = 1080
12: 1440x1080 @ 60Hz @ CVT-RBv2. 100.8 MHz pixel clock. htotal = 1520, vtotal = 1111
13: 1920x1080 @ 54 Hz @ CVT-RBv2. 118.8 MHz pixel clock. htotal = 2000, vtotal = 1108 if OC is disabled,
or 1920x1080 @ 60 Hz @ CVT-RBv2. 132.3 MHz pixel clock. htotal = 2000, vtotal = 1111 if OC is enabled
14: 1600x1200 @ 57 Hz @ CVT-RBv2. 118.8 MHz pixel clock. htotal = 1680, vtotal = 1233 if OC is disabled,
or 1600x1200 @ 60 Hz @ CVT-RBv2. 124.2 MHz pixel clock. htotal = 1680, vtotal = 1235 if OC is enabled
15: 1920x1200 @ 48 Hz @ CVT-RBv2. 118.8 MHz pixel clock. htotal = 2000, vtotal = 1228 if OC is disabled,
or 1920x1200 @ 60 Hz @ CVT-RBv2. 148.5 MHz pixel clock. htotal = 2000, vtotal = 1235 if OC is enabled
The vertical refresh rates of those modes can be orthogonally unlocked/adjusted up to 75 Hz, subject to pixel clock constraints (max 118.8 MHz when OC disabled, 175 MHz when OC enabled) and what the input video mode from the VGA adapter is.
With some luck, one of those video modes might work as a fixed target in such a scenario.
The one difficulty with VGA is the whole "VGA border" scheme. The above timings are all DVI-D timings, in an era where VGA border had been shrunk to 0 pixels (with exception of 640x480 iirc). But depending on the monitor, they might have hardcoded understanding that there would be 8 pixels of border on all four sides, and get trigger happy to cropping such a border away. There is an option to preserve the border in CRT Terminator, but with a DVI-D -> VGA conversion, it is hard to say how successful that kind of use will be.
Ideally utilizing a display that has a built-in DVI-D or HDMI video port will yield the best results. A passive HDMI -> DVI-D converter works well with CRT Terminator, if the display only has a DVI-D port.
Reply 78 of 78, by Pierre32
Thanks for that answer! Yep I acknowledge that a DVI monitor is the most sensible path here, and I will be testing on a couple. But I'm really attached to my 4:3 beige displays in a retro setup, so I'm just pondering this stop gap option while I hunt for a good one with DVI.
The experiment will only cost a few bucks, so I'll be happy to test and report back.
mkarcher wrote on Yesterday, 12:48:
Scaled output to run flat panels at their native res.
